Features Who's Building a T?
Discussion in 'The Hokey Ass Message Board' started by Slimegreeeeeen, Nov 19, 2011.
  1. robert4005
    robert4005
    More..........
  2. robert4005
    robert4005
    If you’re right and I think you probably are I’ve got a 27.
    AndersF, loudbang and keith27T like this.
  3. keith27T
    keith27T
    Yep 27
  4. robert4005
    robert4005
    I’m gonna call it that anyway.
  5. goldmountain
    goldmountain
    Good luck finding the deck lid.
  6. robert4005
    robert4005
    Not even going to try, already got one from Howell’s.
    AndersF and loudbang like this.
  7. 26 T Ford RPU
    26 T Ford RPU
    Some still have them. JW
    Junk yard, Tall t 26, EVL401 and 4 others like this.
  8. MMM1693
    MMM1693
    Good luck with the deck lid from Howell's
    robert4005 likes this.
  9. brEad
    brEad
    Here in Kansas, I’d call that “mint”!
    robert4005, Jet96 and loudbang like this.
  10. robert4005
    robert4005
    Thanks I’m sure I’m going to need it, I’ve heard the fit is poor at best.
  11. Jet96
    Jet96
    from WY
    Where would you guys go for a deck lid? My '27 is missing completely...
    MMM1693 and loudbang like this.
  12. robert4005
    robert4005
    http://fordor.com/category.cfm?cat=1926 1927 Ford Model T Coupe Parts&dept=0927modelt
    https://www.ebay.com/itm/Model-T-Fo...AOSwQmhdRLEr:sc:FedExHomeDelivery!72126!US!-1
    https://www.ebay.com/itm/1926-1927-...260142&hash=item3d72cb51c6:g:X6oAAMXQWx1RHGeh
    All you get from Howell’s is the outside skin. From what I understand the fit is pretty poor so be prepared to do some work to make it fit. I plan on making a skeleton for it with square tube maybe some angle. There’s an original one on eBay right now ,that’s the second link I posted. The 3rd and last one is an eBay listing from Howells, that’s how I got mine. I understand when you deal directly with them that service can be pretty poor and you’ll have better luck getting one through eBay.
    MMM1693, 26 T Ford RPU and loudbang like this.
  13. Jet96
    Jet96
    from WY
    Thank you!
  14. goldmountain
    goldmountain
    I'm about to try my third go round trying to get my deck lid into shape. My original one looked like an elephant stepped on it so getting it to work with a poor fitting skin has been a challenge. I noticed in a magazine feature on a T coupe that had the deck lid made in two parts with an upper piece that mounted solidly to the body like the tulip panel on a Model A and a deck lid without that troublesome reverse curve. Suggested this to a friend with a T coupe and his turned out great. Meanwhile, I'll keep up fighting with mine. T deck lids do not hinge like other cars. They rely on a hinge pin on the side of the lid about 5 or 6 inches down from the top so that upon opening the top edge goes down when the bottom comes up.
  15. robert4005
    robert4005
    Goldmountain I’ve thought if making 2 pieces. The gas tank will most likely fill the upper part anyway no reason for that part to open up. You got any pics of you progress on your deck lid?
  16. MMM1693
    MMM1693
    I took my Howells deck lid and cut it into two pieces and welded the top piece in. I then hinged the bottom piece to it. It was the only way I could make it work at all. It's not perfect but it came out ok. I have a build thread posted if you want to look at pics
    Jet96, robert4005 and loudbang like this.
  17. robert4005
    robert4005
    Checking out your build thread, already seen some ideas I may steal, your fab skills are excellent sir , I fit and welded in fab shops for over 25 years I know good work and planning when I see it.
    loudbang and Stock Racer like this.
  18. MMM1693
    MMM1693
    Thank You Sir!
  19. 20191027_181551.jpg Slowly but surely making progress. think I'm doing it proper
  20. 26 T Ford RPU
    26 T Ford RPU
    Looks good to me.:cool: JW
  21. brEad
    brEad
    Me, too!
  22. Blue One
    Blue One
    from Alberta
    I’m getting closer :cool::)
    E208F89C-28C2-4D57-B45A-0D447680E343.jpeg 2C1AE376-3CF5-43C2-9FE9-D6D96D593BF6.jpeg 47F596A2-24CD-4847-ADD6-9620EB2550FA.jpeg 39400CE0-A97D-4729-B013-BDC0B0ADCC72.jpeg
    hrm2k, exterminator, VA HAMB and 6 others like this.
  23. 26 T Ford RPU
    26 T Ford RPU
    Show off!:rolleyes::D JW
    Blue One and loudbang like this.
  24. MMM1693
    MMM1693
    Osoty, its looking fine!
  25. Thank . I made a beginner's mistake and changed tire size after I modified the frame. I dont have a full spring pack on the back so hopefully a few more leaves will make the top of the wheel well align with top of tire
  26. MMM1693
    MMM1693
    I would see how it rides before adding springs. I think it looks fine the way it is.
    loudbang and 26 T Ford RPU like this.
  27. jimgoetz
    jimgoetz
    Howell will sell you a complete deck lid or the inner or skin. I bought my skin and inner in two pieces and put them together my self because my body was so bad I knew I was going to have trouble fitting it up. I don't think I could of with a complete piece. Making it fit was maybe the hardest part of the entire build. DSCN1120.JPG DSCN1124.JPG
  28. exterminator
    exterminator
    T skele.JPG hought i would throw this picture in.
  29. DesmoDog
    DesmoDog
    The complete deck lid they sell doesn't fit anything very well. It is flat along the edge the hinges are on (across car), but the tulip panel has an arch to it. Ask me how I know.
    I am living in denial until I reach the point where I have to make it fit.
  30. jimgoetz
    jimgoetz
    That's exactly what I ran into but because I had both pieces I made the outer skin fit the body first. Then I got the inner panel to work more or less and then I put them together. I also had to adjust the panel below the deck lid and even moved the quarters around some. Getting the hinges to work right is another whole problem.
    Good luck with your project DesmoDog.
