Hot Rods Pulling the trigger on this one today. What Am I In For.
Discussion in 'The Hokey Ass Message Board' started by keith27T, Aug 10, 2019.
  1. keith27T
    keith27T
    Going to pick up today and will post more pics after.
    swade41, nunattax, BigO and 4 others like this.
  2. low budget
    low budget
    from Central Ky
  3. HOTRODPRIMER
    HOTRODPRIMER
    Looks like a '38 Chevy, they make nice drivers.
    A friend of mine had a '37 and it road great. HRP
    keith27T and mgtstumpy like this.
  4. 2935ford
    2935ford
    You're in for a lot of fun! :)
    6inarow, Truck64, kiwijeff and 3 others like this.
  5. oldiron 440
    oldiron 440
  6. RICH B
    RICH B
    Hey; it has to be good, it's a 10; even says so.
  7. tubman
    tubman
    If it is a Master and has "knee-action" front suspension, it's probably worn out. As far as I know parts for these are almost imposible to find. When I was in college in the early '60's, a friend of mine had a real nice '38 Master coupe. The knee action front suspension was shot and he couldn't find parts even back then. I spent almost an entire summer with him removing the entire front suspension and replacing it with a straight axle from a Standard. It was held on by lots of rivets, and all we had were hammers and cold chisels. Lots of fun, but it turned out well.
    Seriously, check the front suspension to see what it is; a lot of them were replaced.
    Torkwrench and chryslerfan55 like this.
  8. maplefrm
    maplefrm
    from Central IL
    I would say you are in for thousands of dollars and 100's of hours. Enjoy.
  9. Jalopy Joker
    Jalopy Joker
    you have taken the first step - one day you will have a fine ride to step into and go cruising
    kiwijeff and keith27T like this.
  10. keith27T
    keith27T
    It’s original.knee action [emoji33]
  11. chargin03
    chargin03
    Many men, many hours ,many dollars.
  12. Blue One
    Blue One
    from Alberta
    Every old car I’ve ever owned has been a lot of work and a lot of fun and a money pit at the same time.
    If you’ve been around the hobby for any time at all then you should know just what you’re in for.
    HunterYJ, Budget36, King ford and 4 others like this.
  13. jetnow1
    jetnow1
    from CT
    If you are anything like me your better half is asking you bought what?
    COCONUTS, Truck64, Budget36 and 3 others like this.
  14. BuckeyeBuicks
    BuckeyeBuicks
    from ohio
    You are in for a LOT of work, spending at least two times more money than you think is possible, and more fun than a box of comic books when it is on the road. Looks like a great project, good luck with your build!
    HunterYJ, belair and keith27T like this.
  15. harley jim
    harley jim
    Your in for what you make it. It a lot of work and can get expensive if you get in a hurry. Look around find the deals ask for lots of opinions but build the car you dream of. I would not ever be without some form of a project vehicle or 2 or 4 or 5.
    Jetnow1 my problem is my wife will bring home more than I can finish.
    Sent from my smart*** phone when it wants toThe H.A.M.B. mobile app
    keith27T likes this.
  16. Mike VV
    Mike VV
    from SoCal
    Don't be "pulling any triggers" on your new car already..!
    It leaves you with a lot of holes to fill and or parts replacement..!
    Pulling the trigger !?!
    Mike
  17. keith27T
    keith27T
    It’s new home for a few days.[​IMG]
  18. belair
    belair
    My dad said those knee action front ends were problematic with just a few years on them. If you went over a rise at speed and unloaded the front end, it would go over center and stay there until you jacked it up got them back in position. I would seriously consider a straight axle from the "lesser" Chevy model.
  19. fordflambe
    fordflambe
    Early Chevys are a little harder to find parts for but yours looks pretty solid. By the time this car was manufactured most of the wood was gone out of the inside. I like to see early Chevrolets come back to life just because there are fewer of them still around than Fords (I like em' all though). It looks like a great start!
    nunattax and keith27T like this.
  20. Bill Rinaldi
    Bill Rinaldi
    I like your 38 and it appears to be pretty solid. It's a bad name around here, but a Mustang II is a great option for your front suspension. Heitzs, Fat Mans, even Ch***is Engineering (now Heitz), has good swaps for the knee action front end. Ch***is Engineering (Heitzs) has what you need for a rear end swap, as well as a few others. The engine swaps are endless---- GO FOR IT !!!!!!! Bill
  21. winduptoy
    winduptoy
    Master 85; parallel spring, straight axle
    Master Deluxe; Dubonnet knee action shock
    Hnstray likes this.
  22. TagMan
    TagMan
    The Dubonnet ("knee action) shocks worked well, but garnered a bad reputation as they usually weren't maintained properly, oil wasn't replenished and things wore out and / or broke. Other bad thing was they were ungodly heavy abd looked kind of......well, ugly!
    Saying that, I had the knee action shocks on my '37 Sports Coupe and wound up machining them to accept a modern lip seal. Ran well, with a MUCH better ride that the straight axle on my '37 Town Sedan. Put many thousands of miles on the coupe, driving all over the country over the course of 30-years. I just sold it and regretted doing so as the truck drove down the street taking it to California.......:(
    winduptoy and keith27T like this.
  23. 34Larry
    34Larry
    I'd say a lot of fun, some frustration, a lot of hard and not so hard work and spending more $$$$$$$$
    than planned. That's okay though if that is what you want.
  24. I installed a M11 crossmember kit in the 38 sedan I owned years back; was built by a company in BC, just can't remember the name right now. Kept the original leafs in the rear, just new shackles, bushing and liner. Rear end is offset from the center pin in the leafs. Long engine bay for later engine fit.
    Looks pretty solid; it will be a good project.
    kiwijeff, keith27T and dirty old man like this.
  25. partsdawg
    partsdawg
    from Minnesota
    Pain,frustration,aggravation and a lot of happy memories
    winduptoy and kiwijeff like this.
  26. rusty1
    rusty1
    ...a lot of these guys are wrong, you can build an enjoyable ride out of that car economically if you really want to;..build it like this one I had years ago;...for about $3000 or less, drove it everywhere...lot's of fun per dollar.
  27. keith27T
    keith27T
    ferus88 likes this.
  28. keith27T
    keith27T
    thumbnail_IMG_2513.jpg Getting transfer papers and the reggie done today.
    Changed the flat tire, on the rear with a new tire 650 16. Popped the drum, brakes looked good as well as the drum.
    Here's a pic of the other side.
    swade41, MO_JUNK, kiwijeff and 2 others like this.
  29. choptop40
    choptop40
    had a coupe 30 years back. the crease on the side is the Diamond Crown Speedline...beat wishes on the build..You can still build it for little money if you buy a running driving pre computer doner car..Heck take the wiring harness too!!!
    keith27T and Algoma56 like this.
