1937 Standard 2 Door Sedan. Dry Utah Body (found it here). Car is is good a piece as I could have ever found. Dropped axle, Posies springs, Nova rear end, TCI suspension, cross members, etc, relocated brake pedal, factory steering, including column, wheel, etc, Drum brakes (because I like them) from 48-52 Chevrolet, original mohair interior except for the recovering of the original seats in like material, dome light even works, factor lighted cluster, 12 volt with original wiring harness, fresh brand new 283 Chevrolet with brand new turbo 350 trans, Lokar Gennie shifter, electronic ignition, new factory cam, aluminum radiator (runs 170 in the heat) sway bars front and rear, new rear glass. Period correct Street Rod that you can drive and enjoy. Looks like one factory green re paint to me. Needs to be left as is in my opinion. Car is very presentable and fun to enjoy in the condition it is in Now. Not a project to be changed. I do understand I'ts a free country. Drives wonderfully on the highway and is an excellent example of the period. Call Cobb Ware at 601-291-0781 and Thank You
