Technical Wheel hop
Discussion in 'Traditional Hot Rods' started by LKPar1270, Aug 25, 2019.
  1. LKPar1270
    LKPar1270
    I need help! I've dealt with the left front tire dribbling at speeds between 55 and 59 ever since I got my Jaloy on the road, about 5 years ago. I've tried every thing I can think of to cure this. I've had my tires balanced, rebalance, and checked again, at different tire centers. I've swapped the tires around several times, swapped brake drums side to side, crossed my fingers, threw salt over my shoulder, and banged my head against the wall, all to no avail. I've checked brake drum runout, .017 on left, .018 on right, which seems excessive to me but the right side runs smooth, left side bounces. I checked wobble, .008 right and left measured just outside the bolt circle. Thought maybe the shock on the left was bad so took off both front shocks, no change in driveability or change the dribbling of the left tire. I had set the caster when building this at 5 degrees, changed it to 6 then 7 degrees with no noticable effect. One thing I can't, or at least don't know how to, change is the camber, I have 0 degrees on the left and -2 degrees on the right. I think this may account for the over steer I get, mostly on right hand corners, but dont know if this can contribute to the bounce. I'm running the original '29 Model A axle and springs, minus one leaf, and replaced the original cross member with a 1 1/2 inch drop one. Anyone have an idea of what I am missing here?
    Stogy likes this.
  2. squirrel
    did you try installing good shock absorbers?
    Camber is adjusted by bending the axle.
  3. 6sally6
    6sally6
    Stiffer shock(s)? I guess you checked the car for "square" (measure from left front to right rear and compare to the other side) Front axle 'square'/90* to frame rails?
    Hope you git-it.
    6sally6
    Stogy likes this.
  4. LKPar1270
    LKPar1270
    I have Houdaille lever shocks on front, they work well. I took them off and adjusted them using a torque wrench so they have very close to the same action on compression and rebound. I dont completely roll them out as the cause, but taking them off did not change anything.
    I spent a lot of time when I started building this on getting the frame square and level. I am confident it is square.
    Stogy likes this.
  5. Sounds like a shock or spring issue
    Stogy likes this.
  6. dirt t
    dirt t
    I'm not understanding dribbeling?
    clem and Stogy like this.
  7. LKPar1270
    LKPar1270
    Left tire bouncing
    Stogy likes this.
  8. SR100
    SR100
    Did you swap the shocks side-to-side to see if the issue moves too? (This is essentially the low-buck version of Squirrel's advice...)
    Stogy likes this.
  9. Pleasantleafarm
    Pleasantleafarm
    Houdaille shocks are side specific. Maybe you have wrong shock on left side.
    Elcohaulic and Stogy like this.
  10. Texas Webb
    Texas Webb
    Is the tire perfectly round?May need to be shaved?
    Course that should show up at speeds before 55.
  11. F-ONE
    F-ONE
    from Alabama
    Not to sound sarcastic but are you sure it's bouncing on just the left side?
    You may only see on the left because the left is .....the side you see as a driver.....
    Being a transverse spring it may have some attributes with a semi elliptical.
    Here is the trouble shoot for a F1 ... of course it's a semi elliptical suspension vs transverse but it may apply.
    Wheel Tramp...
    loose connecting rod ends
    loose drag link ends
    loose spring clips ( U bolts)
    broken spring tie bolts
    broken spring
    loose steering gear mountings
    wheel balance
    steering gear bind
    radial run-out
    lateral run-out
    spring sag
    loose or worn shock absorber
    Stogy likes this.
  12. buffaloracer
    buffaloracer
    from kansas
    I think it would be interesting to see what things look like when using a spin balancer on that wheel. I'm talking about the kind that spins the tire when it is still attached to the axle.
    Hnstray, Stogy and Mr48chev like this.
  13. Stogy
    Stogy
    Did you try balance beads...I'm running them on a What I suspect is a Coker Piecrust With Lead weights and it has bandaged most of the nastiness...
    How old are the tires...why...because at some point the belting in the bias was changed out to a belt that didn't get flat spots.
  14. Stogy
    Stogy
    Those may be as rare as Tire Shavers these days.
    41rodderz likes this.
  15. Mr48chev
    I've got two of them that I picked up over the past few years, the second because a strobe balancer came with it. LKpar1270 Have you had the tires spun while they were on the car?
    this one has adapters I never knew existed.
    Thing is when you have issues like that and you take the tires off and put them on the finest off the car spin balancer made with an operator that gets called on to teach others because is so good it still doesn't tell you if the brake drum / rotor is out of balance or even if the hub cap is out of balance if you have heavier hubcaps.
    It's still a process if elimination though. If you spin the tires on the car and it is gl*** smooth that eliminates the wheel/tire/ hub and drum from the equation and then you look at those things that F-1 listed and that looks like it is from experience and not a bit of guessing.
    Stogy likes this.
  16. Stogy
    Stogy
    You addressed the OP but No I have not and would take advantage of shaving and this form of vintage balance as I do believe that balancer you show would address the full dynamics of what you mention...The other caveat is you have to make all those goodies you have function but that is quite a neat Swapmeet Snag indeed.​
  17. LKPar1270
    LKPar1270
    I guess it's time for me to eat a little crow. My wife seldom rides with me, and I cannot see that right tire. Talked her into riding along last night and she says the right side is doing the same as the left. The shocks are on the correct side, when I got the truck it had 4 of them, 3 worked well so I pumped the crud and water out of them, flushed them with fresh hydraulic fluid, put them on and filled them. Had tractor fluid so that's what I used. Today I'm gonna flush them and fill with Jack fluid, see if that does the trick, if not I'll go to a heavy fluid.
    Thanks for all the input, I'll let you know how it works out in a couple of days.
    Stogy and F-ONE like this.
  18. 2OLD2FAST
    2OLD2FAST
    from illinois
    I fought this on my tbucket a few years ago.....twice........first time it was an out of round REAR tire , yes , rear .......few years later it was a front shock that lost it's gas charge ....
    Stogy and Blues4U like this.
  19. 56don
    56don
    Crow ain't that bad if you cook it with garlic and coconut.
    Hnstray, Stogy, seb fontana and 2 others like this.
  20. jcforgives
    jcforgives
    I had same problems I installed new rotors that I bought Wagner brand and that fix it
  21. Mr48chev
    Actually I am damned good at making that unit function. I first learned when I was 15 in high school shop and used them at work in different shops for years and when I taught Auto Mechanics with much of the same equipment I had used in cl*** years before even though the cl*** was in a new larger shop at the newer school.
    Still it will tell you a lot just by spinning the wheel with the motor to see if something is or isn't out of balance. Eliminate the easy ones and then work on the hard ones.
    LKpar1270 If you slide your hand around the tread of the tire do you feel any areas that feel cupped out a bit that may be somewhat evenly spaced around the tire? That is often the tattle tale indicator of bad shocks or shocks that aren't working right. You see it a lot on tires on 4x4 trucks but I have seen it on car tires a number of times. You will probably have to feel it more than see it though.
    Hnstray, Stogy and X-cpe like this.
  22. Stogy
    Stogy
    Perfect...Win, Win, wish you were closer I'd pay for that service in a heartbeat...Literally days ago I had a mechanic spin balance and re-weight the wheels accordingly and swap them side to side. I had Road Force balance done several years ago and added Balance Beads last year. So the Balance and Swap/Rotation this time with beads intact has made a noticeable difference but I have not been above 55mph yet.
    Technically I'm only supposed to run beads but at this point in time with 3 Ounces of beads per tire I believe the weights help. Note that one of my front tires has a slight out of round condition masked by the balance...and like you say with the Buick Drums, Caps and Trim rings how does it all work together...That why that machine would make a lot of sense.
  23. X-cpe
    X-cpe
    No change in tramp with the shocks removed means the shocks can't control whatever is causing the tramp, not proof that they are good. More likely that they are totally ineffective. Have you tried checking the radial runout of the tire mounted on the hub and drum? Was the bolt pattern re-drilled, perhaps inaccurately? Have you tried lowering the air pressure in the front tires?
    One possibility from F-ONE's list is front spring U bolts not tight. You removed one leaf and installed an aftermarket lowering crossmember. An error stack may mean that, while the U bolts are tight, they may not be clamping the spring properly. If that is the case it may be exacerbating your oversteer problem. From your avatar, I suspect the over steer's main cause is that rear suspension is a little stiff for the weight it is carrying. The rule of thumb for a cross camber over .5* says that a car should pull to the side most positive, so if your car has a pull it should be to the left.
  24. Vic Walter
    Vic Walter
    Basket balls bounce well as a factor of air pressure, less pressure less bounce. Is running a softer tire pressure a valid test ? Too low a pressure for to many miles will lead to a failure but a short test might make a difference. All tires will have some bounce, effective shocks will control most of it
    Stogy likes this.
  25. christmas tree
    christmas tree
    My roadster did it after running it several times in the quarter. Im puzzled. What happened, what changed. These numbers were as follows not a misprint. 5/8 tow in and 28 lb tire pressure no bounce straight as an arrow. Let it sit all winter and spring strip prep aired the ft tires up 45 lbs [tire gauge was bad I later found out] To the strip I went. Super tire bounce. Loaded it up and went home, then started checking reset tow in to 1/8 in DON,T let grand son read the tape when setting the tow in Lesson learned. Let the tires down to 28 lb air and at 100 you can take your hands off the steering wheel. New tire gauge. Too much tow in got by, to much tire pressure and too much tow in, VERY ****TY combo. Check your numbers.
    Stogy likes this.
  26. clem
    clem
    For some tyres, could this cause a problem , putting them out of shape initially ?
    Stogy likes this.
  27. clem
    clem
    Does anyone know what type of tyres the OP is running ?
    Stogy likes this.
  28. oldbanger71
    oldbanger71
    Interesting.... curios what cure you have finaly.
  29. jcforgives
    jcforgives
    I had a 34 panel truck hopping at 55 I put new Wagner brake rotors on it and that fix it
  30. I was thinking this same thing when I had a tire bouncing, but to tell the truth I fixed it by running higher pressure. That after new king pins, new tires, messing with toe-in adjustment did not fix it. Boy, I won't forget that!
    Stogy likes this.
