Any early overhead Caddy blower manifolds?
Discussion in 'The Hokey Ass Message Board' started by Kirk Hanning, Sep 2, 2007.
  1. Kirk Hanning
    Kirk Hanning
    I am running a 57' 365 ci Cadillac motor in my '34 Ford truck project. I have already aquired an edelbrock 4 duece intake for it.
    My delima is that a family member just aquired a complete 6-71 blower setup for a sbc. including the carbs. I can get it all for dirt cheap. I know that I will have to fab up an idler pulley bracket if I use the setup.
    1. Did someone make a 6-71 blower manifold for this engine
    2. If they did, would I be able to aquire one w/o an arm or leg
    3. Would it be feasible to fab up an intake or would it just be a waste of time? I AM confident of my fab skills if that helps.
    Any input would be greatly appreciated
    kidcampbell71 likes this.
  2. ss34coupe
    ss34coupe
    I don't think anyone made a Cad manifold to take the 6-71, but I have seen manifolds that would take a 4-71. That 4 carb manifold would look great on your Cad-powered rod. When those 4-71 manifolds do come up (on ebay) they go for $1500 and up, and they are rarely available.
  3. flatheadpete
    flatheadpete
    from Burton, MI
    Anyone else? Kirk really wants to run this on his Caddy. Another question we were asking each other is how nuch carb? Run 3 or 4 2 dueces? Or keep the 2 4's on it?
  4. Lancer
    Lancer
    You will also need to change your cam to run the blower, but I am sure you already know that, just my two cents.
    I would be interesetd in the SBC blower manifold if you are not going to use it, or the whole package if you decide not to run it.
  5. Evel
    Evel
    Von Franco has one for the lighnin' Bug.. Its a Cragar manifold with I think a 6-71 blower on top...Good luck finding one tho..I'll see if I can find a pic..
  6. Ron Mayes
    Ron Mayes
    I have a Cragar for a cad , it's for a 4/71 .........don't know if thay made one for a 6/71
  7. Dale Fairfax
    Dale Fairfax
    'Seems if all else fails, the Edelbrock + a milling machine + some aluminum plate + a tig welder would get you there.
  8. Ben de la Vega
    Ben de la Vega
  9. Dirty2
    Dirty2
    Early Caddy performance stuff is shure hard to get. Sometimes I wonder if its worth it. But they shure are pretty.
  10. Bellboy
    Bellboy
    Hi Ron,do you have a use for the 4-71 Cad manifold? George Montgomery modified a 'few' Cragar 4-71's by welding an additional cast piece with his name to the front.Cheers,Squeak.
  11. Squeak Bell
    Squeak Bell
    Hi,just to let you know I am making Cad 6-71 intakes new. It is patterned off an original Montgomery modifed Cragar 4-71 as used on his Willys Coupe. Cheers,Squeak.
  12. Paul
    Paul
    Editor
    Beauty
  13. ss34coupe
    ss34coupe
    Very nice!
  14. Mike VV
    Mike VV
    from SoCal
    I also have a Cragar to mount a 4-71 blower on an early Cad.
    Mike
  15. Zachary M
    Zachary M
    Squeak,
    Can you send me a link to the blower intake manifold I would like one for my 390 in my 1961 caddy.
  16. mgtstumpy
    mgtstumpy
    I only know of McAFEE or Cragar 4-71 intakes from back then.
    rod1 likes this.
