Projects 60's Era Street/Strip Model A Coupe
Discussion in 'Traditional Hot Rods' started by -Brent-, Aug 1, 2019.
  1. -Brent-
    -Brent-
    Thanks, 40! I appreciate it. I went back, last night, and added a couple more detail pics here and there and fixed some of my typos and such. I'm trying to squeeze this thread in whenever I'm free and I see, now, I didn't proofread so well. Hahaha.
  2. -Brent-
    -Brent-
    I had two really good cowl/gas tank tops so I kept one with the filler and cap and we filled the other. I actually like the tank filler kept in place.
    My thought on it is this, a lot of customizations have been made and keeping the filler is exercising restraint. The other part of my brain is like, "a whole list of things have changed, not changing this seems odd." So, that's pretty much how my brain works on things... haha.
    The fuel tank top that's in the car, now, came off my donor ch***is. I fully expected to see a nightmare in the tank when I cut the top off. However, when I saw inside, I felt bad for a moment because it was the cleanest tank I've EVER seen in all my years of cutting up and parting out this stuff.
    That's the worst of it!
  3. -Brent-
    -Brent-
    B Pillar Wood, Welding, and Rust Converter
    With the sub rails in, we can take out the bracing. Finally! Now the wood comes out.
    I modified this tiny, flat puller on the grinder so I could get it under the nail head without any damage and then it could "roll" over the sheet metal and pull the nail.
    Anyone who chops one of these cars knows its a paint to get any sort of decent weld with the wood in. So, with the wood out, we pulled the pillar and got some tacks on each.
    Matt squaring the prior cuts.
    This is the side that can be seen with the door open. So, it got a better finish on it.
    I wire-brushed the pieces and sprayed them with some rust converter.
    I did the same with the inside of the car. The wood had blocked these area when it was blasted.
    Probably not needed but it was cheap insurance.
  4. Nick Agius
    Nick Agius
    This is so awesome, Great stuff!
    loudbang and -Brent- like this.
  5. mgtstumpy
    mgtstumpy
    I'm on board ;)
  6. mad mechanic
    mad mechanic
    subscribed :)
    Loving this....
    -Brent- and loudbang like this.
  7. -Brent-
    -Brent-
    Thanks, fellas! I appreciate it.
  8. -Brent-
    -Brent-
    Olds/Pontiac Rear End - Diss***embly
    Early on in the plan I knew that this car had to have an Olds/Pontiac rear. I kept my eye out, locally, for a while. Eventually a parts car popped up. The seller was a bit reluctant to sell just the rear and I considered buying it for the 389, too, but rebuilding a O/P rear was costly enough. Hopping up a 389 is even more expensive... but man do I love those engines.
    The axle donor was a 1959 Pontiac Star Chief.
    Obviously, an axle out of a boat like this would be way too wide. So, like seemingly everything else, it will get modified (narrowed).
    Seemed like I was tripping over this thing for a few years... it had to be a couple, at least! Wrestling that heavy SOB into the truck was a great time.
    Dis***embly in the yard. Those lefty-tighty lug bolts always get me!
    One pesky backing plate nut needed some extra attention.
    Then, after a couple cut off wheels, all the brackets were removed. I should have left that one on the center of the housing, it looks weird without it.
    I left the third in and made some plywood caps and bolted them in to keep the sand out. It worked like a charm.
  9. -Brent-
    -Brent-
    Narrowing an Olds/Pontiac Rear End Housing
    Man, I love when stuff comes back from media blasting. I started using a new place (well, new to me) and they're affordable, they do a great job and they're FAST. Unheard of, I know! Oh, and they're a friendly lot, too.
    I pulled the third and the end covers and cleaned out as much oil as possible. On the recommendation of Dave from Fabcraft, I marked up the housing and put a dimple to measure from on both sides so that there'd be no questions if Brian and I lost contact. He's so with it though, all my markings were probably not needed.
    That divot was punched in to be 4" from the finished end.
    To figure how wide the rear should be, I didn't get scientific. I just asked folks whom had cars that were in a similar style (i.e., with mags, slicks, tire hangout, etc.). All that said, I like round numbers, so we ended up taking off 3" from either side.
    It's neat how he set it up in the lathe to burn the ends in.
    This lower photo is actually really neat. Check out the grounding wire. The pros have all he tricks.
    From what I hear, the factory ends weren't always true (this goes for all the automakers). Brian is meticulous in his set-up.
    Those Fabcraft ends are really nice. Hindsight being what it is, I could have run big bearing Ford ends and run a lot less expensive drum brakes. Live and learn. I guess it's easier remaining all Pontiac... so there's that.
    You can kind-of see there's a drain plug installed too. Brian went around and filled in a bunch of divots in the tubes. Some were like that from the factory and some were from removing the bracketry.
    It ended up being pretty close to the width of an early Bronco 9" housing. I'd have to check my notes but with the drums it's in the 58" range... like 58.6"... something like that.
  10. -Brent-
    -Brent-
    Measuring For Axles
    Fabcraft has this handy template. It makes measuring for axles simple, otherwise I'd surely get it wrong!
    While the pics don't show, these end were pretty much dead-nuts exact. However, holding a tape measure, a straight edge AND a camera is NOT recommended. I measured like 10 different times and then twice more with Dave from Fabcraft on the phone... hahaha.
    The axles are 31 Spline "Pro Street High Performance Axles" for 1957-1964 P/O 9.3' Rear End, 4340 Chrome Moly, heavy tapered shaft, extra thick flange w/large bearing journals. Full through heat-treated. 2 Bolt Patterns: 5.50" & 4.75" x 5
  11. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Excellent work and love the era you're shooting for. I went back and forth about chopping my '31 and ultimately didn't. Kinda glad after driving it and trying to see stop lights and stuff.
    John Davies' coupe was my inspiration as well. Love the stance and paint too. Couldn't bring myself to cut on my body at the time since paint wasn't in the picture, but someday it'll get root beer and gold......
  12. -Brent-
    -Brent-
    Thanks Mr T., I knew from the outset that I wanted a chop. It was the other stuff I hesitated with, like running a 32 ch***is. It was an awesome set-up but it didn't align with what I was p***ionate about.
    There was all sorts of evidence, however, I just wasn't paying attention. Looking at the folders of Model A ideas and there was a lot of similar cars to what I had posted.
    So, it is good to wait on it, like you did on the chop and I did on the ch***is.
    JUNK ROD, 1947knuck and loudbang like this.
  13. boutlaw
    boutlaw
    Brent , awesome work and vision. I wish I had seen detail like this before I chopped and repaired my 31 coupe back in 2012. The details like the aft firewall supports, the closeout panel and rear firewall in the trunk and the way you chopped the top are just well thought out and perfectly executed. I like the 60s era drag coupes as well and the examples in your avatar are perfect illustrations. Definitely subscribed. Glad your vision is better and that your lifestyle changes have made a difference. Beautiful kids to help you enjoy this ride when you finish. Now get back to work and keep posting.....
    BOutlaw
    1947knuck, brEad, Thor1 and 2 others like this.
  14. -Brent-
    -Brent-
    Thank you for the kind words, truly!
    I'm no innovator, a lot of this stuff I've seen before and I put my own idea on it. I've never seen the capped feet or the blank for the pedals but they make sense to me.
    Lots of this stuff won't ever be seen but I enjoy the creative process of problem solving... so both doing that and knowing the details are there makes me happy.
    I looked at your profile @boutlaw and I have to say your coupe looks pretty damn mean. I think you nailed it.
    As for the health changes, I'm grateful for the wake-up call. Man, I was going the wrong way for a while.
  15. brad2v
    brad2v
    Still loving it. I really like your approach to how much to narrow the diff. No aerospace engineering formula, just pick a number.
  16. -Brent-
    -Brent-
    I mean give me a little credit, I had a tape measure in my hand... I think? :D
    1947knuck, loudbang and brad2v like this.
  17. Tim
    Tim
    from KCMO
    Glad to see you filling this post up! And more glad that I caught it early so I don’t have to spend three days catching up on it
    Love seeing some notes and tools used to get what’s in the photos. That tool to measure for axles is genius
    loudbang, brad2v and -Brent- like this.
  18. -Brent-
    -Brent-
    Thanks, Tim!
    Yeah, that's a pretty neat set-up. The folks over at Fabcraft are a pretty decent bunch.
    1947knuck, mad mikey and loudbang like this.
  19. Hotdoggin DaddyO
    Hotdoggin DaddyO
    from Hays, Ks
  20. -Brent-
    -Brent-
    Bringing the Coupe Body Home
    I flew out to Matt's and picked up a U-Haul in Oakland, on my way.
    We loaded it up and it was bittersweet. I love Cali and Matt is a good dude, too.
    My sleeping arrangement for the night... that was a rough one.
    Somewhere in Nevada.
    Loading it was easy with a forklift and two guys but I am a notorious one-man band, so I figured out how to get the coupe down on my own. It's now a much heavier body! I used to be able to carry it around by standing inside, lifting up and walking around. Not anymore and I am glad about that!
    Bringing the Coupe Home 1.jpg Bringing the Coupe Home 3.jpg Bringing the Coupe Home 4.jpg Bringing the Coupe Home 5.jpg
    Now it's home for a bit.
  21. -Brent-
    -Brent-
    The Model A Frame
    Now that the body was home, I had to prep for the next stage - getting it into a roller. That means the ch***is needs to be built, some parts acquired, etc.
    As mentioned, previously, the car will sit on a modified, original frame. I had a perfect frame for the car but, like a fool, I sold it a while back. I have a beautiful, stock frame sitting under my roadster but I didn't want to make any other foolish decisions and then kill that project by using the frame.
    So, the hunt was on. Actually, I really love that process of hunting down the right parts and pieces for projects. Not just car projects, either, I do it for my house and shop and so on.
    I used to buy and sell a lot of early Ford parts. It's how I paid for most of what I have. I'm still plugged into that loop a little bit and occasionally there'll be a time when the truck gets loaded with parts to resell, it's not all that much anymore. Times have changed, I've changed and my storage condo is at max capacity (I hate that it's packed). Still, I found an ad for a bunch of A parts, including frames a few hours away in Colorado. Maybe there'd be a decent frame, if not, I could pick up some parts I didn't have to make a little profit on.
    I did scoop up a few frames and a bunch of other parts. None of these frames were good enough for what I wanted.... especially after owning two pristine frames.
    When I was there, though, I did see this 31 ch***is. I didn't have a trailer, though, or I would've dragged it back with me.
    99% of the time frames are in better shape when they're on axles/springs/wheels. Being in Colorado doesn't hurt, either.
    The next weekend, I dragged a trailer out.
    The Tundra was a great parts chaser, too bad the motor got wiped out at 90k. :(
    Once the ch***is was home, it sat around some more. It was now a play fixture and the gr*** grew long under and around it.
    [Edit] Just looking at these pics and I am quietly kicking myself. This cowl, which I robbed other parts from, could've have a perfect donor piece to fix my car. But, yet again, I sold something too soon. I don't think I'll ever learn that lesson. I sell most things as quick as possible...
  22. -Brent-
    -Brent-
    Model A Frame Tear-down and Sand Blasting
    The tear-down begins.
    And After, it got to sit for the rest of the season. After this season's snow, it'll live life in a garage... stay strong little buddy. Hahaha. :D
    Then, as summer came, I tore the frame down further, just to a perimeter, and brought it down to the blasters. While I was pulling it apart, I looked over it much better. It's in really great shape. The only major pitting is at the motor mounts. I've seen far worse. I'm pretty happy with this frame.
    All cleaned up.
    Little by little, it's getting closer.
  23. UNSHINED 2
    UNSHINED 2
    Your comprehensive posts are most excellent! I come back daily to see what youve posted. Keep on, keepin on!
    L7, Thor1, loudbang and 1 other person like this.
  24. -Brent-
    -Brent-
    Thanks, Dane!
    There's a little bit left to wrap up before we get current. The ch***is will be underway soon and I'll post updates as they come in.
    1947knuck, loudbang and UNSHINED 2 like this.
  25. UNSHINED 2
    UNSHINED 2
    Excellent. Maybe I'll be able to see it before it goes back out West.?.?.
    oliver westlund, loudbang and -Brent- like this.
  26. -Brent-
    -Brent-
    Putting The Body in Sealer
    The car will be heading out to @Von Hartmann 's shop in Illinois, which has been notoriously humid (the state, not just Von Hartmann's shop... haha). It's been on the news for it's rain and record-breaking heat index. That type of moisture in the air won't play nice with the unprotected coupe body.
    That said, I needed to get the car protected before dragging it out to Ryan.
    I called up the same tow company that towed my Tundra when it died and they sent a hot rodder to my house. He's an awesome guy and had my son man the controls. Usually I wouldn't post so many pics of loading a car onto a flatbed, but I really loved this moment. I wish his little sister, who was at school, was able to help... she's ALL about this stuff at the moment.
    This pallet has seen some use!
    Explaining the controls.
    Teamwork.
    The operator, Gary, was like, "You're not done, yet, buddy!" and brought him over to the other side where they finished loading the coupe.
    When the coupe left, we loaded up the pickup with the fenders and head over to the shop.
    Aside from prepping the body for sealer, they wanted to adjust the panel above the deck lid, push the rear quarter out a bit on to get it into proper shape, and the front of the drip rails (where the header panel was installed) really bothered them, so they wanted to address that - too.
    In about a week, my hope was to be loaded and on I80 heading east.
  27. Vic Walter
    Vic Walter
    very cool, i am in for the long haul
  28. -Brent-
    -Brent-
    Thanks, Vic!
  29. -Brent-
    -Brent-
    Seeing the Coupe in Bare Metal - One Last Time
    The shop owner had called me with a few questions and mentioned that the car was in bare metal. They had run up against the clock and couldn't get everything done. The priority was to get everything into sealer, so the "other stuff" will have to wait.
    Knowing that the car was in bare metal, I had to swing by. This is probably the last time I'll ever see it like this.
    Here are some pics. As you can tell, it still has it's share of waviness, dings, dents, and now a few new holes.
    They tried to grind in the continuation of the drip edge seam. I don't know how it can be fixed but we'll get it sorted.
    Another thing to sort is the seam of the decklid patch. From some angles it's barely visible, from others you can see it will need some bodywork.
    The top of the decklid now matches very well to the upper panel.
    Another area that was ground through. I think they cut this area to adjust the gapping or maybe the cut was part of them working on the rear 1/4 adjustments.
    Next time this car is seen, it will be in sealer.
  30. -Brent-
    -Brent-
    Model A Coupe in Sealer
    The car was ready to go the morning I had planned to leave. So, I was in a rush (I still didn't leave that day) and didn't take many pics.
    Sadly, that's all I got. It went straight into the trailer and I headed out to load up so I could get on the road.
    Still, it's awesome to see it "painted" for the first time in ten years!
