Hot Rods Pecks RPU project
Discussion in 'The Hokey Ass Message Board' started by pecker head, Dec 29, 2018.
  1. pecker head
    pecker head
  2. stillrunners
    stillrunners
    from dallas
    Nice.......
  3. stillrunners
    stillrunners
    from dallas
    Someone gave him the Gauge panel - that's all I'll say.........
  4. pecker head
    pecker head
  5. pecker head
    pecker head
  6. pecker head
    pecker head
  7. pecker head
    pecker head
  8. pecker head
    pecker head
    4D9DA70A-DA08-4D9D-B7A6-A3D302977240.jpeg ADE278E2-AB37-44E0-946F-D0499357B2DC.jpeg
    Just Gary, LCGarage, afgjr and 8 others like this.
  9. greaser
    greaser
    Project is moving fairy rapidly.
    I'm not sure the rear end torque arm will function correctly in its current configuration, and will probably break the adjacent trailing arm. I believe the pivot points should all be on the same rotational axis, both on the front and rear, similar to a 4 bar setup.
    Roadsir likes this.
  10. pecker head
    pecker head
    0BB42C1E-A7F7-424C-A71E-A6D1AEE5384A.jpeg Been running one on my 28 coupe for 12 years no problem.
    BradinNC, Stogy, Junior Stock and 2 others like this.
  11. patmanta
    patmanta
    from Woburn, MA
    WOW, that torque arm is a BEAST! I like it!
    Stogy, loudbang and pecker head like this.
  12. pecker head
    pecker head
  13. pecker head
    pecker head
    435C45E2-3160-48C1-8D75-3CE650284653.jpeg Putting driveshaft in shop today to get cut down. 71805FD2-46E5-412A-A316-6D87E9742FE8.jpeg
    Stogy, OFT, loudbang and 1 other person like this.
  14. pecker head
    pecker head
    0C3D050F-BDD8-4ED5-8640-0C1690E5158C.jpeg F6BEA105-41FF-4675-8065-984F5A1DF875.jpeg C1AB8DC1-9A6C-486B-9816-0B3DBEB0299C.jpeg Got shifter installed, stick will be changed to a 39 stick.
    Atwater Mike, Stogy, brEad and 3 others like this.
  15. pecker head
    pecker head
    C4362A5A-9D2D-4375-B94F-E087CF8A659C.jpeg 5DBE4C18-3456-4380-BFAE-CABD6BC12063.jpeg E4DDF0B4-BE46-4825-89C2-3179CEFAA52C.jpeg B1B6A07A-8449-454A-B77E-EF27D6B63C67.jpeg I’ve started cutting the F1 pedals and changing them up to my liking. Still not there yet.
    Stogy, OFT, loudbang and 2 others like this.
  16. pecker head
    pecker head
  17. pecker head
    pecker head
    856A8D72-2DEB-4F7D-B4CE-B5D1205C5627.jpeg Driveshaft done.
    Stogy, OFT, Shadow Creek and 2 others like this.
  18. pecker head
    pecker head
  19. pecker head
    pecker head
    8B31D813-7089-4B09-9706-9887A96B4078.jpeg 0E3BEE03-15F8-4824-9169-534D950F050F.jpeg Clutch linkage done.
    LCGarage, bct, cactus1 and 6 others like this.
  20. pecker head
    pecker head
    Whacked out these weld on brackets for the flexible brake lines , I used 5/8 E clips to hold them in place. I did the easy one first. Maybe the front two before weekend is up. E02F6117-7ADF-423C-A2C0-D5866BE81732.jpeg 22BB7BE5-0480-4DE6-B89F-597120290F2C.jpeg 0594FF8D-0D91-4B93-B0B5-BAA4BC600BA3.jpeg 9A43B15A-58F1-4615-97B5-B63DAACECC38.jpeg
  21. pecker head
    pecker head
  22. pecker head
    pecker head
    BA6F666A-35CA-4165-AAD8-F6463A99927F.jpeg 332CB905-216A-41AC-B53C-075C757FA1D4.jpeg 257FCCD0-7656-48E7-9CB0-8A564C5FA8DC.jpeg CAA8FD58-1BBC-4D50-99DE-3D0D444349A8.jpeg Brakes are adjusted and bled with a good pedal.
    brEad, patmanta, Junior Stock and 7 others like this.
  23. pecker head
    pecker head
    So, for the people that have been following this build , you know I spent a day reversing the eyes on the stock springs . The front spring hit spring perches as soon as I set motor and trans in place, took out and re-arched more to no avail. So I called my bud Nostalgia Sid and had a Posies super slider in 3 days. Will install soon.
    Stogy, loudbang, guthriesmith and 2 others like this.
  24. pecker head
    pecker head
  25. pecker head
    pecker head
  26. belair
    belair
    Lots of nice work that no one sees or appreciates.
  27. kidcampbell71
    kidcampbell71
    Less than 3 weeks to Pistons and Paint !! Gonna' make it, with the RPU ? Hope so ...
  28. pecker head
    pecker head
    1ABF1FBD-D56F-407B-8E7B-E2D3115C37F1.png Will be in PeckerHead coop.
    OFT, loudbang and kidcampbell71 like this.
  29. pecker head
    pecker head
    78CD49DF-5F7A-45C8-ABEE-8646615F7C54.jpeg D8448A57-3E3C-422D-9B64-D253B74E1935.jpeg This was delivered Friday. Any mounting advice? Gonna run original shell and full hood.
  30. pecker head
    pecker head
