Projects Just Another Hemi Powered Model A Coupe Build
Discussion in 'The Hokey Ass Message Board' started by ClutchDumpinDan, Aug 1, 2019.
  1. lothiandon1940
    lothiandon1940
  2. 40FORDPU
    40FORDPU
    Some people question what a Hot Rod is..this car will clear it up for them.
    Nice craftsmanship, coming along nicely.
  3. D-Russ
    D-Russ
    Hey Dan, would your client be interested in a high rise 6x2 or a pair of Imperial valve covers?
  4. ClutchDumpinDan
    ClutchDumpinDan
    Alignment slice and dice...
    Garnish mouldings done..
    Windshield slide pivot thingies are moved and working sweet...
    Wood! Covers up the welds nicely...
  5. ClutchDumpinDan
    ClutchDumpinDan
    4 deuces is gonna be enough to try and tune!
  6. Redrodguy
    Redrodguy
    Looks great! Nice welds and fabrication skills. Would you mind sharing a part number for the gas tank?
  7. D-Russ
    D-Russ
    4x2? I thought he had a 3x2. 3x2s tune themselves.
  8. ClutchDumpinDan
    ClutchDumpinDan
    Sure. I’ll dig it up for ya. Nice tank so far.
    He has all the 2’s! Actually sold the 3x2. It’ll be running the 4x2. I think there’s even a blower manifold on a shelf somewhere :eek:
  9. swade41
    swade41
    from Buffalo,NY
    Nice to see you're still at it Dan
    ClutchDumpinDan and loudbang like this.
  10. 51box
    51box
    from MA
    Looking good nice work
  11. ClutchDumpinDan
    ClutchDumpinDan
    On and off. What a long strange trip it’s been haha :D
  12. ClutchDumpinDan
    ClutchDumpinDan
    Chops all done...
    I can’t stand a sloppy misaligned T-strip...
    P***enger wheel well and quarter panel patch final welded and finished...
    Trying to get the body done and ready to take to the painter on Monday. That’s gonna be a stretch. Who wants to come help weld and grind? ;)
  13. waxhead
    waxhead
    from West Oz
    Outstanding workmanship. Looking really good.
    loudbang, ClutchDumpinDan and enloe like this.
  14. Jeff Norwell
    Jeff Norwell
    MODERATOR
  15. AmishMike
    AmishMike
    Very nice build as said defines a real”hot rod”. R u going to run/build a hood? I hope the grille comes down a bit to line up with top of cowl.
  16. Fitnessguy
    Fitnessguy
    Good stuff brother. Brings back lots of memories on my build. Enjoy the process! What colour are you going with? Looking forward to the final product.
    Dino 64, loudbang and ClutchDumpinDan like this.
  17. fordloverracing
    fordloverracing
    First quality workmanship and pre-planning. Even "Jaws" would be happy with your work ( Jaws was our fabrication shop supervisor at Holman-Moody in the '60's / '70's... a super stickler!!!!!! ) Rick
  18. ClutchDumpinDan
    ClutchDumpinDan
    Nope, no hood. It’ll have support rods mounted down lower than stock. Agreed, nothing worse than a grille shell above the cowl. Gonna have to cut the lower radiator mounts to drop it.
    As of now, it’s getting Leadfoot Gray (modern Ford color) on the body and grille shell. All black ch***is and suspension, black painted/powder coated grille insert, black coated headers.
    And a different more bad *** set of wheels and tires.
  19. ClutchDumpinDan
    ClutchDumpinDan
    Driver side wheel well and quarter patch done...
    Trunk divider welded in and done...
    Trunk braces are done...
    Got the trunk gap good enough for the painter. It was bad....
    All the misc interior welding is finished up. It’s coming along pretty good. Still a looooong way to go before the body can go to the painter.
    Stogy, 1947knuck, Tall t 26 and 14 others like this.
  20. AHotRod
    AHotRod
    Looks like the making of a real Hot Rod, make it for fun and you'll never regret it, trust me.
    Your doing a really good job, well done Dan.
  21. Barn Hunter
    Barn Hunter
    Great looking hotrod and fine metal skills. Can't beat it!
  22. ClutchDumpinDan
    ClutchDumpinDan
    Taillights and tag mount. It’s getting a year of manufacture tag which is wider and will center the taillights...
    Poor fitting corner patch panels...
    Header turnouts tacked on and ready to final weld...
    Added flared holes/covers to the seat brackets that will be seen...
    And then...lift off!
    Driver side door bottom and cowl bottom...
    P***enger side door bottom and cowl bottom...
    Bottom side seam sealed and undercoated...
  23. ClutchDumpinDan
    ClutchDumpinDan
    The build changed a bit as things came along. I was originally gonna do all the body and paint work. Nicely painted ch***is and just a quick once over on the body and primer. To maybe be painted at a later date.
    Then it was decided the body was to be nicely painted, which I can’t do in a reasonable amount of time...or at all. A phone call to my buddy Scott at Kahiko Customs just outside of Richmond Virginia and he agreed to help out. He does high end Porsche restoration work, so painting a hot rod is a bit outside of his norm, unless it’s something like @D-Russ Vicky which ended up on the cover of TRJ. Thanks again Scott!
    Head shop supervisor at Kahiko...
    I’ll be finishing up the ch***is and painting/***embling that while Scott gets the body in top shape. Looking forward to seeing it all together!
    Stay tuned!
  24. Dino 64
    Dino 64
    from Virginia
    Just found this thread !! Great job Dan.
    Looking forward to seeing it in paint.
    It’s killer
  25. ClutchDumpinDan
    ClutchDumpinDan
    Need a glovebox handle/latch for the ‘35-‘36 Ford dash if anyone has a lead. Thanks!
    1947knuck and loudbang like this.
  26. sidevalve8ba
    sidevalve8ba
    Dan, what is that seat frame out of? The car looks great by the way. Keep up the good work!
  27. alfin32
    alfin32
    from Essex, Ma.
    WOW, great build, and I love the punch list!
  28. ClutchDumpinDan
    ClutchDumpinDan
    It’s a new seat from some street rod company. Owner traded some stuff for it awhile back. They’re crazy expensive new. It’s at the upholstery shop now.
  29. ClutchDumpinDan
    ClutchDumpinDan
    Ch***is is stripped and ready for final welding!
    A few speed holes in the wishbones...
    Axle is laid out and gets holed tomorrow...
  30. ClutchDumpinDan
    ClutchDumpinDan
    Axle drilled...
    Spreader bar drilled...
    Smoothing and prepping ch***is parts for paint...
