Features Corvette hot rods - picture thread
Discussion in 'The Hokey Ass Message Board' started by KING CHASSIS, Jan 1, 2011.
  1. Stephen Baxter
    Stephen Baxter
    I had the frame blasted and then started to move the springs inside the frame. I bought Cal_Trac springs and traction bars and sliders. 20190319_074530.jpg 20190406_172522.jpg 20190411_153226.jpg 20190411_152939.jpg
  2. loveoftiki
    loveoftiki
    from Livonia,Mi
  3. enloe
    enloe
    from east , tn.
  4. loveoftiki
    loveoftiki
    from Livonia,Mi
    And and it runs as bad *** as it looks...
    enloe, loudbang, mkebaird and 2 others like this.
  5. Stephen Baxter
    Stephen Baxter
    Next I notched the frame for more tire clearance. I cut it in half and moved the piece I cut off to the inside and welded it up. I said before I had a 57 Pontiac rear end but I sold it and got a 9" Ford. I kinda wish I still had it. I figured the ford would be better.
    31hotrodguy, enloe, loudbang and 3 others like this.
  6. Had the 57 out banging gears today!
  7. Looking good! But you should start your own thread on this build. I’m sure most of us want to see more of it.
    mkebaird, Deuces, loudbang and 2 others like this.
  8. Stephen Baxter
    Stephen Baxter
    Got the frame primed and painted and the motor and trans installed
    31hotrodguy, Deuces, loudbang and 2 others like this.
  9. Stephen Baxter
    Stephen Baxter
    I made new front engine mounts and notched the X member lowering the motor and trans 2 1/2 inches. That gives me better drive shaft angle. I also cut the X member and welded tabs to bolt it up so it can be removed.
  10. 65pacecar
    65pacecar
    from KY, AZ
    Nice car, Cool Kitty
  11. “El gato *****” and that place is my buddies, and yes he is a cool cat!
    Deuces, loudbang, 65pacecar and 2 others like this.
  12. jimdillon
    jimdillon
    Stephen glad you are taking us along for your build-all good stuff. Glad to see another solid axle drag car come to life. I am including pictures of my 60 Vette ch***is that started life with a small block that ran gas in the 60s to a big block modified production car (although occasionally ran gas) from Alabama.
    They both have sliders and also notice the cut down in the x-frame. Ricky Moore who built the ch***is to where it is today, told me the cut down not only helped with the driveshaft angle but also helped with pulling the trans (Doug Nash 5-speed) at the track. Of course the car did not have the four link in the 60s and it had a Pontiac rear at the time but he updated it over the years to the Dana 60 and added the four link. The Pontiac you had may have been cool but I suppose you can argue the Ford 9" will take a bit more punishment (although some may debate that). Vette -12-13 005r.jpg
    Your build is looking great-keep up the good work.
  13. 65pacecar
    65pacecar
    from KY, AZ
  14. 65pacecar
    65pacecar
    from KY, AZ
  15. Chuck Norton
    Chuck Norton
    from Division 7
  16. Deuces
    Deuces
    Hmmm... Friday the 13th and a black kat crossing your path....:confused::D
  17. loudbang
  18. gotta56forme
    gotta56forme
    from Seattle
    don't tell me there isn't any subliminal messaging going on there...
  19. loveoftiki
    loveoftiki
    from Livonia,Mi
  20. jackal396
    jackal396
  21. j hansen
    j hansen
  22. loudbang
  23. loveoftiki
    loveoftiki
    from Livonia,Mi
  24. kaspar
    kaspar
    65pacecar, loudbang and chryslerfan55 like this.
  25. Jalopy Joker
    Jalopy Joker
  26. Stephen Baxter
    Stephen Baxter
    20190317_154759.jpg My friend Wheeler working on his 62 in the Navy base hobby shop at Cecil field in 72 or 73 he had 3 fuel injections and he wanted to trade me one for a holley and high rise. That is where too fools met. Lol I wouldn't do it
  27. kaspar
    kaspar
    Just had to check the data on that car! It was first registered in Sweden -77, I wonder if it had that paint job when it was imported, or if it got the paint over here.
    The car has a manual gearbox and 275 kW, which translates to roughly 350 hp. I guess someone was really keen on the "cool kid on the block"-***le back in -77! :)
    Current information in the Swedish Transport Agency's database suggests that it's been restored to stock configuration - color: red, tires: GR60-15.
    chryslerfan55, 65pacecar and loudbang like this.
  28. loudbang
  29. 65pacecar
    65pacecar
    from KY, AZ
  30. quick85
    quick85
    Uh-oh, at least four '67 Camaros in this pic.
