Technical What are these? What does this fit?
Discussion in 'The Hokey Ass Message Board' started by Hotroddder, Aug 22, 2019.
  1. Hotroddder
    Hotroddder
    from Auburn, WA
    I picked these at the Goodguys Puyallup Swap Meet last month. 2019-08-15 18.22.16.jpg 2019-08-07 06.40.31.jpg 2019-08-07 06.40.33.jpg 2019-08-15 18.20.32.jpg 2019-08-15 18.21.00.jpg 2019-08-15 18.04.16.jpg
    catdad49 likes this.
  2. oldiron 440
    oldiron 440
    Is the first one a top for an autolight carburetor?
  3. Hotroddder
    Hotroddder
    from Auburn, WA
    I was told by the seller that it was an aftermarket top made by a famous (his words) engine builder in the 50's or 60's. He could not remember who it was.
  4. warbird1
    warbird1
    The middle one looks to be an automotive version of the the Time-Rite used to set the mag timing on aircraft engines. If so, that's a very good tool...
  5. Hotroddder
    Hotroddder
    from Auburn, WA
    A google search came up with absolutely nothing for me.
  6. alanp561
    alanp561
    There's a thread from 2005 started by @DoggieBoy Johnson about the Creitz brothers in Oklahoma. If I knew how to show the link, I'd do it but, as I'm pretty computer illiterate, you'll have to look for it yourself.
  7. okiedokie
    okiedokie
    from Ok
    A local friend is a Creitz expert. Bob was from here. If you would like to contact him pm me and I will set you up.
  8. squirrel
    Maybe you could take pictures that are not close ups, and include the whole part, showing both sides of each. And take the tool out of the can, if it's in there, so we can see it.
    I bet lots of folks would recognize the other side of that bellhousing, if they saw it.
  9. Hotroddder
    Hotroddder
    from Auburn, WA
    PM sent
  10. Hotroddder
    Hotroddder
    from Auburn, WA
    Here is what is in the can. I have a couple of these and some have different small parts. This one had the allen wrench, the others did not. Some look unused, some may be used.
  11. Hotroddder
    Hotroddder
    from Auburn, WA
  12. Hotroddder
    Hotroddder
    from Auburn, WA
    The carb tops
  13. Corn Fed
    Corn Fed
    Well the carb top says right on it that it's for a Carter AFB.
  14. Hotroddder
    Hotroddder
    from Auburn, WA
    I also got this from him. The front is empty and the reverser housing has a set of planetary gears in it. 2019-08-15 18.23.46.jpg 2019-08-15 18.23.50.jpg 2019-08-15 18.24.05.jpg 2019-08-15 18.23.58.jpg
  15. Nailhead Jason
    Nailhead Jason
    do you have any more pics of the lower bellhousing? it looks to be possibly for an early extended bell Hemi, it say Drag Machines on it ans I know they made adapters for the early dual range hydros to extended bel Hemi, but have not seen the lower bellhousing before. Is there a starter mount?
  16. williebill
    williebill
    I've got nothing useful, but from now on I'm going to tell people that my old girlfriends used to call me RamSonic..
    Used to...….
    Asphalt Demon and caseywheels like this.
  17. Hotroddder
    Hotroddder
    from Auburn, WA
  18. Black Panther
    Black Panther
    from SoCal
    I'm not going to say I've seen everything..but I've been around. Never seen that Creitz stuff. The carb top has part number CT-4. I wonder what CT-1 through 3 are? Really cool stuff. They made a low profile dual quad intake, maybe this was companion stuff. Love seeing new, old, speed parts..
  19. fastcar1953
    fastcar1953
  20. BamaMav
    BamaMav
    from Berry, AL
    Carb top looks like a dual inlet conversion for an afb carter. Other carb topper is like the air horn sold for Holley’s, supposed to smooth the airflow into the throat.
  21. carbking
    carbking
    Here is a picture of the Creitz dual quad intake:
    Jon
