'35-6-7 Ford trucks-swap grilles?
Discussion in 'The Hokey Ass Message Board' started by Jeem, Apr 30, 2007.
  1. Jeem
    Jeem
    Alliance Vendor
    Is it a bolt for bolt swap or not even close to put a '35 or '36 grille shell on a '37 PEE CUP?
  2. bdrake
    bdrake
    Now why would you want to do a thing like that :)
    The fenders are the same so no problem there.
    The inner fender panels are different on the '37 so those would need to be swapped out.
    Then you would need to mess with the hood panels. Since the '37 cowl is different the older hood would not be a bolt-in and the stock one would most likely be to long.
    Here are some cropped pics of the grille to fender on a '36 and and on my '37 truck. The '36 grille has more contact with the fender while the '37 uses around half the contact. A quick glance at the inner fender panels look the same but they are different to make up for how the grille meets the fender.
    [​IMG] [​IMG]
    Cheers,
  3. pasadenahotrod
    pasadenahotrod
    from Texas
    I would guess because the 37 Pickup Grille is the most desireable and expensive grille for a Ford Commercial vehicle, bar none.
    kidcampbell71 likes this.
  4. Jeem
    Jeem
    Alliance Vendor
    Thanks Bill, exactly the info I was looking for.
    So, if I bolt up a '36 grille and inner fender panels to the '37 and modify the leading area of the 37 hood tops, I'd be set? I'm thinking of making new hood sides anyway.
    Not even sure which grille I prefer anyway. I'll be looking and wanted to know if I could ****** up a '35 or 6 to use.
  5. Roothawg
    Roothawg
    The 35 is the narrowest (depth wise), the 36 gives you more room for a radiator but the 35 looks racier.
  6. bdrake
    bdrake
    Yea, looks like the hood would be the only problem area. A little t*******, maybe a little welding should make everything right. Works good on the drawing board!
    So did you buy a '37? It took me three '37 grilles to piece together the one on my truck. Didn't want to fork out the green for one of those nice ones.
  7. Jeem
    Jeem
    Alliance Vendor
    Good to know.
    Bill, the deal will go down soon. I'm pretty excited, actually. I've been forewarned about the grille situation, but I'm just stupid enough uhh, I mean motivated enough to proceed with it....
  8. TUDORTOBY
    TUDORTOBY
    Hey guys. I just bought a 36 pickup that was too cheap to p*** up. I have two 36 grilles (both are rough). I like the 35 grille better, and since I don't have a radiator yet anyway, I'm thinking of running a 35 grille on my 36. My question is, would the 35 grille work with my 36 hood and fenders?
    kidcampbell71 and harpo1313 like this.
  9. Budget36
    Budget36
    Yes, it will work. But note that the front fenders you have are '36 (at least the one on the left it, can't see the bottom of the one on the right). Close up shot of yours doors will tell what they are as well.
    Also appear to be '36 hood sides too.
    Take real good care of the rear fenders, really hard to find.
    Edit:
    I'm an idiot, for some reason I read your post as buying a '35.
    Carry on ;)
    Clay Belt and TUDORTOBY like this.
  10. TUDORTOBY
    TUDORTOBY
    Thanks for the info! Yes the doors are 36 as well as both fenders. All four fenders have been repaired multiple times... the rears are pretty rough but they will haft do for now. Build thread will be coming soon.
  11. RMR&C
    RMR&C
    from NW Montana
    If you use the '35 shell you need the thinner '35 radiator or similar. '36 rad is much thicker in the top tank area.
  12. Roothawg
    Roothawg
    Swing by the shop if you are ever in OKC....if ya wanna talk 35-36 stuff.
  13. TUDORTOBY
    TUDORTOBY
    ^^^ yeah I'll probably just have to break down and buy a new radiator. I'm guessing they a different from the p***enger car radiators.
  14. TUDORTOBY
    TUDORTOBY
    OK will do man thanks. Obviously I'll be in the market for a 35 grille and various other parts. So if any thing pops up, hit me up.
  15. Roothawg
    Roothawg
    The radiators are the same 35-36.
  16. TUDORTOBY
    TUDORTOBY
    For all or pickups only?
  17. Roothawg
    Roothawg
    Pickups only. I have no idea about p*** cars.
  18. TUDORTOBY
    TUDORTOBY
    OK. Appreciate the info man.
  19. RMR&C
    RMR&C
    from NW Montana
    This is not my experience......had a '36 pu in the shop the owner wanted to swap a '35 shell onto. No go, the top tank sticks out forward of the core a couple inches. Not an issue with the deeper '36 shell.
    Pretty sure it was the original rad on the truck...everything else fit perfect.
  20. Roothawg
    Roothawg
    I just mocked up a 35 shell with a 36 radiator, then swapped to a 36. I did have some issues, between different grilles. But, the Ford part number was the same for both years.
  21. 1946caddy
    1946caddy
    from washington
    The 35 cross member has one mounting hole while the 36 has two different mounting holes for the radiator.
  22. Roothawg
    Roothawg
    This is true.
  23. Ks Muleskinner
    Ks Muleskinner
    The Ford ch***is parts book lists 4 different part numbers for 35-36 pickup radiators; same part number 51-8005, with 4 different suffixs. A=1935, B=1935 extra cooling, C=1936 and D=1936 extra cooling.
  24. 28rp
    28rp
    I have all three radiators mentioned-35,36 & 37 in my shop. They are all markedly different to look at. I also have both 35 & 36 grilles and they don't fit any radiator other than the one they are meant too. All these were gathered up to suit my too long in storage 35 pickup.
  25. Ive seen 37"-38"s with 37 p*** car front sheet metal.Not a bad look.
