Technical Cheater slicks groove width
Discussion in 'Traditional Hot Rods' started by evobuilder, Aug 18, 2019.
  1. evobuilder
    evobuilder
    I have a new pair of pie crust slicks I am going to groove to make cheater slicks.
    Standard grooving tools come with a #4 blade but I think I need a wider blade..
    Does anyone have a cheater slick they can take a measurement from? Here are the blade sizes for reference...
  2. wuga
    wuga
    My M&Hs measure 3/16
    Warren
    loudbang and evobuilder like this.
  3. chevy57dude
    chevy57dude
    Radirs come in at 3/16" also. 1566138684178-1173072230.jpg
  4. dreracecar
    dreracecar
    from so-cal
    Will the car be entered in the Pebble Beach Concours??? just grove it,, hope its the hot grooving iron type or hit up a USAC Sprint car team to cut it for you with theirs
  5. s55mercury66
    s55mercury66
    from SW Wyoming
    Here is something a little different, from the early '60's. 20190818_154853.jpg 20190818_154648.jpg
    evobuilder, Hightone111 and loudbang like this.
  6. evobuilder
    evobuilder
  7. Stan Back
    Stan Back
    Wonder whatever happened to 8/32? Got 7 and 9 on the chart, 8 must be real strange.
  8. willys36
    willys36
    They left off 3/16" and 1/4".
    I just cut the ones on the old/new Inglewood Pos-A-Tractions for the Mysterion clone with the cutter that came on the tool. Didn't know there were different sizes.
    mgtstumpy, evobuilder and loudbang like this.
  9. evobuilder
    evobuilder
    I just bought a groover with a #4.... did you need to set the depth, hopefully the tool has some sort of intuitive gauge.
  10. evobuilder
    evobuilder
    What was your trick to getting the lines straight? That's my biggest concern. Any help is greatly appreciated.
  11. LM14
    LM14
    from Iowa
    You have to set your depth of cut. Loosen the screws that hold the blade in place and slide the blade up/down for depth and lock your screws back down. Might want to do that before you plug it in :). I would use a #4 blade. Make sure the blade is in with the sharp side facing forward and has plenty of time to get up to cutting heat. Don't rush it. If you have to force it it's either too cold or in backwards. A little corn starch or baby powder spread across the tire's surface will make it cut faster and easier. Use a scribe and score a uniform line around the tread surface off the sidewall/tread edge.
    SPark
    kadillackid, evobuilder and loudbang like this.
  12. dreracecar
    dreracecar
    from so-cal
    Spin the wheel/tire off an axle and a yellow crayon to mark it
    Speedwrench and evobuilder like this.
  13. willys36
    willys36
    I measured and ran a strip of duct tape around the tire. Just followed the edge of the tape for perfect line. cuts fairly slow, easy to control. Seems like it was a few minutes per cut. Not bad.
  14. evobuilder
    evobuilder
    Duct tape is smart.... did it act as a guide? My biggest worry is a crooked groove.
  15. mgtstumpy
    mgtstumpy
  16. willys36
    willys36
    Yep. Just follow the edge of the tape and should have arrow straight groove.
  17. mlagusis
    mlagusis
    I wonder if you keep the tire on the car jacked up a little, then set the grooving iron on the floor fixed to something to keep the iron/grooving tool in the same location. Then rotate the tire on the car. You should get a perfectly straight line. FYI, I have never done this before so just a random thought on how to get a straight groove.
  18. willys36
    willys36
    You are WAY overthinking this. You can do a pro job just taking minimal care. Just do it!!!
    LM14 and evobuilder like this.
  19. dreracecar
    dreracecar
    from so-cal
    Practice practice practice, its not that hard but its not easy either. the pro knife I used was heat adj and easy to control, pressure pushed the contacts into instant heat and backed off cooled the blade. Iron type can be a little woobly without a extra handle at the blade. slow spinning of the tire while bracing yourself yeilds the best results, but practice practice practice
  20. dreracecar
    dreracecar
    from so-cal
    Some truck tire repair/stores have a blade to regroove a marginal tire to get past the police
  21. evobuilder
    evobuilder
    man, if you know of one, let me know. I have exhausted that option in So Cal. Even the race shops will only do tires they are sponsored by/sell due to liability issues. This used to be common, there was even a shop in HB that did my motorcycle slicks in the 90s, but they are long gone.
    With all the race shops around So Cal, I cannot believe it's this hard.
  22. I agree with this ^^^^^something in the neighborhood of 1/8 to 1/4 is going to get you there and it seems like 3/16 is what I normally see them at.
  23. dreracecar
    dreracecar
    from so-cal
    I just remembered this place Nate Jones Tire in Signal Hill give them a call
    562-597-3369 (closed right now)
  24. evobuilder
    evobuilder
    I owe you a beer.... this is it!!!!!
  25. evobuilder
    evobuilder
