Technical What should I cast?
Discussion in 'The Hokey Ass Message Board' started by flathead 37, Jan 2, 2019.
  1. 56Don, I will look into that- thanks!
  2. 41rodderz
    41rodderz
    from Oregon
    I will have to go back and check but his has Marshall "raised cast" and website shows valve cover spacer available and pic of valve cover not available.
  3. CNC-Dude
    CNC-Dude
    It's in the "seeking a foundry" to get cast stage.
  4. roseville carl
    roseville carl
    I started with anything I neeeded but was too cheap to buy, carb adapter, blower idler arms, blower end plate along with plaques and other ****.....
    carb adapter04.jpg Blower Bracket.JPG Blower Idler no 2 mount000.jpg DSC02822.JPG ResizedImage_1418235638580.jpg
    BradinNC and Bandit Billy like this.
  5. flathead 37
    flathead 37
    Well, I finally cast something!
    I needed a hand brake mount for my 1937 ford pickup, and so decided it would be a good casting project. I drew up a design in fusion, 3d printed a pattern, and cast it the next day. I'm pretty happy with the results of my first try at casting. More to be coming soon for sure! 20190716_175947.jpg 20190716_175953.jpg 20190716_224007.jpg
  6. flathead 37
    flathead 37
    I put together a short video of my latest casting. It is a sand rammer for compacting casting sand. Enjoy!
  7. manyolcars
    manyolcars
    Even better make an oval air cleaner that covers all 3 carbs. This gives you a plenum and is not restrictive like those little bitty individual cleaners
  8. catdad49
    catdad49
    Nice, whole bunch Better than a screwdriver! Thanks, Carp.
    lothiandon1940 likes this.
  9. newmagrathea
    newmagrathea
    Did you ever get around to casting the El Toro?
  10. Pat Thompson
    Pat Thompson
    We made propane fueled furnaces out of 1/2 of a 55 gallon barrel. Lined them with fire brick. Ran the fuel line in with air added to it< controlling the air with a ball valve. I still know where one is if pictures were needed or I think it could be bought.
  11. deathrowdave
    deathrowdave
    from NKy
    Man you never know where that was ! I’m sorry I could not help it !
  12. continentaljohn
    continentaljohn
    That’s Awesome thanks for sharing and look forward to seeing future projects. I plan on building a similar setup to yours for my casting ideas.:D
  13. flathead 37
    flathead 37
    Been a while. Here are some of the latest castings. IMG_20201204_142220.jpg IMG_20201231_175512.jpg IMG_20210430_150120.jpg 20210601_094245.jpg
  14. Max Gearhead
    Max Gearhead
    from Wisconsin
  15. Pete1
    Pete1
    from Wa.
    How about a 5 main 8ba block with a 3.5 inch bore, 2 inch cam tunnel and 2 inch valves to be run in a yet to be organized PRO vintage circle track racing ***ociation?
    97 and kidcampbell71 like this.
  16. cfmvw
    cfmvw
    I had the Dave Gingery charcoal foundry furnace, used to make a lot of castings! Built his lathe and ***orted equipment and cool stuff, but you are really knocking it out of the park!
    seb fontana likes this.
  17. F-ONE
    F-ONE
    from Alabama
    I'm, serious...
    A slingshot Y dual 3 bolt intake piece that will bolt to a 4 bolt 1949-53 Mercury Intake. This basically makes a slingshot intake for a 8BA.
