Projects 1932 Jalopy Roadster Build
Discussion in 'Traditional Hot Rods' started by deluxester, Jul 20, 2019.
  1. deluxester
    deluxester
    ***embled new brake hardware on the rear axle. Used ‘40 type backing plates and drums for the conversion to hydraulic. Getting late so this is where I stop tonight.. I’ll start again on it this weekend.
    WC145, oliver westlund, Tim and 9 others like this.
  2. Austinrod
    Austinrod
    from Austin
    Going too follow this thread fosure inspiration
    nunattax, Stogy and deluxester like this.
  3. Atwater Mike
    Atwater Mike
    Enviable project... completeness in renovating front axle is 'textbook'.
    Most would ***emble running ch***is, then grumble because there aren't any REAL front end shops left.
    Noted replacement spring bushings, where is their source? (I also have '32 front main leaf)
  4. deluxester
    deluxester
    I sourced the spring bushings from the Early Ford store. From what I understand, however, is that 32 used a unique size bushing. I’m not certain if my reversed eye main leaf is 32 or later, but they seemed to fit just fine for me.
  5. deluxester
    deluxester
    5791A356-D708-4123-BD5A-8E5E260F0576.jpeg 92168F64-302A-46E0-B6D6-5B9551BFB9EE.jpeg 7B7AF966-5848-4FA0-BC7B-B7263AB4953F.jpeg
    I dis***embled the rear leaf spring pack to clean, paint and install the reversed eye main. Leaf no.2 was shortened to fit within the reversed eyelets.
  6. 421-6Speed
    421-6Speed
    Great find and Job your doing. Will keep and eye on your progress...
    deluxester likes this.
  7. deluxester
    deluxester
    F44FFDAA-2D7C-4DE0-B9AA-1A1D3DEE7EBD.jpeg 43DDFAF8-8C97-4653-8144-8B528D606101.jpeg 0F1BAAA0-4954-4366-B035-5062B9CAE70D.jpeg
    I installed new bushings in the reversed main leaf. Also painted, greased and ***embled the leaf stack today. I had to shorten the two clamps as I removed leaf number four from the bottom. Curious to see how the changes will impact the lowered stance.
  8. sodas38
    sodas38
    Congrats, as everyone else has said its a dream car!
    So far the progress looks great. good work.
  9. What a find! How did you come across it?
    Nice work btw! Looking good!
    chryslerfan55 and deluxester like this.
  10. continentaljohn
    continentaljohn
    Awesome build and congratulations
    nunattax, deluxester and pprather like this.
  11. deluxester
    deluxester
    Another Hamb member discovered it in pieces where it was being stored. It had been entirely dis***embled some time during the 60’s.
    chryslerfan55 and Runnin shine like this.
  12. Doug Hines
    Doug Hines
    I am glad this car ended up in capable hands! What a dream!
  13. ct1932ford
    ct1932ford
    Looking Good!:cool:
  14. Materguru
    Materguru
  15. deluxester
    deluxester
  16. deluxester
    deluxester
    4D88A434-D06E-4423-AAB7-EAF512FCC06D.jpeg B9351308-BC6A-4102-AE54-8A4C0CF95FAC.jpeg FA69AFD1-FEDF-4DF9-B9AF-A928DAB82765.jpeg I learned that 1932 spindles will not bolt directly to a 1940 backing plate. I purchased adapter rings and also notched the backing plates to accommodate the smaller bolt pattern on the spindles.
  17. deluxester
    deluxester
    Loosely bolted together here, but I’m not sure I like the look of the notches sticking out from behind the spindle flange.
  18. deluxester
    deluxester
    I drilled the backing plate bolts for cotters, cut some washers to fit around the spindle center, and ***embled the front brakes finally.
  19. deluxester
    deluxester
    @HellsHotRods turned the front drums down for me. Its hard to find a modern brake shop capable of mounting early Ford drums on their equipment. Thanks Dave!
  20. deluxester
    deluxester
    cleaned and dis***embled the stock pedal ***embly. A78738CB-43C1-4FCD-B2D1-9A82EC5864ED.jpeg
    ..Then chopped off the original actuating arm for the mechanical brakes.
  21. deluxester
    deluxester
    I took advantage of @HellsHotRods shop space and helped myself to his Tig welding equipment while visiting earlier today.
    I welded the beginnings of an actuating lever on the opposite end of the stock pedal arm, so that the pedal will now have a pushing effect for the master cylinder plunger.
    866EA39D-92C8-48AF-B457-F29F68302E77.jpeg 30686EA2-5E4D-4DF4-B9B7-E33AFE5BCB47.jpeg 33C5C465-BFFC-4481-ADD0-2B695DFBA18F.jpeg
  22. deluxester
    deluxester
    Thanks again, Dave, for use of the Miller synchrowave 250!
  23. choptop40
    choptop40
    Kudos on your thread , thanks for the share...process is art...
  24. HellsHotRods
    HellsHotRods
    B02678C7-1018-47F5-BB71-1A10E07A9D55.jpeg 71C75316-26E5-4842-8135-C584C32F5F81.jpeg 166C4699-5ED5-4440-978F-E6D7AC771117.jpeg
    Support your local builder ! One stop for everything . Quality craftsmanship . Ford part numbers .
  25. deluxester
    deluxester
    I forgot to mention that these machined spacers were necessary to form a mating surface for a grease seal at each front drum when mounting ‘40 style brakes on ‘32 spindles. They have a slight press fit at the base of the spindle axle.
  26. deluxester
    deluxester
    4E502B3D-7EB2-4E99-AA30-CBE23ECAFA0B.jpeg Prepping an 8ba motor this morning that I built last year. Snyder cam, converted to early distributor and heads, zephyr valve springs, high volume oil pump and truck pan.
  27. deluxester
    deluxester
    EDD6D1D5-D623-4210-AA77-28E08079D188.jpeg Some grinding to the mounts required along the water pumps to get these 32 motor mounts to bolt up to the 8ba.
  28. deluxester
    deluxester
    I needed to swap the timing gear cover with a 3-bolt type in order to accommodate a Lincoln V-12 distributor. I also cleaned and painted the block M200 Antique Ford Green.
    C8CEC771-50BD-4860-9E94-7F753EEA1904.jpeg 126ADAC1-E51C-40F3-8A4F-B6B0FF50F278.jpeg
  29. deluxester
    deluxester
    I managed to find an original Kurten converted Lincoln distributor, and had Tyrell Pennington restore the unit to perfection! He does beautiful work and I’ve been anxious to mount it to the motor. The coil has been converter to 12v.
    Having grown up in Southern California, I enjoy finding and learning about local speed equipment manufacturers. Kurten Aero-motive operated out of Alhambra during the 1940’s. Owner Jim Kurten produced about 50-60 of these to my knowledge and proceeded to share his knowledge with the Spaulding brothers of Monrovia, CA.
    5CB56194-446B-4C44-BB8D-4F986BE8D5C8.jpeg A45E40B3-418E-41FC-8649-1EA42A58B121.jpeg 4B2BF3EF-11A8-47DA-9DF9-F8CD6612BE24.jpeg C320CB74-4DE3-4E86-9E38-6D11C01798BF.jpeg F2309066-FBD3-45F7-AC27-900D64298056.jpeg
