Projects The Warbaby sport coupe build
Discussion in 'Traditional Hot Rods' started by Joe Rosales, Feb 17, 2018.
  1. Joe Rosales
    Joe Rosales
  2. Joe Rosales
    Joe Rosales
    Thanks bud
  3. JWL115C
    JWL115C
    Beautiful and thoughtful work. In one of the first photos posted is one showing the front brakes. It looks like to me that the shoes are installed backwards. That is, the primary shoe with the shorter lining should be on the front. Maybe I am looking at the photo wrong, but just in case... JWL
    triumph 1 and chryslerfan55 like this.
  4. BuckFord
    BuckFord
  5. Joe Rosales
    Joe Rosales
    Yes, we didn’t notice until after I posted the pictures. Problem fixed. Thank you
    Stogy and chryslerfan55 like this.
  6. Well done so far man, fab skills are unreal! keep up the great work!
  7. lucas doolin
    lucas doolin
    The devil is in the (incredible) details. Unreal!
    Okie Pete likes this.
  8. Joe Rosales
    Joe Rosales
    Build is going good had to do a few modifications to the transmission plate that goes to the new xmember. Cut out and moved up about 2 inches, Slowly but surely.
    45DBBEB1-9F04-4B53-999E-764F36660ADF.jpeg 9F57A3E5-9968-46FB-A476-158CEFA19112.jpeg 5F568606-3B02-45E5-8725-5C6D5F92EDC3.jpeg
  9. Joe Rosales
    Joe Rosales
    327 motor fit like a glove, Still have some more work to do to the rear end, but car is coming along nicely.
    410DBE7D-AC3A-45B0-9E10-459F3B3DC4FC.jpeg BAA99092-A17E-49F6-8B48-1A98B702E3B0.jpeg
  10. Joe Rosales
    Joe Rosales
    Some before and after of the rear radius rods that were cut to fit the heim joints. E9ECA354-8235-495C-8C02-3EB287CFA001.jpeg 285A86D1-4A4C-4FE5-BE05-1BCB07834302.jpeg C20D38B9-60A3-4BEB-94F2-84D08EF45294.jpeg F905C825-294A-43C0-8E65-65CF7994EB56.jpeg B494ACB9-CD14-4326-AAA0-5A2448524B23.jpeg F72BA2AF-784C-46F7-8663-F3AA9977020F.jpeg
  11. Stogy
    Stogy
    Joe Rosales and chryslerfan55 like this.
  12. Joe Rosales
    Joe Rosales
    Thanks
    Stogy likes this.
  13. Stogy
    Stogy
    I spy with My Stogy Eye....Quads...Oh Yeah...is that another up and coming Period treat for us Joe...by the way your Camerawork is fantastic...
    You may have answered that already and apologies, I may have missed it...​
  14. Joe Rosales
    Joe Rosales
    Definitely more surprises Mr. Stogy
  15. Stogy
    Stogy
    You're a Great Torch Carrier Joe...the Younger Generation...It's Inspiring and I appreciate it...;)
    chryslerfan55 and Joe Rosales like this.
  16. speedster t
    speedster t
    It looks like you first welded the crossmenbers to the frame rails. The rivets are mostly for detail correct. Very nice build
    Stogy likes this.
  17. Joe Rosales
    Joe Rosales
    Yes, that is correct. The cross members have either been Tig or MiG welded in the inside.
  18. 6sally6
    6sally6
    Nice fab work and welding.
    As a retired welder I have a question though.. Are you going to put a "cap"/final weld around the under-cut spot on the motor mounts where its welded to the frame? Nice 'row-of-dimes' cap around the mount would be purrrrfection IMHO!
    You know how it is......being a welder I look at stuff most non-welders don't see.....not throwing stones.
    6sally6
  19. Joe Rosales
    Joe Rosales
    Frame mounts will have a cap around once they are finished.
  20. Joe Rosales
    Joe Rosales
    Ok guys just a update from my previous post. Originally I was running rear hairpins, but I just didn’t like to look of it so I removed them. After installing the xmember to the deuce frame 35-36 rear wish bones seem to be the perfect fit. Not only was little to no mods had to be done they look great and also give me that traditional look that I want to stick with. Of course I had to pie cut the rods to fit the heim joints and a bit of magic to recreate that pitted look that time has done to 80 year old parts. Thank you everyone for following this build. Not as close as we would like to be but she is coming along nicely. Chris and I are very proud of this little car!
  21. bct
    bct
    Nice
    I've seen a few set of those bones rusted out at that seam. You've just proved them usefull.
  22. Joe Rosales
    Joe Rosales
    They were in decent shape.
  23. koolbeans
    koolbeans
  24. Joe Rosales
    Joe Rosales
    Some brackets for the rear wish bones that will be welded to the xmember transmission mount.
    53BBF218-8AB1-417F-BAD6-D8FAF736DA9D.jpeg 88E54851-0AB9-450D-8C33-3FDBE7FE9CEC.jpeg 4BECE6C3-56F5-4AD2-B668-83DFFF401C04.jpeg 72F2C877-8827-4240-ABA0-DEC0D8B3DE2E.jpeg
  25. Stogy
    Stogy
    :rolleyes:...Nice Layout in Bracketry...There is an Art Factor there absolutely
    Outback and Joe Rosales like this.
  26. Joe Rosales
    Joe Rosales
    Finally got the rear end all back together and officially a roller again for the last time. Everything looks and fits great with the Xmember. A few final touches to frame rails and then on to the steering box. I thought building a car was supposed to be easy.
    CE448FF0-6BD3-4116-A4B9-EE42E64EE9A9.jpeg 354D45DC-4A9A-4DFC-9910-091D5F8A6D97.jpeg D82A3908-BFAA-47E0-A5CE-7D5F8E531157.jpeg 86D7A5E9-25DF-47A8-A14D-92B2C2B1DA8E.jpeg
  27. saltflats
    saltflats
    from Missouri
    You started it :D
    And I'm glad you did and shared it with us. :)
    Stogy and Joe Rosales like this.
  28. Joe Rosales
    Joe Rosales
    Me too
    chryslerfan55, saltflats and Stogy like this.
  29. The 39 guy
    The 39 guy
    Just found your thread! Outstanding craftsmanship!! You should be very proud. I will be following along the rest of the way.
  30. Joe Rosales
    Joe Rosales
    Thank you, more to come
