Have you ever used wrinkle finish on car parts? If so, what did you paint and how did it turn out? HRP
I like Krylon. Put it on as wet as you can and right into an oven. Better yet, let your favorite power coater do it for you. Gary
I really like the look of wrinkle finish but it's been years since I've used any. At least some 426 Hemi valve covers were wrinkle finish if memory serves so it can't be too bad. Now that you've brought it up, I wish I had done wrinkle finish on the new pair of raw steel SBC valve covers I just painted low-gloss black. Lynn
I have used it a few times. Like stated above, put right away in an oven or use a heat gun. On hot southern sunny days like the 100 degree days lately, you could probably just let the outside temps cure it properly.
First time I saw it used was in the late 60's. My brother painted the valve cover on my mother's Austin Healey 3000 and I was amazed. It looked cool as hell. He called it Crinkle paint.
Use VHT. Put it on real wet and take a heat gun to it. I used it on cycle and dash parts. It looked real good. The trick was the amount that you put on.
The only comment I can say is for best results, always use a fresh can and not one that's been used sitting on the shelf for 6 months
OK @gnichols, you must be single huh? I prefer Krylon also but have had good results with VHT too. I value my life so I don’t use my wife’s oven but I have put the item out in nice, bright sunlight around noon time to get it good and warm, sprayed the paint and let it dry in the sun. Worked great. Danny, if that first photo is representative of the effect with Rustoleum it is not what I get with the other paints, Krylon and VHT wrinkle like the old school finishes we’re familiar with. Disclaimer- then again it has been a long time since I bought any wrinkle paint, the formulas may have changed.
In the 70's I had an Enderle injector hat for my carb scoop, it had never been machined or polished and I used a wrinkle finish on it, don't recall the brand, it turned out pretty good but it took some trial and error to get a consistent pattern/finish. I actually got the idea from my pals' 66 Plymouth Hemi rocker covers which were factory wrinkle finish. Sorry, photo is in computer lockup.
I did a valve cover for a ot Toyota pickup. After it was dry, I sanded and polished the lettering and ribs. Looked cool.
I use it for air cleaner lids and valve covers. Tried it out on a dashboard and door tops on my first Falcon, too large of an area to get a good finish. There used to be a brown version that was popular for a while. I have a can of black that is still good after three or four years on the shelf. Just used it the other day on the air cleaner lid on my 460.
I've used it on valve cover and OHC timing belt cover on a 2300 Ford, like BamaMav, I sanded the ford script and cleared over it. I like it on valve-covers,timing cover, and oil pans....cheap dress-up contrast, and doesn't show any oil seepage. '60's Mopars had them on performance engines
The sample image and spray can was pulled off the internet, Back when I used it the copany that made it was Illinois Bronze and they made it in several different colors. HRP
Harley Davidson brand is light years the best. I have in the past recommended this to a friend over on the “barn” in the UK he paid $40 a can & said by far worth every penny. I highly recommend despite the cost. Good luck Cheers Tony
I used it many times on inner fender panels and firewalls. It covers small imperfections(little surface prep - just free of grease and oil). It also is easy to clean and engine oil and emissions does not seem to affect it. Follow the directions , apply up and down and across ( avoid runs at all costs) and follow the time intervals. Hard to put an ***embled front cap in an oven , so do as suggested let the noon day sun and heat do it's thing . Later Bill
Many moons ago, 64 Bonneville with a 389, painted motor cherry red, took a set of Mickey Thompson valve covers and VHT black krinkle paint, , polished the tops of the fins. Painted pulleys semi gloss black with a thin cherry red pinstripe on each one. Nice small chrome spark plug separators with black plug wires. Finished off with a small 8" air cleaner. Every time I opened the hood to check oil at the gas pumps I'd always end up with at least 2 or 3 guys walking around it. It was awesome
Used it on a pair of Sheetmetal valve covers. After my last coat(used 2 coats) put a 100w light bulb under them for a couple of hours. worked fine & lasted for at least 15 yrs or more on a daily driver motor. Everyone thought it looked good, especially after my artist wife repainted the stamped logos in the covers the correct original colors.
First and only time I ever used the stuff was probably 30 years ago. Painted the valve cover on my 223 six banger. I’m from Arizona, so there’s your oven. I remember liking the way it turned out.
Never tried the bombs , but I found out many moons ago that after you shoot your panel, thicken up your paint and spray it out evenly ,kinda like cotton candy hair. Ive done quite a few things using that method but mostly engine bays. Actually discovered it by accident.
love that stuff. painted the valve cover and lifter covers black on a chevy inline 6 and they really set off the orange engine color!
Other than you can’t wipe it off easily, I like it. Always had the heater or oven ready. I agree with the HD cans. Did my barrels and didn’t take it off the edge of the fins.
Don't know about Rustoleum wrinkle paint but their bed liner paint is a PITA to spray. Now I always use Krylon for bed liner paint, works much better. That said if was me I'd go with anything but Rustoleum.
