Projects Grill insert ideas for a Model A
Discussion in 'Traditional Hot Rods' started by jimbousman, Mar 1, 2019.
  1. jimbousman
    jimbousman
    Looking for some ideal for a grill insert for a model A. Mine is a '31 and while
    I know I could always go for a deuce grill, I want to keep it A. I have an aluminum radiator. I painted it black but is recessed about 3" behind the shell. Look hoky so I am looking at different screens, meshes, bars are generally any ideas for an insert.
  2. HOTRODPRIMER
    HOTRODPRIMER
    You could use these guys idea to make a insert.
    Theirs is a little pricey. HRP
  3. scrap metal 48
    scrap metal 48
  4. Tim
    Tim
    from KCMO
    You know you can just click full size when you post the photo and it’ll be big all the time.
    jaw22w and scrap metal 48 like this.
  5. 2NDCHANCE
    2NDCHANCE
    I have a 1930 Model A Tudor sedan on a 1932 frame with a AA painted steel grille shell. There is approx. 1" of room inside the shell to install an insert. Could a stock Model A rock guard be trimmed down and installed inside the grille shell? Looks? IMG_2082.JPG
  6. scrap metal 48
    scrap metal 48
    Tim, if you click full size it gets even bigger... (just ask my wife)….
    Dino 64, Tim and Just Gary like this.
  7. sloppy jalopies
    sloppy jalopies
    Tried too trim a '31 grill guard.. not big enough...
    so I traded it for a '32 -V8 headlight bar...yup.
    Fluorescent light screen or grate... $13 at lowes…
    1 sheet does 2 model A shells... about 1/2" thick... moves the shell ahead the same... hood ?
    the flash makes my buddy's '31 look grey...
    Deutscher and 6sally6 like this.
  8. Just Gary
    Just Gary
    catdad49, oj, Jalopy Joker and 2 others like this.
  9. pitman
    pitman
    1/2" × 1/4" expanded steel mesh oriented 'down' w/ 1/2 cut horizontal. Paint it black.
    Turns likes this.
  10. dana barlow
    dana barlow
    from Miami Fla.
    I've used a number of def. stone screens,1/4in. wire screen/a type of chickenwire,also screendoor pet protechtor and fineily some stainless steel 1/4in. screening. I do like some I've seen that are art layzer cut. I'll post a pic of one thats cool ,I saw on the net. Some one did some great art on that !
    catdad49 likes this.
  11. 41rodderz
    41rodderz
    from Oregon
    How about a 1929 Pontiac grille. Looks like a '30 /'31 A but more art deco looking
  12. BJR
    BJR
    All of those block air movement through the radiator, so if your car is on the edge of heating up this may be a bad idea.
  13. RICK R 44
    RICK R 44
    Flattened expanded metal, painted a color of your choice. See my avatar.
  14. Just Gary
    Just Gary
    Some pix from my "good idea folder"::)
    A RPU grill 01.jpg a%20o%203.jpg DSC05852.JPG JohnOlays29 01.jpg Picture%20055.jpg RoyalShifter 0.5 01.jpg RoyalShifter 0.5 03.jpg toxic tom 1.5.jpg whitlock .75in holes.jpg yellow grill.jpg
    dana barlow, catdad49 and pitman like this.
  15. firingorder1
    firingorder1
    Henry got it right the first time. Why mess with right?
  16. fastcar1953
    fastcar1953
    DSCF7040.JPG stock and modified
  17. Dirk35
    Dirk35
    Definitely following this for ideas. I don't like the idea of the expanded metal, and I need something that is super thin to protect the radiator fins. My Model A has a few fins that were smashed by a rather large bug and no matter how much I've tried, I cannot get them to comb out nice enough to where I cannot tell the damage was there.
  18. esrbuilders
    esrbuilders
  19. Tim
    Tim
    from KCMO
    Austin kays likes this.
  20. Canuck
    Canuck
    Molded HD Industrial Plastic with a woven pattern. Trimmed to fit and bonded to inside of grill shell. 90+ degree temperatures in slow city traffic and no trouble keeping temp at 180.
    With stands runs at speed. Repels stones and small animals. Keeps bugs from in-bedding them selves in the rad fins. And I think it looks good.
    Got the piece from a friend and he didn't know what it was originally made for. Only used half of it, if anyone is interested send me a message.
    Canuck
  21. denis4x4
    denis4x4
    from Colorado
    This is stainless shaker screen.
  22. Austin kays
    Austin kays
    Yeah I just used an old mess engine guard off an old industrial engine. Haha coincidence it’s actually off the case @Tim motor came in
  23. ckdesigns
    ckdesigns
    from Ogden,Utah
    [​IMG][​IMG]
    I built this insert some stainless steel rods from the s**** pile at work.
  24. rwrj
    rwrj
    from SW Ga
    Mine is from the screen of an old swamp cooler. Wasn't big enough to let the two spots with more wire be symmetrical, but I kind of like it plaid. Haha.
    catdad49, belair and spurgeonforge like this.
  25. Mike Colemire
    Mike Colemire
    If you can find a stainless shield that goes around semi truck exhaust, they work great. They will have oblong holes in them. A friend has picked several up at big truck shops where one end would be damaged.
  26. IRION29
    IRION29
    from Alberta
    Sorry I don't have picture of it, but my '29 Tudor has a sectioned '31 grill. I obtained a piece of '
    "perf screen" that has 68% open area, cut to size and had it nickel plated.Never runs past 190 deg.
  27. old round fart
    old round fart
    from Norman Ok.
    How filling a sheet full of louvers? Have to try to see if it cools but would be slick if it did!
