Projects 1932 Jalopy Roadster Build
Discussion in 'Traditional Hot Rods' started by deluxester, Jul 20, 2019.
  1. deluxester
    deluxester
    Battery shut-off/starter relay/starter switch installed under seat.
    Added some brake line hangers.
    5B4AA49E-E6D1-4BF6-8DD5-5C2B1BED5246.jpeg 72A74178-C9B1-4D4C-A93C-81C537B1312A.jpeg
    And started on the fuel line.
    WC145, Tim, nunattax and 12 others like this.
  2. deluxester
    deluxester
    I removed the sending unit from the badly rusted original tank and cleaned it up for use on another tank that I picked up from a friend. The replacement tank had been modified for quick-change clearance, and there were some pin holes to patch, but overall much better than the old tank.
    5690CAFD-43B0-4789-8A32-4831DD408A53.jpeg 4328C405-74F7-4648-85E3-D4D1E998E96A.jpeg
    WC145, oliver westlund, brEad and 5 others like this.
  3. Nick Agius
    Nick Agius
    That tank is *****in!
    Now all it needs is a quick change!
    brEad and deluxester like this.
  4. deluxester
    deluxester
    ...oh, we shall see.
    Nick Agius likes this.
  5. deluxester
    deluxester
    Found an early Zephyr wheel.
    537514AB-0D96-48E7-A58F-C177FFD12E3C.jpeg 46D0AC40-B167-4E42-8B4C-6F57AF5EF000.jpeg
  6. deluxester
    deluxester
    ..After some (many hours of) elbow grease and polish compound.
    I can’t do much about the cracks and I can’t bring myself to recast the original bakelite.
    Any ideas?
    WC145, oliver westlund, Tim and 10 others like this.
  7. redoxide
    redoxide
    a little filler, something hard like JB weld or maybee Araldite and 2k the entire rim in a shade as close to original as you can have mixed ..
    deluxester, barrnone50 and waxhead like this.
  8. dumprat
    dumprat
    from b.c.
    Epoxy with dye in it would be my choice. Leave as much original as possible and just fill the cracks.
    Runnin shine, slv63 and deluxester like this.
  9. pprather
    pprather
    There was a steering wheel repair thread recently. I'll see if I can find it.
    Phil
    Stogy and deluxester like this.
  10. pprather
    pprather
  11. pprather
    pprather
  12. Beanscoot
    Beanscoot
    The steering wheel is really nice, and functional.
    After everything else on the car is done, get back to it.
    WC145 and deluxester like this.
  13. Ziggster
    Ziggster
    Awesome build!
    deluxester likes this.
  14. KKrod
    KKrod
    I would be tempted to run it like it is. Nice coloration in it.
    Runnin shine, brEad and deluxester like this.
  15. deluxester
    deluxester
    Fixed! (Not really). I must agree that there is plenty else on the to-do list and I am enjoying the original hand-worn surface as is.. so I jammed some mustard cloth wire in the two gaping cracks for now. CD032583-7E66-4B45-8F17-50B683F0C68B.jpeg
  16. deluxester
    deluxester
    Agree. Thanks
  17. deluxester
    deluxester
    Very helpful info. Thank you. I’m not interested in re-painting the entire wheel after the repair, but I did like the super glue and baking soda idea. I might try that sometime in the future to patch the cracks.
    Stogy likes this.
  18. deluxester
    deluxester
    I cleaned up a beat trim piece and installed the gauge panel. I found a used repop “choke” knob for $10 bucks and patina painted it brown on top the glossy black. It should work for now.
    WC145, oliver westlund, Tim and 7 others like this.
  19. deluxester
    deluxester
    I think I finally wrapped up the rest of the wiring, ignition and charging. It looks like a spaghetti mess under the tunnel but it was a lot of work for me. I’ll make it pretty later if I discover everything works.
    FF2A8803-F300-4682-AAFE-1837B5094C90.jpeg 573E2E6A-4CFF-418E-BF96-920F88D289C1.jpeg
  20. deluxester
    deluxester
    6B360B2B-B8AC-4D28-9269-FAC4AF5E0C64.jpeg And finished the fuel line as well..
    WC145, Tim, magnus13 and 12 others like this.
  21. Farmer
    Farmer
    looks like you have a good handle on it all- very cool man! thanks for sharing this progress with all of us
    NoSurf and deluxester like this.
  22. jimmysweden
    jimmysweden
    from sweden
    Fairlane500 and deluxester like this.
  23. deluxester
    deluxester
    Thats what my friend said yesterday! I’ll be switching to the stock 32 type clamp and relocate the line to the dimple in the firewall.
  24. HellsHotRods
    HellsHotRods
    Move the FUEL line to stock firewall location (I have the clamp you need). The brake line brackets are '39-'48 FORD and are dead on period correct for a post war hot rod as this build is. @jimmysweden Do your research, nobody was welding on tabs or running street rod brake lines back on the dry lakes after the war.
  25. jimmysweden
    jimmysweden
    from sweden
    I don't need to do any research. for me it was a matter of taste. But of course, Better to nothing say than say it wrong..
  26. alchemy
    alchemy
    I don't mind the 1940 Ford brake hose bracket one bit. Just what they would have used in 1940 to hot rod that little roadster.
  27. 421-6Speed
    421-6Speed
    Use the steering wheel the way it is it fits the build and looks great as is.
    I agree, change out the fuel line, the rest of your build is so nice would change out to the original clamp and hole. Also your cut out, I had one like that on my 35 coupe and it was a POS. I'm sure you could find a nice used original.
  28. deluxester
    deluxester
    Thanks! I’ll stop by
    brEad and HellsHotRods like this.
  29. deluxester
    deluxester
    Good advice, thank you. Ya, definitely changing that now. To what what cut outs are you referring?
    Nice engine compartment. I dig the bent choke/throttle rods to keep everything parallel and uniform.
    brEad likes this.
  30. deluxester
    deluxester
    I appreciate the feedback.. its why I’m posting. I’m always learning!
