Technical Cowl lights
Discussion in 'Traditional Hot Rods' started by simon sinkinson, Sep 3, 2019.
  1. simon sinkinson
    simon sinkinson
    Could anyone tell me the difference between a early set of model A cowl lights and the later ?
    And was there a difference in the two bodies ?
    I want to get a pair to fit my pick up that I think is a 1929 . Not to worried about getting the right year just a good fit .
    I am in the uk but wonder if anyone has some that they might sell ?
  2. flatford39
    flatford39
    If the pick up in question is the one in your avater you have a 30 31 cab and need the 30 31 cowl lights. The 28 29 don't fit. The 30 31's have a lip that goes over the cowl band. 28 29's dont.
    The37Kid and Dave Mc like this.
  3. Dave Mc
    Dave Mc
    My 31 and my Grammar school cl***mate Bill with my Dog Fuji , is the best pic I have showing the 30-31 Cowl Band with Lights
    chryslerfan55 and kidcampbell71 like this.
  4. simon sinkinson
    simon sinkinson
    Brilliant guys
    I know what to look for
  5. simon sinkinson
    simon sinkinson
    Is the cowl a separate part ? I just have 2 large holes
  6. alchemy
    alchemy
    The 30-31 cowl lights fit over the cowl band. That band strip is either steel or stainless, and required for the cowl lights to fit correctly. The cowl sides won't have the proper rib for the cowl light to fit without the band.
    Dino 64 and Dave Mc like this.
  7. Dave Mc
    Dave Mc
    What alchemy said is correct
  8. Mr48chev
    This is my 31? Victoria. Left side has stainless / shiny right side I'm not so sure if te chrome has deteriorated or it wasn't chrome .
    Both are obviously damaged but should show what the guys are saying. IMG_8064.JPG IMG_8066.JPG IMG_8062.JPG IMG_8063.JPG
    chryslerfan55 and Tim like this.
  9. Mr48chev
  10. Deuce Lover
    Deuce Lover
  11. simon sinkinson
    simon sinkinson
    The Band strip might be a problem . It looks like a big thing for postage ,
    Has anyone used any sort of lights and fixed them in the existing holes ?
    I liked the idea of yellow lenses ablaze on my night trips to the pub
  12. HOTRODPRIMER
    HOTRODPRIMER
    1932 Fords cowl lights have a flat mounting surface, but none of the cowl lights I am aware of have a yellow lens, they are eventually park lights.
    I suppose you could use a amber bulb.
    This is my old mordor with cowl lights. HRP
  13. simon sinkinson
    simon sinkinson
    I will look for 32 lights
  14. simon sinkinson
    simon sinkinson
    Just seen the 32 ford lights .
    Love the look as they look tiny
    I am sure I could make them work
  15. Hotrodmyk
    Hotrodmyk
    Here's another example of the '30 - '31 .
  16. simon sinkinson
    simon sinkinson
  17. Frank Carey
    Frank Carey
    Were Briggs and Murray bodies the same? I've seen 28/29 cars with cowl bands and others without. Wondered if it was body mfr difference. Or body style difference. ????
  18. simon sinkinson
    simon sinkinson
    Be great to see a picture or a car without cowl Bands and lights
  19. flatford39
    flatford39
    Please...buy a cowl band. It finishes off the body lines whether you have cowl lamps or not. They are available in plain steel as well as stainless. Your pick up would have had the plain steel one on it.
  20. simon sinkinson
    simon sinkinson
    Close up photo of the cowl on truck .
    With my long suffering wife and our dogs .
    Do these holes look standard ?
  21. alchemy
    alchemy
    Your truck looks like it usta be a fordor. And no, those holes are way too big. You might need to reduce the hole size for any type of cowl light you can find. I do think a 32 light would be a good alternative if you don't want to use a cowl band.
  22. simon sinkinson
    simon sinkinson
    Yes it was a 4 door . I think 32 lights would be a good look
  23. The37Kid
    The37Kid
    The stock Model A had a wood block that fit between the cowl sheet metal and that metal brace you can see in this photo. Designed to keep the outside metal from getting pulled in when the cowl light bracket is tightened. Bob
    chryslerfan55 and Never2low like this.
  24. Mr48chev
    I'm putting that wood block thing in my model A notebook. Thanks
  25. The37Kid
    The37Kid
    You could make them, but for $8.75 plus postage Snyder's will sell you two, part number is A-13318
    Bob
  26. simon sinkinson
    simon sinkinson
    That might explain the damage
    Did all model A,s have the band ?
  27. The37Kid
    The37Kid
    Yes, all 1930-31 A's had a cowl band, some 1929 Fordors and the '29 Cabriolet had a band as well.
    Bob
  28. scrap metal 48
    scrap metal 48
    Cowl lights also were the same shape as headlights.. 28/29 came more to a point like the headlights....
  29. Mr48chev
    Thanks, for me it is making a note of the simple fact that they have to be there. I can do Chevy AD trucks in my sleep but the Model A is a whole new ball game for me.
    RollinRock and The37Kid like this.
  30. flt-blk
    flt-blk
    from IL
    As noted above, stock the trucks had a painted metal cowl band, I ended up getting a polished Stainless one for my truck and it really sets it off. Since you have over-sized holes in your cowl, you can do whatever you want. I would probably make a garnish plate to cover the big hole and add whatever lights you can get your hands on.
