Technical Little tips and tricks for garage hobbyists.
Discussion in 'The Hokey Ass Message Board' started by Ron Brown, Jul 30, 2019.
  1. Mike Colemire
    Mike Colemire
    I have a 66 chevy carb, came on a 1966 327 300 HP if it'd help anyone. The 462 heads are dated April, 1966.
    slack and loudbang like this.
  2. I use dish soap, sugar and no water
  3. 59Tele
    59Tele
    When stripping multi-layers of paint with paint stripper, cover it with Saran Wrap and let it sit overnight. If it's a small part, spread the wrap out on a flat surface, pour the stripper on and then place the part on it . bundle up the wrap and work the stripper around the part. This allows you to use a lot more stripper than just brushing it on. Large areas like a hood just pour it on and lay the wrap over it. Works great.
    Fingers, brEad, j-jock and 3 others like this.
  4. Boneyard51
    Boneyard51
    When your hands are real dirty, grab some absorb all ( oil dry) along with your hand cleaner. Works great at getting through all that dirt and grease.
    Bones
    65pacecar and loudbang like this.
  5. sloppy jalopies
    sloppy jalopies
    If you use '35-'36 car or truck headlights and want to convert to sealed beams try using '40-'41 one ton light bezels, they are a little deeper and that hides the sealed beam retainer rings...
    the '40-'41 truck lights look to be leftover '35 car buckets...
    the truck lights are cool rod lights in their own right...
    slack, 41rodderz, 65pacecar and 2 others like this.
  6. fourspd2quad
    fourspd2quad
    C77887FC-EFEA-46B4-867F-2F438DBE4574.jpeg This is pretty obvious but thought I would throw it out there. Drill a hole in the corner of those large solvent cans to get the ounce or so out of it.
  7. whitewallwilly
    whitewallwilly
    When I drill holes with a stepped drill like this I mark with a sharpie the diameter I need ,so I can see when I get to that diameter,,,it's so easy to over do things an end up with the wrong size hole
    Hope this is helpful
    Cheers
  8. error404
    error404
    from CA
    I made this to hold various size tubing to drill holes in to tubes on the drill press. But it works pretty good for other things too. Even works on thinner cutoffs like this, or even drilling holes into spheres
    lucky, brEad, pila38 and 29 others like this.
  9. birdman1
    birdman1
    I use an old lawnmower battery when doing the electrical wiring on building shot rod.
  10. solidaxle
    solidaxle
    from Upstate,NY
    Don't tell your wife how much you pay for stuff. Mine went to a high end furniture store and the salesman asked what she had for a budget. She said a "32" Ford budget. I paid twice for that car.
  11. stanlow69
    stanlow69
    When seeing if an upholstery shop is any good. Take a set of sunvisors and have them recovered. They are the hardest part of an interior to do. If they turn out nice, then they are good to go. If not, then find another shop.
  12. hotrodmano
    hotrodmano
    from Norway
    Braided lines? You should now better !!! :D
    belair likes this.
  13. whitewallwilly
    whitewallwilly
    When I'm drilling holes in panels inside the body I always have a telescopic stick magnet on the job,,I use it to pick up the metal swarf as I go,,,,saves if ending up in your knees if your kneeling in the car,and keeps it out of panel recesses etc,, IMG_6342.jpg
  14. stivemorgan
    stivemorgan
    from Detroit
    Hi everyone. I am new here. I like old cl***ic cars and despite I don't have any of them it is great to see your projects :)
  15. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    I totally agree with you on this. In one of my last houses, I was the guy a lot of my neighbors came to for help fixing everything. In return they pretty much let me do whatever I wanted. Going out of your way to help others pays off in many ways.
    Sent from my SM-G960U using The H.A.M.B. mobile app
    kbgreen, Chavezk21, Fingers and 10 others like this.
  16. clem
    clem
    I see a lot of tips for hand cleaners.
    For years I copied my father in laws idea of using laundry detergent straight out of the packet, with a little water.
    Please DO NOT do this as it takes the natural antibodies off the skin and opens your hands up to all kinds of possible infections.
    We have both had problems due to this.
    jaimalade and slack like this.
  17. Pallograph
    Pallograph
    Thanks for sharing all your ideas.
  18. BJR
    BJR
    Put a plastic bag over the magnet. When done picking up the metal shavings, just pull off the bag over a trash can and all the shavings fall in the can and the magnet is clean.
    clem, Johnboy34, hotrodmano and 15 others like this.
  19. 58 Yeoman
    58 Yeoman
    from Lacon, IL
    A friend of mine had a 51 Ford PU that wasn't stock. I watched him put SS round knurled bolts into his drill press and file the knurling off while it was turning. He used the bolts for the under hood fender bolts. Looked great.
  20. whitewallwilly
    whitewallwilly
    Like it,
    loudbang and Boneyard51 like this.
  21. boy_named_sue
    boy_named_sue
    from Dayton, OH
    Brilliant. I hate trying to s****e all those little metal shavings off the end of my magnet...
  22. Mind = Blown
  23. Lone Star Mopar
    Lone Star Mopar
    Keep one of those magnetic parts dishes in the blast cabinet to hold small parts and hardware when blasting.
    Sent from my LM-Q720 using The H.A.M.B. mobile app
  24. Doublepumper
    Doublepumper
    from WA-OR, USA
    Friction modifier has the most putrid smell of anything I can think of....well, almost anything;) It permeates right through the plastic container it comes in and will stink up anywhere and anything it's stored in. I keep mine inside a gl*** jar with a sealed lid....stank problem solved.
  25. vintage6t
    vintage6t
    from CT
    Tip 1: To stop dropped nuts, bolts, screws and other fasteners from hitting the hard ground a ricocheting into oblivion, put a bin with the bottom lined with foam, speedy dry, rags or whatever on the floor under your work area. The bin should be low maybe 5" high max and as wide and long as possible.
    Tip 2: When dis***embling a car or some other component where the parts will be stored for a long time a lot of people use zip lock bags. A vacuum food sealer is better. 11" is max width but if you use make-your-own bags on a roll, you can make the bags any length you need. Just cut to desired length and heat seal both ends once the parts are inside. No need to use the vacuum function of the machine though. The seal is stronger than a ziplock, the bags are thicker and stronger and they take to labeling with a sharpie better too. I put all the parts from a given ***embly in one bag.
    Sent from my SM-G950U using The H.A.M.B. mobile app
  26. sloppy jalopies
    sloppy jalopies
    buddy named Wilson gave me a magnet on the end of a bent 3' handle... I call it a Wilson...
    really handy if you drop steel stuff...
  27. Elcohaulic
    Elcohaulic
  28. chiro
    chiro
    When rebuilding carburetors I lay out an old, out of service WHITE bath towel on my work bench. I then put every one of those little tiny parts on the towel as I dis***emble in an order that represents their location in the body of the carb with the carb body arranged on the towel appropriately in the midst of the parts. I then take a picture of it all with my phone prior to putting the parts in the ultrasonic cleaner, The parts stay put on the towel, do not roll off into oblivion and are easy to see against the white background. The picture makes re***embly go easier. Learned this one from a friend. "Brians white towel method"
    Andy
  29. eicke
    eicke
    Throw a magnetic parts dish in the bead blaster for small metal parts. Put them in the blaster on the dish. Close door. Hands in gloves. Grab parts. Blast. Put parts back on dish. Open door. Get parts. No falling thru grate. Happy days!
    Sent from my moto z3 using The H.A.M.B. mobile app
    dwollam, drdave, tomkelly88 and 3 others like this.
  30. BJR
    BJR
    When using a trouble light, always use a compact florescent or better yet LED bulb. They run cool enough so if you splash anything such as gas or oil, it will not break and set the liquid on fire.
