Projects And So It Begins
Discussion in 'Traditional Hot Rods' started by Piewagn, Jul 14, 2019.
  1. 40FORDPU
    40FORDPU
    Cool project..cool Boss for his generosity/support.
    brEad and Piewagn like this.
  2. koolbeans
    koolbeans
    Looks like a really great beginning....pile of steel, great body, all the rest will bring great fun. Like me I'ma finishing my last build too. (really two..'32 highboy and '62 Falcon track car).
    I chose a short cut for my age (76) and found a body and interior that was close to perfect and my liking. Added a custom perimeter frame, some other goodies and soon will be driving...total build time to now...by the clock...about 51/2 months, calendar time 9 months to now.
    When done the shop gets swept clean. No more temptations....been a great ride IMG_20190812_100500524.jpeg IMG_20190812_111224416.jpeg IMG_20190802_152828980.jpeg IMG_20190802_152956561.jpeg
    Sent from my XT1710-02 using The H.A.M.B. mobile app
  3. Piewagn
    Piewagn
    NICE! I'm at the point now I want to enjoy this build and the all brain exersizing and all the the fun stuff that goes into building one of these.....then I just want to enjoy it and drive the wheels off it!!
  4. Piewagn
    Piewagn
    Yep! he's a grade A dude! He wants to experience something new to him, he is a mechanical engineer. His father and him designed and built the machines at the facility, but he's new to traditional hotrods. He's become like a little kid wringing his hands in anticipation......should be fun!!
  5. koolbeans
    koolbeans
    Do it... HAMB is a good place... just be careful..put together an idea three ring binder and glean all the photos of where you want to land...it's like a coloring book...fun, fun, fun....
  6. Piewagn
    Piewagn
    That coloring book is in my head! I can see each stage, I've envisioned this build for a looooooooong time! "Last Hurrah" Very fitting!
  7. koolbeans
    koolbeans
    Mine was too. Age has killed my noggin hard drive (soft drive). But the internet/Pinterest, HAMB etc. offer today an enormous wealth of alternatives and photos of how others have executed each event. Great to compare and review.
    I coined Last Hurrah Garage because of this closing chapter. Done up some caps and t shirts. Doin some tag toppers now. Friend has done a video do***entary not yet done..but can see some on YouTube.
    Greatest language and social fun...building hot rods...
  8. Piewagn
    Piewagn
    This place has been a treasure trove of info, knowledge and experience.....to me, it's priceless!!
  9. Piewagn
    Piewagn
    Ya think I can fit some things in here?? Along with a 75hp compressor that runs all the machine drives and air blasts, this thing could practically strip a battleship! [emoji23][emoji23]
  10. Piewagn
    Piewagn
    Why on earth would someone put all these holes in the firewall??
    nunattax, chryslerfan55 and koolbeans like this.
  11. koolbeans
    koolbeans
    It'd be kool to know each ones history. Makes for good lore.
    chryslerfan55 and Piewagn like this.
  12. Piewagn
    Piewagn
    I thought the EXACT same thing while I was taking that photo! The other side isn't much better. It's like every time they needed to run a wire up there "well, time to drill another hole". I think one p*** through would have sufficed. :confused:
    catdad49 and chryslerfan55 like this.
  13. Atwater Mike
    Atwater Mike
    Piewagn likes this.
  14. Atwater Mike
    Atwater Mike
    Envious of that subframe, seriously. You should have seen the last 4 or 5 I had to 'revamp'...
    'Ghastly' is the word.
    There's a HAMB build going on right now, [Buying an ole can o' beans] HAMBer Austin is doing ******'s ex Model A sedan. His bud Tim has supplied and trimmed down a Ford F6 truck center cross member to fit. Nice material piece. Check it out.
    Center cross member is the main spine of a Model A frame...if '32s are most preferable, F-1 thru F-6 is secondary only to those...F1s being the best choice, because of 'compact' size.
  15. Piewagn
    Piewagn
    That's what I'm looking for right now......the crossmember. I just scored 4 wide 5's and 2 drums, a flathead radiator and an F-1 steering column/box with the column shift for the trans I have! I have seen those builds......I'm getting excited!!!!
  16. Piewagn
    Piewagn
    Got this little goodie in the mail!!!
  17. Piewagn
    Piewagn
  18. Atwater Mike
    Atwater Mike
    That last pic of the right side body makes me want to pull it out of the monitor and start on it...aside from the lower rust, it's SO straight!
    Totally 'm***ageable'...
  19. Piewagn
    Piewagn
    The other side is even better!! For the most part, it's straight and solid!!
  20. Piewagn
    Piewagn
    I’m transporting the quarters home one at a time so I can utilize time better. Work on The subframe at work during the week, then get panel repairs done at home on the weekends. I’ve found my front wide 5 drums, so now I have a complete set of wheels and drums! Located a front drop axle, my pedal ***embly came, there’s a ‘36 dash in the works right now. Things are coming together! Now I just need the frame member. I can make my own, I have all the material I need. If I can’t score the k or x member at a reasonable price, I’ll just go the “from scratch” route. Geezus, the last k member I saw they wanted almost a thousand friggin’ bucks!!! Well, I’ll be shoutin’ at yoos all soon, enjoy!!!
    OFT, catdad49, chryslerfan55 and 2 others like this.
  21. Piewagn
    Piewagn
    Hey Cliff! I scored an F-1 column with steering box WITH COLUMN SHIFT!!!! Yes!! Has all the linkage too!! I’m goin with your idea and freeing up all that floor space!!
    Cliff Ramsdell, nunattax, OFT and 2 others like this.
  22. Piewagn
    Piewagn
    Well, I’m headed up to North Jersey tomorrow to pick up some goodies! A set pf wide 5 wheels, drums and the F-1 column shift column I mentioned earlier. Headed on vacation next week and when I get back, it’s time to hit this hard!! Thanks for all the encouragement fellas!!!
  23. Piewagn
    Piewagn
    Well, first actual “work”! I’m diggin’ in to this quarter. I’m trying to distinguish where the tabs for the subframe are, some rust repair and general cleanup.....[​IMG]
  24. topher5150
    topher5150
    But first you need to fix the valve covers:D
  25. Piewagn
    Piewagn
    Nope.....not gonna!!
  26. Piewagn
    Piewagn
    Just the small tedious stuff..... all the little stress cracks and screw holes....ya gotta just wonder... IMG_0001.JPG
    Now where did I put my flanging tool....[emoji848]
  27. Piewagn
    Piewagn
    Calling it quits for the night....gotta head up to North Jersey to pick up some more goodies! Hey, at least I can say I’ve officially started! Thanks fellas!!!
  28. Piewagn
    Piewagn
    Just got back from a road trip and met a fellow HAMBer that sold me a BUNCH of goodies!!! It’s playtime!! 58776359191__68F1EA0E-0B23-4188-8D00-8E6B44CBA589.JPG
  29. Piewagn
    Piewagn
    Tim, Cliff Ramsdell, mctim64 and 2 others like this.
  30. Piewagn
    Piewagn
    Geezus! I always have to pause and look at your avatar! What a mix....gap and a Holley! :D
