Hot Rods MODEL A COUPE ROOF FILLER?
Discussion in 'The Hokey Ass Message Board' started by Nos1partstore, Sep 10, 2019.
  1. Nos1partstore
    Nos1partstore
    Anyone ever used a donor car to fill the roof of a 30/31 ford coupe? If so, what car/year did you use?
    thanks
    scrap metal 48 likes this.
  2. 60 Chevy wagon.
  3. Nailhead Jason
    Nailhead Jason
    64 to 66 mustang turned around backwards
    esrbuilders likes this.
  4. alchemy
    alchemy
    We installed a late 60's Chevelle turned backwards in a 28/9 coupe once. Would probably work well in a 30/1 also. The front of the Chevelle roof where it's curved over the windshield fits nicely on the back of the coupe roof.
    Might even be able to order up a brand new repro skin if you can't find an original in a yard.
  5. el Scotto
    el Scotto
    from Tracy, CA
    Fudge Packard, about 1951 or so
  6. Rex_A_Lott
    Rex_A_Lott
    Find somebody good with an English wheel and they can make one, save you from rambling through the junkyard. Good luck.
  7. paul55
    paul55
    from michigan
    I just used the rear half of a 2007-2013 Impala to fill my Chevy coupe. Might be close enough to yours. It fit prefectly!
  8. oldiron 440
    oldiron 440
    I can't believe no one stamps them out now.
  9. Atwater Mike
    Atwater Mike
    Lester Codd and I 'nibbled' the roof off a '69 Buick wagon, before Moomjean sent it to the crusher.
    Some t*******, and the curve was just perfect.
  10. Cleveland Coupe
    Cleveland Coupe
  11. brianf31
    brianf31
  12. Los_Control
    Los_Control
    from TX
    I thought Jonathan W was a interesting topic, he used a Gremlin car hood.
    As bad as that sounds, he actually had room for a 3rd brake light.
    The choice is yours. If you are trying to do a full resto and sell it for a full price ... good luck.
    If you trying to build it to drive it, you will have a lot more fun out of life.
    Used metal rather it be a 70's chevy or a 60's rambler, that is your new top.
  13. Vega wagon (if there are any of those left)...the roof has ribs that were the perfect length for a coupe.
  14. flt-blk
    flt-blk
    from IL
    07 Dodge Caliber worked on my truck, should be close on a coupe, it is a really low crown.
