1952-59 Ford Push Rod Delema
Discussion in 'Off Topic Hot Rods & Customs' started by 55newbie, Aug 11, 2019.
  1. 55newbie
    55newbie
    from Ohio
    Ok Guys, I've been following the stickies really close on putting a SBF in my 55 Fairlane. I have a 91-95 Mustang short block (F1SE BB). I thought I bought heads from a guy that were 302 heads, however checking the stamping, ( DO0E) it appears they are 351 heads. I bought push rods for the block and they are too short. Any idea what push rods I need?
  2. 55newbie
    55newbie
    from Ohio
    7E33EBEB-15FF-48C2-A0DA-20A08F67BDFE.jpeg 10609E56-A7DB-43E6-B0D3-B014582F09F2.jpeg
  3. There are alot of variables, you need to measure.
  4. JeffB2
    JeffB2
    from Phoenix,AZ
    I think you would be better off selling them,the 351W head also uses 1/2" head bolts your 302 uses 7/16" which means you will need either the ARP step down bolts or the tapered head bolt bushings https://www.summitracing.com/parts/sdm-pce277-1001 Also these heads do not have adjustable rocker arms as they use the rail type rockers and your 302/5.0 is a roller cam motor which means you need to also upgrade the springs to match and the cam you choose will also govern the push rods you will need so you will end up needing this to get the correct length: https://www.summitracing.com/parts/cca-7702-1/overview/ By the time you upgrade the DO0E's you could almost by a set of aluminum heads that will far out perform the DO0E's and have the right springs for your roller cam. https://www.ebay.com/itm/2-SBF-FLO-...152134?hash=item23bab30e46:g:flkAAMXQltxQ7YGw If you are sticking with the stock pistons this is the largest intake valve that will clear unless you change pistons to newer ones with larger valve reliefs.
  5. DIYGUY
    DIYGUY
    from West, TX
    JeffB2 likes this.
  6. 55newbie
    55newbie
    from Ohio
    the thing that doesnt make sense, is the pic of the head with the 302 stamping with the 69 below it. Clearly a 302. But the other stamping of DO0E which I found to be a 351. It cant be both
  7. 55newbie
    55newbie
    from Ohio
    The motor is fresh short block bored .30, new pistons, rings and bearings. There is no camshaft in it yet. I did purchase the push rod measuring tool as suggested.
  8. DIYGUY
    DIYGUY
    from West, TX
    D0OE-B is a 302 head
    D0OE-C and -G are 351 heads
    This is from small block Ford book by George Reid
    JeffB2 likes this.
  9. 55newbie
    55newbie
    from Ohio
    That’s a big help!! I really appreciate it
  10. fordsbyjay
    fordsbyjay
    from Lafayette
    Have you tried push
    rods for a 70 302? The block height is the same so the difference is going to be in the head casting. The best way is to use a pushrod checking tool but not everyone has one or knows how to use them.
  11. mnfordfan
    mnfordfan
    The head castings are the same other than the head bolts holes on a 351. The push rod differences are due to the rocker configuration, the older motors used cast iron rail rockers the "rail": keeps the rocker centered on the valve tip, with a stud mount rocker, and a positive stop shoulder. If you had no valve in place the rocker could pivot in all direction
    https://www.rockauto.com/en/moreinf...AH2n1HRz7GoKCHq8VOUGEAaBvtPMqCLzE7j7G5wAH1VcM
    The newer engines use the bold down stamped steel rockers, they have bolts and a fulcrum that only allows the rocker to move up and down. pictured here
    These differences are what makes the push rods different.
    Are you using a flat tappet hydraulic cam? If so the 70 model push rods with the first cast iron rail rockers will work.
    JeffB2 likes this.
  12. 55newbie
    55newbie
    from Ohio
    I am using a flat tappet hydraulic cam
  13. Fairlane 62
    Fairlane 62
    Also the 5.0 roller cam uses shorter push rod than the flat tappet as the roller lifters are taller.
