Projects Just Another Hemi Powered Model A Coupe Build
Discussion in 'The Hokey Ass Message Board' started by ClutchDumpinDan, Aug 1, 2019.
  1. ClutchDumpinDan
    ClutchDumpinDan
    Here's how it sits as of this posting...
    Decent body but the subfloor had been hacked up, so new one went in with Steadfast rear rails for the '32 frame...
    Made a threaded bung for steering box so the bolt wasn't poking through the frame...
    Model A tie rod ends for the wishbones...
    Original Model A axle that's been dropped, standard vega cross steer stuff...
    P&J shock/headlight mounts...
    jimpopper, Stogy, 1947knuck and 30 others like this.
  2. Jalopy Joker
    Jalopy Joker
    Cool - doing good
  3. ClutchDumpinDan
    ClutchDumpinDan
    Dash/pedal support...
    Under dash pedal mount setup...
    Steering column drop...
    Column in and dash going in...
    Dash holes modified for gauges...
    Underdash panel for extra gauges, switches, 12V outlets...
    It's tapered so it's the same thickness as the dash...
  4. ClutchDumpinDan
    ClutchDumpinDan
    Wheel well repair time...
    Wanted it to match the c-notch in the frame so went ahead and made them...
    Aftermarket tail pan was a real POS so cut the ends off and redid them so it'd actually fit. New trunk lid fit and hinged as well...
    Had to make the rear floorpan due to the Steadfast subrail kit...
    Welded flange nuts in some square tube for the fuel tank mount as getting to the backside will be about impossible once it's done...
    Then made a panel to separate the trunk area...
    Angle bent on the top. Over 48" wide so I had to make it in 2 pieces...
    It's in the hole!...
    Fuel tank mounted up...
  5. ClutchDumpinDan
    ClutchDumpinDan
    Dimpled holes in the visor...
    Layout...
    Drill...
    Dimple...
    Admire hard work...
    Hacked up some 2x3 tube and welded in flange nuts for the seat mounts...
    Stogy, 1947knuck, Tall t 26 and 16 others like this.
  6. ClutchDumpinDan
    ClutchDumpinDan
    That's pretty much up to date. Roof gets cut off tomorrow. Stay tuned...
    wheeldog57, Stogy, 1947knuck and 26 others like this.
  7. Joel Reeves
    Joel Reeves
    Dan,
    That was a Good Days Work!
    Stogy, ClutchDumpinDan and loudbang like this.
  8. Bugguts
    Bugguts
    Wow! Loving it all! Subscribed for more.
  9. Nailhead Jason
    Nailhead Jason
  10. 63Compact
    63Compact
    I like it nice work
  11. Kiwi 4d
    Kiwi 4d
    Very nice work. Only one Question , how come you did not use the original dash knob holes?
  12. Scott_Rod
    Scott_Rod
    Awesome. As usual
    Dan, you make us normal people look like hacks.
  13. 392
    392
    Fantastic work. Nothing like a hemi powered rod.
    a boner, ClutchDumpinDan and loudbang like this.
  14. 57 HEAP
    57 HEAP
    I want one!
  15. Just Gary
    Just Gary
    Beautiful work, Dan. I especially like the tank mounts & seat mounts. :cool:
    But how many cans of Mountain Dew has it taken?:eek:
  16. slowmotion
    slowmotion
    Gonna be sweet, outstanding work!
  17. Flamed48
    Flamed48
    What’s the dash out of?
  18. Dog_Patch
    Dog_Patch
  19. oj
    oj
    Lookin good Dan, a cl***ic Model A hot rod is hard to capture, you're doing a great job!
  20. D-Russ
    D-Russ
    Very tidy work Dan, I've learned a lot from you.
  21. catdad49
    catdad49
    Outstanding! More, Please.
  22. brady1929
    brady1929
    Damn, that's a cool hot rod.
  23. 1946caddy
    1946caddy
    from washington
    Looks like a 36 Ford to me.
  24. ClutchDumpinDan
    ClutchDumpinDan
  25. Gammz
    Gammz
    from Lincoln Ne
  26. john mullen
    john mullen
    You are am amazing metal artist Dan....
  27. ClutchDumpinDan
    ClutchDumpinDan
    Didn’t want just gauges in the lower panel. Tried to avoid the “add on” gauge panel look. Like a clean/smooth dash as well.
    Well I’m not gonna post the pics where I messed up :D
    Thanks Gary! Soda free haha. Powered by water these days believe it or not.
    Ok. Coming up!
    Yup, 36 Ford.
    Thanks John! Means a lot coming from a true pro.
    1947knuck, Stogy, Dino 64 and 4 others like this.
  28. Kiwi 4d
    Kiwi 4d
    This is obviously not your first rodeo, lots of great ideas to share here. Good skills.
    We have fitted a 36 dash to our 28 tudor but extended it out slightly to have a small glove box and speedo cable clearance. But we goofed and now window winders wont clear the dash. Not too sure what the plan is there yet.
  29. ClutchDumpinDan
    ClutchDumpinDan
    Starting to finish up some of the chop welding. It’s gonna finish off pretty good.
    Chopped the windshield frame down. Gonna have to move the pivot points due to the upward curved ends in dash. Cost of looking cool :D
  30. 61cad
    61cad
    Awesome work dan
