HEMI Tech- Identification
Discussion in 'The Hokey Ass Message Board' started by scootermcrad, Jul 17, 2006.
  1. Niksramjet
    Niksramjet
    Will do, Sorry for the confusion. Just trying to get the widest dissemination.
    Thanks.
  2. monc440
    monc440
    Hi Guy's going to look at a Hemi today. The block casting shows 1619829 for 354 and the stamp has an M for marine however is is stamped M35 4-2020. Any ideas? The only reference I can find for marine are all M45-- The head casting number is also 354 but no water outlets, I thought that was only 331 heads? Please see pics below.
  3. George
    George
    The Marine, Industrial & truck engines are like the 51-54 car engines, heads, oil pan, ect. What intake? tuck & marine are different from each other & from car intakes.
  4. monc440
    monc440
    Thanks George
    The engine doesn't come with an intake. Everything is dis***embled and I believe it is a mix and match of parts. It comes with the block, crank, rods, pistons, 2 sets of heads, 2 transmission adapters. When I go look at it I'm going to get casting numbers off everything to see what I'd be in for if I buy it.
  5. 73RR
    73RR
    No real mystery. The photo showing the end of the cylinder head clearly shows the truck 'pad'. If you remove the spacer gizmo on the intake rail you should find the tall water p***age at the center where p*** car heads have exhaust p***age. The 'spacer' on the front is typical of the truck water pump being raised up a wee bit to get the fan higher.
    30dodgeboy likes this.
  6. George
    George
    Why would a 354 block need a spacer?
  7. gimpyshotrods
    gimpyshotrods
    Someone was probably making a manifold.
  8. DAHEMIKOTA
    DAHEMIKOTA
    from Tenn
    Being an industrial engine it may have gears for the cam timing instead of a chain.
  9. mgtstumpy
    mgtstumpy
    My contribution, others with more knowledge can clarify. Hemi ID.jpg hemi-engine-block.jpg
    51 mercules and town sedan like this.
  10. 73RR
    73RR
    Agreed, likely a u-fab project.
    Trucks usually had gears but nothing shows in the pics and a p***-car cam is the usual cam used.
  11. gimpyshotrods
    gimpyshotrods
    Make sure there is a car/truck/industrial crank in that mix.
    Dedicated marine cranks are ever so slightly different, necessating a trip to a crankshaft shop, to fix it.
    On a land going vehicle, there is a slight step in the snout for the timing chain sprocket. It is not there on a dedicated marine crank.
    They run their drive on the "front", and all accessories are gear-driven.
    A good crank shop can make the step "appear" there.
  12. scootermcrad
    scootermcrad
    town sedan likes this.
  13. In_Benzin_Veritas
    In_Benzin_Veritas
    from Toronto
    Can anyone help with this serial number? I can't find info on the "C55" beginning
    milwscruffy likes this.
  14. gimpyshotrods
    gimpyshotrods
    Um, 1955 Chrysler 331, but I did not need the code for that.
    It has the extended block, so it is an early 331. There were some later ones with a rear block face like a 354 or 392.
    It is certainly a Chrysler. That's about the only way that they came. Two-barrel.
    C55 is Chrysler, 1951.
    Refresh what needs to be refreshed, put it in, and go have some fun!
  15. In_Benzin_Veritas
    In_Benzin_Veritas
    from Toronto
    Thanks for the reply!
    Yes I ***umed is as a '55 but was confused as I though the 331 lost the integrated bell housing / "extended block" in 1955. Didn't the heads change in 54-55 too to larger valves?
    I couldn't find any examples that specifically start with "C55-****X"
  16. slayer
    slayer
    A 55 331 Hemi would not have the extended bell housing. The last extended bell was done by early in 1954, most likely a leftover 53 engines. Maybe the bate code is a mis stamping.
    gimpyshotrods likes this.
  17. George
    George
    C55 is a 51-2 Saratoga engine.
  18. In_Benzin_Veritas
    In_Benzin_Veritas
    from Toronto
    No kidding ?!
    Wonder why they serial number start with “C55” you’d think it would be “**51 / **52”
  19. 73RR
    73RR
    For whatever reason, some engines were stamped with the vehicle model code. You can fine these codes in the front section of a FSM or parts book.
    Yup, kinda weird, but that's MaMopar.
  20. George
    George
    Long tails were 51-4. '55 331 code was CE55. The long tails were 2 bl engines with round ex ports. '54 4 bl were oval, still solid ends on the head. '55 had bigger valves & water ports in front.
  21. gimpyshotrods
    gimpyshotrods
    I stand corrected.
  22. Racingsnake
    Racingsnake
    from So Cal
    Hi, looking for some help with a serial number on a 392 block. It's N357404 CAL which doesn’t match up with anything I’ve been able to find. I did see a similar number on a block in another thread but there were no details on it. I'm guessing the 4-25-7 may be an April 25th 1957 casting date? I don’t know what the C and C5 represent though. Here’s a couple of pics.
    Desoto291Hemi likes this.
  23. caprockfabshop
    caprockfabshop
    I believe that to be a replacement engine, when they installed it in the car they stamped it with the car's serial number.
    This makes sense because N357404 is correct for a Detroit built 1957 New Yorker.
    This theory is backed up by the very late production date of 4-26-57, by then the original engine could've been in service for 6+ months and have already been damaged.
    As to the CAL meaning, that could be an internal Chrysler designation, I don't know.
    Ultimately, as long as the block is magnafluxed and the bores look good, I think you have a great piece. Really all 1957-58 392ci Hemis are equal from a casting point of view, it's the internals that changed depending on the model/year.
  24. Racingsnake
    Racingsnake
    from So Cal
    Thanks, that does make sense
  25. 73RR
    73RR
    The 'other' clue is that the stamp is not viewed from the front but the rear. I'll guess that someone sat on the block when they were working on the numbers.
    caprockfabshop likes this.
  26. pitco
    pitco
    from ny
    I hope you won't mind too much if this question is in the wrong spot. I am going to look at a 354 hemi truck engine which i would like to build just a little hotter than stock and was wondering what complications the truck engine may cause. I know the water jackets are not the same but not sure what this means as far as parts or general tech. Thanks This is all new to me.
  27. George
    George
    Go to "Hemi Tech Index", the main page. Mostly similar to the 331 car hemis
