Technical Need advice on rear brakes on Model a
Discussion in 'Traditional Hot Rods' started by Olav 67 Norway, Aug 11, 2019.
  1. Olav 67 Norway
    Olav 67 Norway
    Hey guys .
    I need some advice on what brakes are easy to put on the stock rear axle on my 1931 Model a coupe .
    I got 42-48 spindles to use up front , also have 1956 F100 brakes .
    So what is the normal to use on the rear ?
    Thanks in advance :)
  2. IRION29
    IRION29
    from Alberta
    I'm guessing you have mechanical brakes on the rear? I would go with '39 & later hydraulics.What brakes are you using on the front ? master cyl. ?Is the car plumbed for hyd.brakes?
  3. Olav 67 Norway
    Olav 67 Norway
    Now it has the stock mechanical brakes .
    Will the 39& later rear brakes bolt to the rear axle ?
    How is the emergency brakes on the 39& later ?
    I dont have a master cyl yet , is there an adapter to use the stock pedal ?
    I am trying to keep it old style .
  4. IRION29
    IRION29
    from Alberta
    On a '37 sedan We did a few years ago The shop obtained a conversion kit from Richard Lacy. The m/c was a two compartment unit from '39 & later Ford.The E-brake is cable operated. I don't know if the '39 backing plates will fit the Model A diff. I'm sure someone on here knows. Richard Lacy can be reached online: earlyv8garage.net or (626)338-2282
  5. 39 - 48 backing plates bolt right on the Mode A axle. When installed as stock with wheel cyl on top you will have contact with the A spring perch. Some cut to get rid of contact. Myself I change backing plates side to side and turn 180* and mount it with wheel cyl. on the bottom. Then the E-Brake cable comes out facing forward as it should only on the top of baking plate. Some will call B.S. but it works and the brakes don't have a clue things are on up side down. Make sure you put the front shoe on the front side and the rear shoe on the rear and you'll be just fine. You may need to add a shim on the tapper of the axle to keep the drum form dragging on the backing plate but several Model A parts suppliers have them in stock. It's not a big deal.
    rwrj, ydopen and irishsteve like this.
  6. ydopen
    ydopen
  7. missysdad1
    missysdad1
    Don't forget that you'll need to turn the wheel cylinders over so that the bleeder is at the top, otherwise you'll not be able to bleed them properly. This is most easily done by enlarging the center hole upward until the wheel cylinder bolt holes line up with the existing backing plate holes with the wheel cylinder inverted. This can be done with a die grinder.
  8. Several ways to get it done. I believe in K.I.S.S. Here is the backing plate mounted wrong according to some. Trust me, the car don't know it.
    7-3-09 002.jpg Stock A pedals and the 39-48 master mounted. Look close and you'll see I change it just a bit.
    31 C-Dan; 002.jpg Home made bell crank to make things work.
    Master Cyl mounted 006.jpg Now notice the Master has spacers between it and crossmember. That's so I can get to the cap with the body on the ch***is. Also notice where the brake lines go on the rear end. It isn't Rocket Science.
    Frame 002.jpg Buy a Kit? You don't need no stinking Kit.
    don colaps, rwrj, tb33anda3rd and 2 others like this.
  9. I know it sounds like I don't know what I'm doing but I can tell you I don't do all that and things are just fine. Just be sure you have front puck facing forward. This ch***is has been together about 15 years now and the brakes just keep doing there job.
    tb33anda3rd and firstinsteele like this.
  10. missysdad1
    missysdad1
    I'm always willing to learn. So how do you bleed the rear brakes when the bleeder is on the bottom?
    Pist-n-Broke likes this.
  11. manyolcars
    manyolcars
    Stay away from ****py Lockheed brakes and use Bendix and self adjusters
  12. I did it just as if the bleeder was at the top. So my wild guess as to why it works is that the master will move more fluid than the bleeder can let out and will purge the wheel cyl. with fluid causing the air that is less dense than the fluid looking for a place to go. With the dense fluid squeezing and pushing the air it follows the fluid movement and ends up coming out the bleeder hole. Now that's an uneducated guess and for sure not scientific at all but all I can come up with as to why it works and I end up with a good solid pedal. If I had only done this once I would say just plain dumb luck but I have done this system 4 times for myself and twice for friends. Each time it ends up the same. How can that be?
    rwrj and Texas Webb like this.
  13. Texas Webb
    Texas Webb
    Sounds like creative mechanics....Good job and pics,thanks.
  14. missysdad1
    missysdad1
    Here's how I did mine.
  15. As long as the bleeder is at the top of the bottom air will rise to it.If the bleeder was at the bottom of its new location air could get trapped.
