Hot Rods Let's talk Cadillac 331's, 365 and 390's
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Apr 7, 2016.
  1. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Is there any advantage to running 57 365 heads on a 331?
    ls1yj and loudbang like this.
  2. ls1yj
    ls1yj
    from Kentucky
    Tuck,
    Yes, the 365 heads breathe better, have slightly larger valves and ports, and centerline is close enough on valves not to require large overbore on 331.
  3. Roothawg
    Roothawg
  4. Roothawg
    Roothawg
  5. 31hotrodguy
    31hotrodguy
    Just got my new intake in the mail today from White Owl. I’m pretty excited so I thought I’d show off a bit. [emoji3] IMG_5366.JPG
  6. 31hotrodguy
    31hotrodguy
    Also a little excited because I got the crank out of my stuck 365. Lost 3 rods in the process. Still excited though. [emoji1303] IMG_5371.JPG IMG_5369.JPG
  7. Roothawg
    Roothawg
    Looks like a nice casting.
  8. 31hotrodguy
    31hotrodguy
    The casting looks good. The only bummer is the messed up the offenhauser name on the other side and then ground part of the name. I might be able to turn it into just Offy IMG_0001.JPG
    lumpy 63, Bowtie Coupe and loudbang like this.
  9. Roothawg
    Roothawg
    Mines getting a full polish anyway. No free advertising
  10. 31hotrodguy
    31hotrodguy
    That is my plan as well. Now I just need a pair of heads a**** other things. [emoji3]
    winduptoy, loudbang and Bowtie Coupe like this.
  11. 31hotrodguy
    31hotrodguy
    Offy contacted me here on the H.A.M.B.
    and made good on the poor casting. It’s always a pleasure to deal with professional people who care about their products and their customers. I am impressed.
    belair, lumpy 63, winduptoy and 7 others like this.
  12. Roothawg
    Roothawg
    Glad to hear it.
    loudbang and 31hotrodguy like this.
  13. loudbang
    The power of the HAMB. :)
    winduptoy and kadillackid like this.
  14. 31hotrodguy
    31hotrodguy
  15. Roothawg
    Roothawg
    I bought one of the last bellhousings for a T-5, Tremec and TKO the other day from the Holley clearance area, thanks to a fellow hamber's tip. I guess now, at least I know I am running a stick for sure.
  16. lumpy 63
    lumpy 63
    I am working out the details of my quicktime bell and am pretty sure I can set it up to work behind a 390 using a GM type Tremec, without machining the back of the Cad crank. Have an order into Wilcap for the flywheel and have ordered an AMC adapter bushing from Novak. It has a 1.8 OD and I will turn it down to 1.6 OD for the Cad . Will post my findings.
    winduptoy and loudbang like this.
  17. lumpy 63
    lumpy 63
    I also have to give credit to Roothawg for digging up all this bad *** Caddy knowledge:cool:
    winduptoy, loudbang and Roothawg like this.
  18. Dangerousdan
    Dangerousdan
    from Arizona
    I have in countered a Cad 390 short block. I 'm looking for a pair of stock heads for it . I will need rockers and shaft also. Thanks for looking
    warbird1 and loudbang like this.
  19. 31hotrodguy
    31hotrodguy
    Good deal! Since I am not racing mine I got my adapter from Wilcap last month. Nice guy to work with. Ps, the adapter was not cheap!
  20. Roothawg
    Roothawg
    I probably will never see track time with mine, but just in case it ever comes apart, my feet feel better.
  21. 51box
    51box
    from MA
    What flywheel and starter works with the Cadillac quick time bell? I can’t seem to find specifics from them
  22. lumpy 63
    lumpy 63
    I ordered the wilcap flywheel that they spec out for their manual trans adapter, It is 130 tooth and use's a mopar starter . I will post more info when I get it this week. If you go to the quicktime thread on here it talks more about the starters.
    winduptoy, Roothawg and loudbang like this.
  23. 51box
    51box
    from MA
    Ok thanks @lumpy 63 , did you get a pilot bushing from them also?
  24. lumpy 63
    lumpy 63
    Yes I ordered one but I think its gonna be for a 331. I am working on one for a 390, will post my findings:cool:
  25. What carbs are you planing to run? looking for advise and ideas of what works on these 331's. I have 94's , 97's, 81's and 92's. What combination works?
  26. Roothawg
    Roothawg
    Yeah, don’t believe them. They (Holley) told me it took the stock starter. Nope. The Dodge pickup starter works. Lumpy has the part number.
    31hotrodguy, lumpy 63 and loudbang like this.
  27. WHITEOWLSPEED has valve covers on sale
    loudbang, 31hotrodguy and lumpy 63 like this.
  28. 31hotrodguy
    31hotrodguy
    I’ll probability run 97’s. I’m still a ways off from that. I still have to find engine parts. But I wanted to grab the intake while I could!
  29. Roothawg
    Roothawg
    So a lot of you know Tony from Ross Racing, he is a fellow hamber and builds a lot of vintage engines. He just posted this on IG. He had mentioned this when I called him recently, glad to See it’s moving forward.
  30. belair
    belair
    Ross racing just kills it.
    winduptoy likes this.
