Technical Oily ass end
Discussion in 'The Hokey Ass Message Board' started by phfireman, Aug 24, 2019.
Tags:
  1. phfireman
    phfireman
    So I was wondering if there is someone that could shed some light on what I have going on. I have been driving my 53 Country Sedan with the Flathead and fordomatic trans. The rear end of my wagon, to include the glass and tailgate are covered in a mist of oil. I have not lost any engine oil however I do have transmission oil loss. Anyone have any kind of thoughts? Any help would be appreciated.
  2. manyolcars
    manyolcars
    it sounds like you have identified the source of your problem
    VANDENPLAS likes this.
  3. HOTRODPRIMER
    HOTRODPRIMER
    Oily**** rear end? sounds like you need to see a doctor! :D
    You have a transmission leak, it will cover up the back of a car. HRP
    Desoto291Hemi, Deuces and VANDENPLAS like this.
  4. Casey Riley
    Casey Riley
    from Minnesota
    Definitely transmission leak. My '51 Merc-o-matic leaks out of the cooling air ducts and ATF ends up all over the rear axle because of highway speeds.
  5. Blowing off the trans where ever that leak is
    And getting your**** oily
    When things leak in movement it goes everywhere!
  6. The wagon is basically as aerodynamic as a brick....... which causes a lot of turbulence in the airflow behind the car........ which causes the oil droplets to come back at ya.
    "Oily**** End"..........
  7. HOTRODPRIMER
    HOTRODPRIMER
    The cure is to fix the leak or wash the back of the wagon often, I'm sure anyone that follows you any distance at all ends up with transmission fluid all over their hood and windshield. HRP
    Deuces likes this.
  8. Mr48chev
    I love it when a guy actually answers his own question without thinking about it. Had the exact same thing happen on an OT rig that I have for the same reason though. After a while you get tired of dirty oil stains on your jeans just below your knees where they bump the rear bumper when you get in the trunk.
  9. MAD MIKE
    MAD MIKE
    from 94577
    Wagons/vans leave a large aerodynamic void behind the vehicle. Air rushes around to fill the void from under the car, over the car and the sides. If your trans is leaking then the oil mist will be carried by the air and then will be pulled up and onto your liftgate.
    Just don't drive around with the back window open, if applicable, until you get your leak sorted.
    loudbang and HOTRODPRIMER like this.
  10. HOTRODPRIMER
    HOTRODPRIMER
    Would like to see the wagon, we enjoy photos but you shouls already know that, I see this is your first post but you have been a member since 2011. HRP
  11. catdad49
    catdad49
    Don't drive so fast! That alone will cut down on the rear end residue, but it definitely sounds like a******* problem. ^ What Danny Said.^
  12. oldiron 440
    oldiron 440
    Change your diet.
    VANDENPLAS and Deuces like this.
  13. drtrcrV-8
    drtrcrV-8
    Could be as simple as replacing the shaft seal on the transmission housing where the driveshaft yoke slides in? Especially if you're lucky! If it doesn't, possibly pan gasket, but hope it's not the front seal behind the torque converter.
  14. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ Just turn body around on chassis.
    Deuces likes this.
  15. BuckeyeBuicks
    BuckeyeBuicks
    from ohio
    Either quit putting your**** cream on with a paint brush or replace the gaskets and seal on your Ford-o-Matic.
    I heard of a guy that was getting his first prostrate exam and was telling his wife about how it went. He said the Dr. put his left hand on my shoulder and his right hand....wait, he put his right hand on my shoulder..... no, that's not right either...……….. DAMN!!! he had BOTH HANDS ON MY SHOULDERS:eek::eek::eek::eek:
  16. Flathead Dave
    Flathead Dave
    from So. Cal.
    Mud*****
    Deuces likes this.
  17. Free rustproofing on the back half of the wagon. :rolleyes:
  18. Deuces
    Deuces
    Check please......
  19. oldiron 440
    oldiron 440
  20. BJR
    BJR
    Olestra may cause***** leakage.:eek:
  21. phfireman
    phfireman
    Figured I would add to this less than useful post so that if there is someone searching maybe they can find it useful. The issue has long been solved and the car sold but for what it was worth the issue came down to the bolts on the flywheel being loose. Once tightened no more oil leak. Yes HRP member for a while, and the usefulness of the responses is primarily why I do not post things. Possibly the way I asked the question and I am used to getting ridiculous responses given my time in the Marine Corps and fire service but I generally just try to figure things out on my own. Hope y'all have a good summer in Anderson.
    BJR, SS327, 2Blue2 and 1 other person like this.
  22. Beanscoot
    Beanscoot
    Good to hear you got it fixed. Was it the bolts holding the flywheel to the crankshaft, or the bolts attaching the torque convertor to the flywheel?
    The****le of the thread kind of invited the humerous smart**** responses, which others found amusing but I guess it's no fun to be the***** of the joke.
    2Blue2 likes this.
