Hot Rods We goofed , 36 dash in 28 tudor.
Discussion in 'The Hokey Ass Message Board' started by Kiwi 4d, Aug 4, 2019.
  1. Brown Devil II
    Brown Devil II
    from Mission TX
    I had the same problem by using a 40 dash on my coupe. I used 33-34 windshield crank knobs work perfectly. I will try to post a picture tomorrow.
  2. Hnstray likes this.
  3. RICH B
    RICH B
    I was thinking along the same lines; but a slightly larger coupe roll-down rear window handle.
  4. kaspar
    kaspar
    Had the same problem in my Model A with -59 Impala dash. Moved the driver side mechanism to the p***enger door and vice versa. The winders ends up in the back of the doors, but it worked fine in my car, don't know if it would work out in your application.
    I don't have pictures of the winders in the new locations, only a picture of the winders... not being in the original location.
    Stogy and Kiwi 4d like this.
  5. Kiwi 4d
    Kiwi 4d
    Well @kaspar thats worth a thought .our seats are probably 17” or less behind the B pillar so still enough elbow room.
  6. Mimilan
    Mimilan
    He could carry on with that same theme by swapping the doors from side to side
    Then the winders would be at the back. [clearance problem fixed] :p
  7. Kiwi 4d
    Kiwi 4d
    Well further to shifting the winders to the back of the door . ****** me ,,,,,there are three factory holes as a mirror image of the front 3 ?? Dunno why, maybe if Henry thought some dummy will fit a fat 36 dash in here someday and not allow for window winders????
  8. neilswheels
    neilswheels
    from England
    So much stuff i've done on my 40 has had a 'knock on effect', fix or modify one thing, generate another three things to do..
    Kiwi 4d likes this.
  9. goldmountain
    goldmountain
    Back to my solution. Did I fail to mention that it was real easy to do? Also, those regulators are easy to find.
    Sent from my SM-T350 using The H.A.M.B. mobile app
  10. Toner283
    Toner283
    Saving $$$ in tooling costs. They are identical left to right so only one stamping is needed. One set of stamping dies and ***ociated tooling versus 2 sets of dies/tooling if they had been left side/right side specific stampings.
    And as far as the electric switches, we have a set in our Coupe and they work really well. However ours are not Autoloc ones. The Autoloc/Hoffman group stuff is junk. Save yourself the aggravation and stay away from it. And as far as someone trying to wind the window down with the power off, they only move a few degrees and then they have a very positive solid stop. Somebody would either break the handle or tear the winder mount out of the door before they break the winder switch.
    I cannot remember who made the ones we have as that's 12 or 15 years ago that we bought them. However they were Model A specific, they had the holes in the right place and they bolted right into the doors in the stock locations using the stock holes with no issues at all. Even had the proper square shafts for the stock Model A winder handles.
  11. stanlow69
    stanlow69
    Did the interior in a chopped and channeled Model A coupe with a 54 Ford dash. It was all painted and a real cl***y looking car. Had the interior all finished. Installed the door handles and shut the doors. Just realized the dash stuck out. Luckily the handle cleared with the window down. Opened the door and rolled the window up. Shut the door and the crank also cleared. Told the owner and he didn`t even think to check that out as he never installed the handles yet. Lucky day for us all.
    Kiwi 4d likes this.
  12. Automotive Stud
    Automotive Stud
    Probably unpopular opinion, but the stock tank with that dash looks like an ongoing headache. I'd eliminate the fuel tank there, then rework the dash further forward.
  13. Kiwi 4d
    Kiwi 4d
    How is it a headache?
  14. Use the 46 48 wind wing cranks and you'll be set.
  15. Kiwi 4d
    Kiwi 4d
    Thanks to @kaspar the solution was right there with the factory stamped holes . A simple bolt up deal . Now shame we only have two RH regulators < in saying that I don’t think one is even model A. Need to find a LH one to put in the RH door.
  16. kaspar
    kaspar
    Both my regulators were really bad, bought new from Snyder’s.
    Cliff Ramsdell likes this.
  17. 97
    97
    Trade me auction# 2271137055 closing Tuesday.
  18. Brown Devil II
    Brown Devil II
    from Mission TX
    I saw that B*** did that on his Model A and it was a great idea. Unfortunately that was not going to work for me because I salvaged the 60's upholstery and the holes were already on the panels. Before someone mentions to change the door panels from left to right it could not be done due to the design on them.
  19. tb33anda3rd
    tb33anda3rd
    can you cover the un-needed hole with an emblem, piece of trim, etc....?
  20. Kiwi 4d
    Kiwi 4d
    Looks like it will and does work putting the left window regulator on the right and vice versa. We also filled bear claw locks .used mid 30s ford remote interior handle in the old window regulator hole.
    More by luck than good management the window crank clears the bear claw bulge ,and if the crank is left facing the pillar lock pin it also clears that .
    Now to reinforce the B pillar.
    BDC43017-D5A7-4CE0-BCED-8E8B7924FC68.jpeg B0E778D8-8D1B-492B-A9DF-E891CFC67DFF.jpeg 4193AF55-E798-4766-9B30-AF983B118849.jpeg E3405AF6-9F32-44C2-B979-FD6C93A58D21.jpeg
    Cliff Ramsdell and kadillackid like this.
  21. 28rp
    28rp
    I struck this same problem when I put the 40 dash in my 28 Tudor-I solved it by measuring from the centre of each crank hole a equal distance on the vertical plane, then added an extra 15 mm onto the edge of each piece of panel and basically cut and switched the left hole to the right door and vice versa-hard to explain in words but easy to do-I found 15mm gave me enough for the stock A winders to clear the dash. I figure if the gl*** wants to rise crookedly I can just tap the channel along the gl*** to centralise the rise of the gl***. also had to shift the pressed hole further down the same amount. Clear as mud I know, bit easy when you approach the job
  22. chiro
    chiro
