Technical Loud multiple bang noise when releasing clutch hard
Discussion in 'Traditional Hot Rods' started by hobbyjp, Aug 19, 2019.
  1. hobbyjp
    hobbyjp
    from socal
    I have a 1954 Chevy 210 with a 235 manual transmission. About two days ago I put the car in reverse and heard a noise that made me feel like the brake pads fell apart. I drove around a little and there's a constant whine and if I let off the clutch hard it bangs multiple time extremely loud.
    I checked the front ujoint today I can force the shaft up and down which seems a little weird but I'm not super knowledgeable about enclosed drivelines it also seemed like it was to one side too.
    Has anyone experienced a bad clutch make multiple banging noises? I guess my next step is to completely disconnect the drive line and run it through the gears and see if it's in the front or rear end. Any help or experience would be appreciated.
    Thanks Jimmy
    Sent from my SM-J327V using The H.A.M.B. mobile app
  2. alchemy
    alchemy
    So you know the U joint is loose but you think the problem is the clutch?
    Desoto291Hemi likes this.
  3. tb33anda3rd
    tb33anda3rd
    I would put it up on the lift and have someone run it through the gears while I listened from underneath.
    uncleandy 65 likes this.
  4. drtrcrV-8
    drtrcrV-8
    If you're going to "listen from underneath", You might want to stand either in front of the clutch or behind the rear end...… just saying......
  5. Should there ever be any play in a U joint?
    Naw!!!
    Tommy
  6. hobbyjp
    hobbyjp
    from socal
    Yes on a normal open driveline car there is no play in the drive shaft this is an enclosed driveline and there's no locking pins to keep the ujoint from moving up and down. I'm kinda confused about how this ujoint is supposed to work. It's been 10 years since I last changed the clutch and had it all apart.
  7. Sorry,, I missed line about enclosed.
    Just ***umed later model driveline.
  8. hobbyjp
    hobbyjp
    from socal
    I found the manual and I guess there is supposed to be clips holding the you ujoint in on two sides. I'm thinking something happened and broke the clips pushing the ujoint out of place. Tomorrow I'm going to pull the whole yoke out to have a better look.
  9. hobbyjp
    hobbyjp
    from socal
    Can anyone verify if there's a ujoint at the rear of the enclosed drive shaft on the 54 Chevy? I could only find information on the front ujoint in the manual
  10. tb33anda3rd
    tb33anda3rd
    no universal at the rear
  11. hobbyjp
    hobbyjp
    from socal
    It kinda seemed like the solid shaft was pushed to the top of the enclosure tube. It might have been the way I had the front jacked up though. have you ever heard of the shaft getting bent?
