Technical 1932 Plymouth PB coupe
Discussion in 'The Hokey Ass Message Board' started by dann57, Sep 1, 2019.
  1. dann57
    dann57
    from Missouri
    Does anyone have or can they take pictures of a 32 PB coupe with rumble seat of the hinges the backside of the lid and the inside bottom panel area below The Rumble. I'm trying to make one any help appreciated
  2. rusty1
    rusty1
    ...I have a 32 DeSoto coupe, same body as your Plymouth,..here's a few pics that mite help some...
    chryslerfan55 and kidcampbell71 like this.
  3. dann57
    dann57
    from Missouri
    Here's what I have, somebody welded metal in over rust and used a lot of putty. The lower panel was crooked ,
  4. dann57
    dann57
    from Missouri
    The Desoto looks to be just like it
  5. rusty1
    rusty1
    yup, looks like it, mine's missing the rumble lid, I'd convert mine to a trunklid if I ever get to it.
  6. dann57
    dann57
    from Missouri
    I have an inner trunk structure made of fibergl*** for a full size trunk lid
  7. dann57
    dann57
    from Missouri
  8. goldmountain
    goldmountain
    This picture won't tell you anything but I thought it worth sharing. IMG_0963.JPG
  9. rusty1
    rusty1
  10. dann57
    dann57
    from Missouri
    That's cool
  11. goldmountain
    goldmountain
    Since you have the inner panel, I suggest you check Home depot. They sell 4x8 fibergl*** sheets that are sort of smooth on the backside with a pebbles texture on the "good" side. Used this stuff on my teardrop trailer. You could bond this to your inner panel. It bent good enough for my trailer but if you want a bit of a crown to your panel going the other direction too, it won't work.
    Sent from my SM-T350 using The H.A.M.B. mobile app
  12. dann57
    dann57
    from Missouri
    I may go that route, I'd like to try and get a crown in it . The inner structure has crown built into it already.
  13. dann57
    dann57
    from Missouri
    Surely someone has a 32 PB rumble seat coupe and could take some pics
  14. rusty1
    rusty1
    ...if you have the inner skin and it looks like it'd fit, you just need to make an outer and bond it to your inner..(.Google 32 Plymouth rumble seat coupe for pics)
  15. dann57
    dann57
    from Missouri
    I've searched on Google lots of pics, I was looking for pics of the hinges
  16. Dyce
    Dyce
    If you have nothing I would suggest starting with a set of reproduction 32 ford hinges.
    dann57 likes this.
  17. dann57
    dann57
    from Missouri
    Thanks ,I'll give that a try
  18. bschwoeble
    bschwoeble
    I changed my rumble to a deck lid. We just moved. If I can find the hinges, I'll take some pictures.
  19. bschwoeble
    bschwoeble
    20190906_104307.jpg 20190906_104307.jpg These are the "32" Plymouth rumble seat hinges on my PB.
  20. dann57
    dann57
    from Missouri
