Projects Dodge This - 1939 Dodge Southeast Gasser Build
Discussion in 'Traditional Hot Rods' started by Dog_Patch, Aug 12, 2014.
  1. How about a msd mag? the control box has a place for a chip and they work. A 12 amp mag should work fine.
    Oldioron, enloe, Dog_Patch and 3 others like this.
  2. Dog_Patch
    Dog_Patch
    Yeah I remember that morning. We're going back to that track in October - I hate the gr*** on the edge of the blacktop there. I need to stay with 392/354 based stuff because of the investment in heads and rockers and intakes etc.
    Hmmmm never even looked into an MSD mag good point.
    chryslerfan55, loudbang and enloe like this.
  3. i think you have exceeded the limits of your steel rods. I have a couple sets that have some unusual angles to them hanging on the wall. it took a few times but I learned. if you are determined to stay with steel rods I would invest in some higher quality replacements designed for your application. if your crank took a hit it the rods could be ordered with a chevy 2.20 rod size. the added benefit to that setup is cheaper bearings with more selection. the msd mag will need to use msd super conductor wires. it will also need ground wires running from the box to each head. good vibrations sells the fie kill switch. don't buy the cheap one they fall apart. get the higher quality unit the first time. these mags are so hot you might have to retard the timing a few degrees. they don't work with a buzz box. a timing light must be used. msd sells a good light that is very bright.
  4. Dog_Patch
    Dog_Patch
    Well seems that the crew chief found my folding money ......
    In any case we seem to be ready for Saturday
    B8FB22A8-B322-4DE0-9E30-6B3B01BA915D.jpeg 4EAE235E-72D9-44DB-811B-F1CDC23BEFE0.jpeg 0E74D4A1-1384-48FF-B653-E9FE340CDB64.jpeg 0615C906-2BC9-4D29-8E6F-313FF82B42AC.jpeg 6EB6597B-E833-43A4-AFDA-4F4FB34B7DDE.jpeg 08F355B9-1F1C-4243-A9E8-307588BA21D3.jpeg
  5. Dog_Patch
    Dog_Patch
    Also - The G***er Gang is having a band play on Friday night after or during Test N Tune - should be a good time!
  6. Dog_Patch
    Dog_Patch
  7. 427 sleeper
    427 sleeper
  8. Scott Mize
    Scott Mize
  9. Dog_Patch
    Dog_Patch
    Thanks Scott! Car ran good last night - rev limiter works! Should be a fun day.
    Fiddle Picker, enloe and loudbang like this.
  10. Dog_Patch
    Dog_Patch
  11. chopnchaneled
    chopnchaneled
    from Buford Ga.
    Well, ?????????
    Dog_Patch and loudbang like this.
  12. Dog_Patch
    Dog_Patch
    4D66AACE-7B51-48E1-BDC3-4BFC4E756508.jpeg 8B78E806-4BD2-4C10-AE3D-2F9D5B89DE61.jpeg E52F86CD-584D-491A-A1C2-1E71FF5DE8A2.jpeg 85ED0D1F-C5E5-4E74-9F00-85CD9A1DAD2F.jpeg E047723C-B610-4183-B0E7-87984B211C6C.jpeg FE05FE29-0FB1-4EAA-93F1-7BBD2316ECF4.jpeg 13AE53BB-94D2-4AC2-863B-2482C971965D.jpeg F7697C9E-DB77-403A-BF04-91EE24469DDF.jpeg AD931CA4-3414-4FC1-9004-3B39F591335D.jpeg DBA42B9C-9E2A-4E6D-8F79-72B39744D11C.jpeg 24689736-B73F-4D8B-AF2B-3E55DE7D8CDE.jpeg DB919284-7BCE-4391-9A50-2F159B05419F.jpeg
    Was a good low adrenaline weekend. With the msd set on 8k it ran like a bracket car 6 flat all the time. Didn’t break anything so now I’m bored. Got to work on the front ladder bar lowering- it won’t wheelie anymore even with the 4.86 gear. Nice 60 foot with those 1.28
  13. Dog_Patch
    Dog_Patch
    It’s 2668 lbs also and I’m allowed 2368
  14. Dog_Patch
    Dog_Patch
    Check this out Tim used an 8mm camera to shoot the race
  15. 427 sleeper
    427 sleeper
    Now THAT'S just plain BAD ***!!! [emoji869][emoji41]
    TOO FREAKIN' COOL!!!
  16. loudbang
    Wow looks like he found a "WayBack Machine"
  17. Dog_Patch
    Dog_Patch
  18. DDDenny
    Tony, the car looks great but I really liked how Q&D looked in earlier times.
    I guess you'll be going through a lot more Mothers polish keeping those Halibrands up.
  19. dirty old man
    dirty old man
    Tony, I dunno if it will work on magnesium like it does on aluminum, but I polished the American Racing wheels in aluminum that I mounted my slicks on for when I drag BGII, and then oiled them down with a couple applications of Gibbs oil. It does seem to retard the tarnishing a good bit.
    Initially it has a very slight dulling effect on the shine, but it takes several months to even tarnish a little bit.
  20. Dog_Patch
    Dog_Patch
    Now we’re just playing
  21. Dog_Patch
    Dog_Patch
  22. Dog_Patch
    Dog_Patch
  23. loudbang
  24. wrench9
    wrench9
    from Canada
    If you are running 6 flat what is the top car or cars running for times in your cl***.
  25. Dog_Patch
    Dog_Patch
    The 2 corvettes run 5.40 one of them did 131mph at the Alabama track. My car is 300 heavy which would make it a 5.70 car. Theoretically.
  26. catdad49
    catdad49
    Tony, who's the guy with cowboy hat and boots? Been missing your posts, but I will catch up!
    chryslerfan55, Dog_Patch and loudbang like this.
  27. Dog_Patch
    Dog_Patch
  28. Dog_Patch
    Dog_Patch
    That's my buddy and fellow club member Tim @3dnsouth he has saved my *** from tight spots so many times, I can't remember them all. He's building a SEG car also.
  29. loudbang
  30. chopnchaneled
    chopnchaneled
    from Buford Ga.
    Th
    Think i like this side more better
