Customs Riviera mild custom.
Discussion in 'The Hokey Ass Message Board' started by flynbrian48, Nov 16, 2018.
  1. flynbrian48
    flynbrian48
    I pulled the doghouse, adjusted the p***enger door (after drilling and tapping three of the sis bolts broken off in the door), then degreased and power washed the engine. Which in the interest of common decency I cannot show you... IMG_2682.JPG IMG_2684.JPG IMG_2687.JPG
  2. Pug}{maN
    Pug}{maN
    from adrian mo.
    Looking awesome
  3. Well, glad you're okay, sorry about the loss of the Pontiac. Keep plugging on the Riv.
    Will you be driving the roadster to the fairgrounds this weekend?
  4. flynbrian48
    flynbrian48
    Nope. In an apparent effort to make my last 6 weeks of work before retirement as miserable as possible, I have been scheduled to work Friday, Saturday, and Sunday. Or maybe this was to simply reinforce my decision that I've been working long enough. Whatever.
    OahuEli, Bandit Billy, belair and 5 others like this.
  5. Congratulations on your retirement decision. If it's any consolation, I had to work until the very last possible day prior to retirement. They forgot to book in a replacement supervisor so t hat I could just come in and say goodbye to everybody, you know coffee doughnuts, stuff. It was a night shift.
  6. flynbrian48
    flynbrian48
    Since the Riviera is to become our new tow pig, I'm going to put a frame hitch on it. I cut the lock section out of the rear valance panel to straighten it, in the photo you can see car's rear crossmember, a simple "C" channel. My plan is to box this in with like 1/8" stock, box in the now un-boxed last foot or so of the frame horns, make some diagonal braces (now that original gas tank has been replace with one that has different profile) from the crossmember to the horns, and put the receiver where the fuel filler used to be. That's now on the drivers side in the catwalk panel above the deck lid, as the new tank has a left side fill snout. Seems like it'll work... 71081511_10220832412862765_1693936269773504512_n-2.jpg 70773657_10220832412942767_2879329861736857600_n.jpg
  7. flynbrian48
    flynbrian48
    Some progress on the Riviera. I pulled the mangled original rear bumper, and cut the section of the tail valance panel out that had been crushed. It was easier to work it back into shape on the bench and weld it back in, which is what I did. Today I finally got the front inner fenders and core support painted, my outdoor paint booth worked pretty well with the catalyzed tractor enamel. 71081511_10220832412862765_1693936269773504512_n.jpg 70773657_10220832412942767_2879329861736857600_n.jpg 70172693_10220874601797462_4590596303074885632_n.jpg 71069112_10220874601757461_4623980293592711168_n.jpg 71144993_10220874602477479_6251841489404428288_n.jpg
  8. Just Gary
    Just Gary
    This is a really cool build, Brian.:cool:
    Rivieras are one of the very few cars that I thought couldn't be improved by customizing (beyond simple lowering & badge removal (nosing & decking)).
    You're proving me wrong.:oops::)
  9. flynbrian48
    flynbrian48
    Thanks! Really all I'm doing customizing it is removing the front bumper, but it does make a huge difference in the appearance. We'll see how well the headlights work behind those grills. ;):cool:
    chryslerfan55, loudbang and Just Gary like this.
  10. flynbrian48
    flynbrian48
    Back on the Riviera! Rear brakes done, new vacuum booster and M/C. Pay no attention to the thing to the right of the M/C.
    LAROKE, OahuEli, loudbang and 2 others like this.
  11. lippy
    lippy
    from Ks
    Ahhh Haaaa.:D Boy that frontend looks cool. I bought a buick too Brian. Lippy
    loudbang and flynbrian48 like this.
  12. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Have always loved 2 different Rivieras..... early fronts with the clamshell headlights and the later boattails. Would love to graft an early front to a boattail (though it wouldn't be traditional). Probably something that looks better in my mind, but I can dream.
  13. Bandit Billy
    Bandit Billy
    ^^^^A buddy of mine used to say that until he had too many beers and went for it, grafted a mustang fastback to a 68 cougar, not good. Dreaming is better than doing sometime.
  14. flynbrian48
    flynbrian48
    This kicked my ****. I had to hog out the center hole in the firewall, as the new booster's neck is 2 1/8" diameter, and wouldn't fit through the 2" hole. Then, from inside the cab, on my back on the floor under the dash, maneuver the pushrod yoke over the pin in the brake pedal, with the booster and M/C hanging from tarp straps on the hood hinge so I could pivot it as I pried the yoke over the pin with a screwdriver. I'm getting to old for this contortionist stuff... Then the power window switch in the p***enger door failed, I guess it's corroded points. I took it apart to clean the contacts, which I'd done with the other switches in the car, this one turned into pot metal dust and fragments of bakelite. The good news is, the window motor works fine jumping it, so I just gotta get a new switch. Tomorrow, we put the new fuel pump in and wire up the brake light switch, which has the torque converter unlock switch as well. ONWARD! 81161209_10221901663633366_4966347826272403456_o.jpg
    chryslerfan55, 62hotcat and loudbang like this.
  15. rockable
    rockable
    Brian, whatever happened to this build? @FlynBrian
    stanlow69 likes this.
  16. SS327
    SS327
    That’s another one we don’t talk about!
  17. In_The_Pink
    In_The_Pink
    Same here. Pretty challenging to improve upon the looks of an early Riv, but this mod definitely improves things.
    Also, consider keeping the white exterior color. IMHO, they look great in white.
    OahuEli likes this.
