Projects Seagrave 531 V12 Special BuiLd Up in Brazil
Discussion in 'Traditional Hot Rods' started by Drmalacarne, Sep 5, 2019.
  1. Fordors
    Fordors
    Your project is an inspiration and shows the true meaning of this old quote- We have done so much with so little for so long, that now we can do anything with nothing.
    Your ability and resourcefulness is amazing.
    cfmvw, 48fordnut, Stogy and 10 others like this.
  2. Drmalacarne
    Drmalacarne
    Yes, we will use 20 inch rims with 700/20 tires.
    Enviado do meu iPhone usando H.A.M.B.
  3. Drmalacarne
    Drmalacarne
    Thanks for the tip about the ignition wires colors!
    Your engine is beautiful!
    I’ll take a picture of the distributor cap soon.
    dwollam, BradinNC, Stogy and 2 others like this.
  4. Drmalacarne
    Drmalacarne
    Thanks Poletto!
    If you came to São Paulo I’ll be glad to show you my Seagrave project.
  5. Drmalacarne
    Drmalacarne
    Next step was to open and see inside the differential.
    The 1926 Buick has a 4.56:1 ratio. Combined with the 0.86 overdrive of the 5 gear of the Seagrave gearbox and the ultra low first gear I believe will result a good match.
    d0b65218-2b19-4b3e-9bb7-8821476e26dd.jpg f7b4c3ca-279a-49c1-9de1-233444041b92.jpg
    Ver good looking for a 1926
    The axles was resurfaced and will have new screws
    d772ac80-a24d-493c-a5ae-d8f882cc1143.jpg 463bbbb8-242c-4c78-abd3-8df7f735d903.jpg 0b8c1fbb-e278-4ca2-8e9b-536771f12a78.jpg
    The original Buick radiator shell was abandoned for a totally custom one that will do having the 1932 DeSoto shell as inspiration.
  6. Drmalacarne
    Drmalacarne
  7. WOW, great thread- thank you for posting!!!
    I'm really looking forward to reading and seeing more of your build, but I'd be concerned about using an early GM rear end- they are known for being weak, especially the axles.
    Deuces, loudbang and Drmalacarne like this.
  8. Drmalacarne
    Drmalacarne
    That’s a good point!
    Let’s see if it can handle the V12!
    Stogy, chryslerfan55, Deuces and 4 others like this.
  9. Drmalacarne
    Drmalacarne
    Meanwhile we put back some engine aggregates.
    9ec93f0c-5109-49c3-9d49-fed6152c3738.jpg 81228ef4-2254-48ce-a8a2-7110cfead193.jpg
    Zenith Model 29 carbs.
    Timing chain, gear and cover.
    Water/Oil exchange heater.
    Spark plugs with wires and distributors caps.
    4900e61c-d1e3-4317-b353-dd8e3bfb666f.jpg 18a5dbc0-ef59-4e94-bbee-cf1f931925e1.jpg
    flyin-t, brEad, JUNK ROD and 19 others like this.
  10. pumpman
    pumpman
    If that engine runs any where close to it's looks, oooh boy!
    41 GMC K-18, Thor1, loudbang and 3 others like this.
  11. Boneyard51
    Boneyard51
    It’s odd that the exhaust exits in the front of the engine! I guess that because of the daul distributors? Are the manifolds interchangable? Did the original single distributor V-12 exit in the rear? Excellent work ! You guys seem to have the ability to do ANYTHING!
    Bones
  12. Drmalacarne
    Drmalacarne
    And it runs!!
    brEad, flyin-t, VANDENPLAS and 43 others like this.
  13. 1-SHOT
    1-SHOT
    from Denton
    That's super neat. Now you heard the noise you will work harder to complete keep up the outstanding work
    41 GMC K-18, Deuces, Stogy and 2 others like this.
  14. drtrcrV-8
    drtrcrV-8
  15. CBoyd
    CBoyd
    You guys are doing a great job. Can't wait to see it when it's done!
    chryslerfan55, Deuces, Stogy and 2 others like this.
  16. 52HardTop
    52HardTop
    Hah hah, that is so cool! Congratulations on the first start up. We had no doubt. You guys are a joy to watch.
  17. Corn Fed
    Corn Fed
    Neat project. It even makes little boys excited!
    Deuces, Stogy, loudbang and 2 others like this.
  18. Drmalacarne
    Drmalacarne
    The water pump was opened and all bearings and seals were changed.
    be438a48-ef91-49f0-802d-7520a1c2a7db.jpg f4a5a1fb-1ce8-45b7-84e5-c819b97b1c06.jpg
    Tim, JUNK ROD, 41 GMC K-18 and 14 others like this.
  19. pumpman
    pumpman
    Yup, sounds like it looks!
  20. tubman
    tubman
    Get 'er tuned up! These things run extremely smooth and will idle easily as low as 300 rpm. When I had my Seagrave, I'd take it to cars show and bet the locals a beer that I could start it with the crank that came with it. I drank a lot of free beer over the years!:D
  21. Drmalacarne
    Drmalacarne
    Maybe mine could start with a crank too!
    So, isn’t this a legend?!?
  22. tubman
    tubman
    Nope. The more cylinders, the easier an engine is to start, especially with a good ignition. I had a 4 cylinder Yamaha snowmobile (do you have those down there?) which was the easiest manual starting machine I have ever seen. Since it was a 2 cycle, there were four firing impulses with each revolution which meant that it fired as much in one revolution as a single cylinder did in 4 revolutions.
    The typical "pull" on a hand crank is 180 degrees; in that time, a 12 cylinder will fire three times, one or two of which will be at the right time. That's why you pull the crank on a four cylinder until the piston is on the compression stroke. Then, you re-position the crank and give it a pull to make sure that you get a ignition cycle when you finally pull the crank. If you don't do that with a 4 cylinder, your chances of getting it started are not good.
    (If an engine has a HUGE displacement, this theory obviously goes out the window.)
  23. This is a damned nice build going... MUCH talent in that shop
    Wish I had even half of the talent they got.
  24. loudbang
    Man you guys work FAST. :)
  25. Drmalacarne
    Drmalacarne
    The first friction disc we made was a little thick. So we put it off and remade.
    ec560cfe-f6b7-475c-aab7-1854a7e83bba.jpg 8ad6a8cf-7657-48b1-942d-d2c4b184e3c8.jpg
    JUNK ROD, 41 GMC K-18, Thor1 and 10 others like this.
  26. Ralphies54
    Ralphies54
    Following this build very closely, love those Seagrave's, When I joined our local Fire dept. we had 3 flathead powered seagraves,2 pumpers and a truck, as the years went by and things got upgraded they were repowered with Detroits and Allison trans.
    I recall the 3 flatheads and tranys lining the wall at the back of the station, sat there for years and then slowly began disappearing one at a time. I think they just walked away and nobody realized it till one day they were gone.
    Beautiful,dependable engines sad they are gone. Ralphie
  27. ClayMart
    ClayMart
    OK. This clutch and flywheel combination is making my brain hurt. :mad: I'm familiar with Borg & Beck, Long style and diaphragm clutches. But what exactly do you call one these self- contained clutch and flywheel ***emblies? o_O
    It appears to have a diaphragm spring but with a built-in release bearing . . . ? :confused: I'm guessing that these might have been fairly common on big trucks and other heavy-duty equipment? Must have been fun to resurface down inside of that flywheel. :rolleyes:
    41 GMC K-18, Deuces, loudbang and 2 others like this.
  28. Drmalacarne
    Drmalacarne
    We bought a new set of 4 red coils and will put them through the firewall.
    So we made special aluminum collars to them.
    72fc3b3c-f1fc-48c5-bfd0-56a4ce8077ff.jpg 9cf1a966-b03b-444e-9633-a2a5cc8f79b6.jpg 315e68f8-4b77-417d-88b4-701128a5fcd4.jpg
  29. j hansen
    j hansen
    Subscribed.Nice job!
  30. ClayMart
    ClayMart
    Now this ignition system is making my brain hurt! :eek:
    Deuces, chryslerfan55 and Drmalacarne like this.
