Projects fixing a smashed 31 model A pickup cab.
Discussion in 'The Hokey Ass Message Board' started by tb33anda3rd, Mar 17, 2019.
  1. tb33anda3rd
    tb33anda3rd
  2. 1953naegle
    1953naegle
    Love this thread! Stuff like this just reenforces my pigheaded ideals that ANY cl***ic is worth saving. The s**** pile you turn your nose up at today is the project you're left with tomorrow.
    And incorporating the oak tree is legendary.
  3. nrgwizard
    nrgwizard
    from Minn. uSA
    Kudos... , you are good!.
    Marcus...
  4. nunattax
    nunattax
    coming together nicely
  5. Dan in Pasadena
    Dan in Pasadena
    I don't remotely have the skills it would take to do something like this. I'd have likely been the meathead going at it with a ball peen hammer! (Kidding!) But I really enjoy seeing how something like this is done.
    I like the door graphics being saved too. Can't wait to see the rest of it come together. Thanks for the informative posts.
    Stogy, osage orange, loudbang and 2 others like this.
  6. Nice work fellas!
  7. tb33anda3rd
    tb33anda3rd
    thanks for all the compliments. it is fun.
  8. brEad
    brEad
    You guys do really nice work! Thanks for sharing all of the steps you’re going through on this project.
  9. tb33anda3rd
    tb33anda3rd
    Today me and Charlie fixed the front mounts. I started by removing the angled toe board braces. I then removed the rivets holding the inner brace, then cut out the rotted section. the front mount has a lot of different angles and bends so I needed to make it out of three pieces. here is a photo of the first piece. IMG_6675.JPG IMG_6676.JPG IMG_6677.JPG
  10. tb33anda3rd
    tb33anda3rd
    I bolted and welded the piece in and cleaned up the welds. IMG_6678.JPG IMG_6679.JPG
  11. tb33anda3rd
    tb33anda3rd
    I used a piece of card board to make a template of the top plate piece that ran up the side. cut out the metal and welded it in. IMG_6680.JPG
    brad2v, Shadow Creek, Stogy and 9 others like this.
  12. tb33anda3rd
    tb33anda3rd
    I then put what was left of the inner brace back in and made a new lower piece and bolted and welded it in. IMG_6684.JPG
    Runnin shine, MP&C, brad2v and 11 others like this.
  13. tb33anda3rd
    tb33anda3rd
    the driver side was not as bad so I just bent the inner support up and cut out the rotted area. I then made the two pieces the same way. IMG_6682.JPG
    MP&C, brad2v, Stogy and 9 others like this.
  14. tb33anda3rd
    tb33anda3rd
    while I was doing that Charlie was bead blasting the toe boards and made a pan for under the seat. we then coated all the mating surfaces with the "weld through" primer and welded them in. IMG_6685.JPG
    MP&C, LOWDUG37, brad2v and 15 others like this.
  15. Bugguts
    Bugguts
    Well done. I’m impressed with your thought out repair plan and it shows in the way the cab is coming together. Too many have the ball peen hammer mentality, without thinking about the next step. Good teaching.
    brad2v, osage orange, dwollam and 3 others like this.
  16. TFoch
    TFoch
    Looking good Ted. Looking forward to the chop!
    loudbang and tb33anda3rd like this.
  17. ct1932ford
    ct1932ford
    Did someone say chop?:cool:
  18. nunattax
    nunattax
    A s look great to me with no chop.[​IMG]
  19. tb33anda3rd
    tb33anda3rd
    Charlie said the same thing when I showed him the photo posted by @Dago 88 "see how good it looks unchopped"
    " it is chopped two and a half inches"
    "that looks good let's chop it like that"
  20. The37Kid
    The37Kid
    Ted, Don't forget to drill the hole for the socket to fit through to attach the nut on the bottom of the cowl band. West Coast Bob
  21. nunattax
    nunattax
    ted no doubt you will do a quality chop job .
  22. tb33anda3rd
    tb33anda3rd
    we have been making some very slow progress. Charlie is working on backing plates and brakes, and he primed and painted a set of 36 wire wheels. I mounted a set of tires he had on them.
    I also had a job to replace a top header piece and filler on a model A truck. so I have a good template and some practice.:) IMG_7738.JPG IMG_7739.JPG IMG_7742.JPG
    MP&C, osage orange, OFT and 14 others like this.
  23. tb33anda3rd
    tb33anda3rd
    I have done nothing with the body, but Charlie has been busy rebuilding, the ******. he has been cleaning the fenders and aprons and making patches for them. the axle and hubs are ready to go. IMG_0337.jpg IMG_0336.jpg IMG_0338.jpg
    Runnin shine, MP&C, brEad and 7 others like this.
  24. tb33anda3rd
    tb33anda3rd
  25. tb33anda3rd
    tb33anda3rd
    Charlie has the front and rear ends ready to on this ch***is, and is wrapping up the final details on the brakes.
    I tested the wood with the moister meter, the ends are drier than the centers. IMG_9505.JPG IMG_9506.JPG
    chryslerfan55, MP&C, TFoch and 4 others like this.
  26. tb33anda3rd
    tb33anda3rd
    I started prepping the chunks I cut to repair the top header. roughed them out with a hand planer and my skill saw. IMG_9508.JPG IMG_9510.JPG IMG_9509.JPG
    chryslerfan55, MP&C, TFoch and 9 others like this.
  27. kidcampbell71
    kidcampbell71
    .. kinda' funny .. & dunno' the ifs or why nots. Had a Mexican guy whose father built boats & wood repair on old vehicles, before my time.
    Measuring moisture in a flood damaged home .. using driers, desiccants, mold removal sprays & ozone generators .. .. I had moisture creeping within the structure. Here one day .. there the other.
    In p***ing, he said .. "too bad we can't soak this ****er in motor oil".
    ????? ( !!! ) o_O
    He claimed his dad would steam fit & dry the fitted stringers in place or whatever .. & thereafter soak them in oil to seal the "end grains".
    I'm thinking a linseed of sorts. I can't imagine motor oil .. but hell who knows ? I've been surprised by Mexican tech' before.
    Example :
    every time somebody would get sick - tequila. Thinking bullsh*t on that forever .. & then an I'll be damned moment .. what alcohol lowers your blood sugar ? Yep .. tequila. By itself .. no margaritas .. & no bazillion shots. Say 1 or 2.
    Dunno' if it cures sickness .. but if heretofor diabetic --> BINGO. Tequila.
    chryslerfan55, MP&C, brad2v and 3 others like this.
  28. tb33anda3rd
    tb33anda3rd
    I had a neighbor who finished the furniture in his house using used engine oil. it looked great and did not smell that I noticed. I have seen junk yard trucks that delivered parts/engines/ ******s etc.. the beds would be an oily mess but the wood didn't rot.
    moving the Tequila bottle to the medicine chest...
  29. tb33anda3rd
    tb33anda3rd
    got the wood cut down to size, then traced out the shape and cut it on the bandsaw. used the belt sander to get it to the final shape. I also made the end filler pieces but didn't take any photos of the process. IMG_9518.JPG IMG_9519 2.JPG IMG_9519.JPG IMG_9520.JPG IMG_9521.JPG
  30. adam401
    adam401
    Fighting the good fight to save that truck. Great job! You do some nice work both in wood and steel.
    Stogy, brad2v, nunattax and 1 other person like this.
