Art & Inspiration Cool Vintage Radiator Caps
Discussion in 'The Hokey Ass Message Board' started by Stogy, Apr 6, 2018.
  1. Stogy
    Stogy
    Still Graceful
    Credit to Photographer, Owner
    kiwijeff and biggeorge like this.
  2. fleetside66
    fleetside66
    A late '20's "Floating Spirit" (missing the lower articulated jaw) & a '60's Cal Custom.
    kiwijeff, biggeorge and Stogy like this.
  3. Stogy
    Stogy
    The vintage Skull helps understand the movement and its relation to skulls and other macabre things catering to certain m***es of the population...Hoodlums...:D...What is it bolted to, a dashplate?
    Maybe someone can cast you a lower jaw
    even the Call Custom is neat...are the fins supposed to sit the same orientation as the Rocker covers?
    Thanks for sharing...;)
  4. Michael Ottavi
    Michael Ottavi
    Been looking for this photo..... She always says I'm going to blow off. DSCN0913.JPG
  5. Last edited: Jul 3, 2019
  6. Ned Ludd
    Ned Ludd
    Page 6 and no Voisin "Cocotte"?
    Jet96, kiwijeff, dana barlow and 2 others like this.
  7. ^^^^ Not bad for something made from s**** :cool: close to 100 years ago. ^^^^
    Stogy and Ned Ludd like this.
  8. fleetside66
    fleetside66
    Yeah, I just had her bolted to that plate, because she was tired of lying down. I think that plate is actually one of those old smoking stands that they made in the shape of playing cards. This one is a club. I bought it as a possible gauge panel conversion, but never got around to it. I always pictured the bottom hole with the steering column p***ing trough. The "radiator mascot" is from the Franklin Die Cast Co. (Chicago) , produced in the 20's & 30's. Franklin is considered to be the father of die casting in the U.S. & went on to form the Franklin Automobile Company. It was stock #129 in their original catalog, called "The Floating Spirit." Years ago, some guy used mine as a form to do a high quality reproduction & promised me a jaw for my troubles. He never came trough, but I do remember seeing the finished product & it was spectacular (and expensive). The jaw was designed to move in the wind while driving & the piece got the nickname of "Yappy," from what I've read.
    And, yes, I do believe the fins on the Cal Custom were intended to be oriented to the direction of the valve cover fins. Here it is on my car, not exactly parallel, but it can be tweaked with set screws. I never used it, because I thought it looks a tad awkward in my situation.
    Speed~On and Stogy like this.
  9. BigO
    BigO
  10. Stogy
    Stogy
    Thanks for expanding on the history...it would be cool to try and and find connected imagery as in patent and catalog. To bad about the jaw...I can imagine how rare that actually is.
    Your shells filled...mine has a no useable fixed cap (repop) with the filler behind the shell much like your setup Fleetside.
  11. Stogy
    Stogy
    Yes that was on that Wild looking Sedan at the Dirtdrags...and of course Hamber @Dan Greenberg's talented capture.
    Lots of Aviation inspired Caps back in the day.
    That had moving details which was quite common on many of these Mascots back when the Elegant Metal Rolled On Down the Highway.​
    BigO and biggeorge like this.
  12. Stogy
    Stogy
    If the Ole MotoMeter isn't working right this might fix it...
    @Bandit Billy heres something you can try next time your at the links...:D
    kiwijeff and Bandit Billy like this.
  13. Stogy
    Stogy
    kiwijeff, dana barlow and egads like this.
  14. Bandit Billy
    Bandit Billy
    I haven't teed one up off the hood but I did tee off my tail gate of "parts getter II" one day at cape horn in the Columbia river gorge (Washington side). Had to stand on the gate to clear the guard rail. Talk about elevated tee box
    Thanks for thinking of me!
  15. Stogy
    Stogy
  16. Stogy
    Stogy
  17. Stogy
    Stogy
    Just evidence that Hotrods sported these even though many shells were filled...
    kiwijeff likes this.
  18. Stogy
    Stogy
    kiwijeff, BigO and biggeorge like this.
  19. Stogy
    Stogy
    I think that might be the Mighty Ram leaping forward on this no doubt 31 Chrysler based Racer...just another observation is that front axle...looks as if it may be solidly mounted...
    Update...It is not a Ram, it is a Gazelle...
  20. Stogy
    Stogy
    This is a Hamber's ride I just can't recall whose...:eek:
    kiwijeff, dana barlow and BigO like this.
  21. Stogy
    Stogy
    kiwijeff, dana barlow and biggeorge like this.
  22. Stogy
    Stogy
  23. Stogy
    Stogy
    :rolleyes:...looks to be a Winged Moto Meter Capping this Radiator on this uniquely styled Hotrod.
    kiwijeff and dana barlow like this.
  24. Stogy
    Stogy
  25. Stogy
    Stogy
  26. Stogy
    Stogy
    Caps are part of the OEM and Aftermarket Offerings but when they are on a Hotrod it just has a better resonance to the connection...
    :rolleyes:...One of Hamber @AldridgeDW captures from a very recent very period attended Swindlers Poker Run...a fine day indeed...and a Fine Hotrod...
    Just an interesting eye play going on here with the siding making the top of the pic look crooked...
  27. Stogy
    Stogy
    kiwijeff, BigO and 31Dodger like this.
  28. Stogy
    Stogy
    :rolleyes:...Another cool pic from Hamber @carsick's Collection
    Man From Uncle Maybe?...
  29. Stogy
    Stogy
    kiwijeff and BigO like this.
