I just went and measured my Austin Ruby and it is 4" narrower than that one. Looks very similar however.
Yeah I was thinking international but no good dimensions on web I’ve found. Thanks goldmountain for checking your ride.
it does resemble International frame however too short and the hinges are wrong. This International frame is 15” It would be a close fit for this IHC cab I chopped down 3”
I found some measurements of a '36 Ford car windshield I had taken for a friend. The width at the widest point was 42-3/8" at the widest point. The height was 13-7/8" tall in the center. Both measurements were from the inside of the window frame with the gl*** installed. The subject windshield of this post is definitely not a '36 Ford, at least not one made in the USA. The joint between the upper & lower halves looks exactly like the Ford, but the hinges are completely different.
