Features What's on your.... AM radio?
Discussion in 'Traditional Customs' started by 1953naegle, Sep 13, 2019.
  1. 1953naegle
    1953naegle
    Anyone else still have an old vacuum tube AM radio in their ride? I have a push ****on one in my 53' chevy and think it's cool, but it's rare that I can ever find something other than talk radio stations to listen too. Tonight I found a hispanic station. I would love it if someone in the greater Houston area put up an AM oldies station, but I'm probably a few decades too late.....
  2. Texas Webb
    Texas Webb
    Yep the 50's and 60's had some good music.Too much garbage today.
  3. Truck64
    Truck64
    from Ioway
    It probably needs a recap and an alignment for best selectivity & reception. At night the AM band should open up, and pick up stations from all over. Could try tuning a weak but steady station near 1400 and peaking the antenna trimmer screw for maximum volume.
    Deuces, dana barlow, 302GMC and 2 others like this.
  4. Nothing!
    spinner and 1953naegle like this.
  5. 1953naegle
    1953naegle
    I've been thinking about sending it out to be serviced. It's working off of a voltage reducer but the volume has to be cranked up all the way to hear anything. I've also thought about getting it upgraded to modern AM/FM guts, but I kinda like having to wait for it to warm up, and sometimes you can see a little bit of the glow from the tubes from underneith.
    Texas Webb, spinner and Deuces like this.
  6. blowby
    blowby
    from Nicasio Ca
    My ignition system
    Mimilan, spinner, ccain and 4 others like this.
  7. Truck64
    Truck64
    from Ioway
    If you know what end of a soldering iron to hold it's not difficult to replace the power supply capacitors and a resistor or two. This would help quite a lot. Alignment would be a little more difficult.
    spinner likes this.
  8. Flathead Dave
    Flathead Dave
    from So. Cal.
    KFI 640 on my AM.
    Watch out for those old radios. They play old songs and have old news...
    spinner, Deuces, williebill and 6 others like this.
  9. TrailerTrashToo
    TrailerTrashToo
    The vacuum tubes gradually wear out (stop producing electrons) - basically, the vacuum tube may glow, but, little amplification is taking place (the lights are on, but, no body is home...). The old tube equipment was a constant maintenance item. Every year or so, the radio or TV would stop working well, and vacuum tubes were replaced.
    Finding vacuum tubes might be a problem. I gave away my tube tested over 40 years ago, so I have zero current knowledge about antique radio parts availability.
    Deuces, lothiandon1940 and 1953naegle like this.
  10. 1953naegle
    1953naegle
    All I need is a briefcase in the trunk with an AM transmitter and an MP3 player loaded up with old songs, news, and programs!
    Deuces, dana barlow and arthurC3 like this.
  11. Truck64
    Truck64
    from Ioway
    TVs ran tubes hard, and hot, esp. color televisions. Vertical sweep tubes and stuff like that. Radios, not so much. They last a long time. Maybe not at 100% but most people don't listen to them constantly either, and a weak tube won't usually cause issues except maybe an oscillator.
    About 20 years ago as an experiment I left a restored radio from 1942 running 24/7 for over two years and gave up seeing how long they would last. I used it fairly often since that time and the tubes finally gave up the ghost this year after another extended run.
    Tubes are plentiful and cheap for car radios. The real culprit in unreliability is the power supply, coupling, and byp*** capacitors.
    Deuces and TrailerTrashToo like this.
  12. s55mercury66
    s55mercury66
    from SW Wyoming
    It used to be Oldies 940 KMER, but they sold out a year ago in June, and came back on the air this summer as a copycat country station, playing the same thing as their FM counterpart. Bummer. There used to be another oldies station in Rock Springs, but it went talk radio several years ago, which is enough to make me slit my wrists. There are only two types of music here as a general rule, country, and western. Things are fortunately a little better down in the Salt Lake valley, but I sure miss my old AM station.
  13. I recall that the radio DJs were really entertaining characters back in the late 50s, early 60s. (the 45 record days) The equipment was a lot more manual and they had to have a real gift of gab to fill the in-betweens so there was never any dead air.
    I've seen some NOS vac tubes being sold on fleaBay lately by eastern Europe and Russian sellers. I have no idea if they would be the right stuff for the old car radios, though.
  14. wheeltramp brian
    wheeltramp brian
    I get k-mozart.a cl***ical station .itspretty good .can only listen when the 29 isn't running as it's too loud.
  15. lothiandon1940
    lothiandon1940
    Loved AM radio back in the 60's, but then that's all I had and stations were plentiful. WCAO in Baltimore, WEAM in Alexandria, Va., WPGC in Prince Georges County, Maryland, WOOK and WOL in Washington, D.C. It's a romantic notion to try to relive those days. Technology has improved so much with the FM stations of today. Then again, an AM radio hooked up to a reverb unit, some mood lighting, parked with your favorite girl and, well, it does bring back some special memories.:D;)
    Deuces likes this.
  16. Deuces
    Deuces
    The BiG 8 many many years ago... CKLW AM800... I miss those days..... :(
  17. slowmotion
    slowmotion
    WCFL out of Chicago in the wee hours was the ticket...
    Deuces, hrm2k and quick85 like this.
  18. Truck64
    Truck64
    from Ioway
    Those are actually new production vacuum tubes. Audio outputs of the type used in guitar amplifiers and stereo hi-fi. Those always wore out relatively quickly and unfortunately are easily roasted in defective equipment. NOS audio tubes from the big US and European makers from the 30s through the end of the vacuum tube era have dried up and command very high prices, so they tooled up to re-issue them. They sound fine but they don't last anything like the real thing.
    Radio and Television tubes aren't usually expensive and can't give them away, $2 or $3. Replacing tubes in a radio is usually a waste of money, they need a fresh DC power supply to get back in business. Capacitor technology then wasn't very good, and the waxed paper & foil design are shorted out by now.
    The Shift Wizard likes this.
  19. tubman
    tubman
    There was a good "Oldies" station out of Aitken, MN up until a few years ago, and then they changed their format. I gave up and installed a CD player so I can listen to what I want to hear. It was kinda tricky on a 6 volt positive ground system, but we did it.
  20. Mike51Merc
    Mike51Merc
    ….a 3.5mm audio jack plugged into an iPod.
  21. ffr1222k
    ffr1222k
    I still have the Town and Country radio that was in my 56 Ford 55 years ago. I also had a parts radio I picked up laying in the mud at a junkyard 50 years ago. My best friend growing up just repaired the original radio. He replaced the ******** and all the capacitors and a few resistors. I had enough good tubes between the 2 radios.
    This radio is going in the 56 Victoria I bought back in March but first I either have to swap the dash or get the hole filed in where someone cut it to put in a DIN radio.
    1953naegle likes this.
  22. Elcohaulic
    Elcohaulic
    We have a couple decent doo wop radio channels here in Pittsburgh.
    WEDO 810 and WKFB 770..
    Deuces and 1953naegle like this.
  23. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Second on KFI 640. Listen to it a lot when driving. Tim Conway Jr. is great. Love how John and Ken publicly call out the crooked politicians and policies.
    When I was a kid, late at night in the early 70's, my Brother and I used to see how distant a signal we could grab off AM. From Socal, we used to be able to tune to an Iowa station as well as a Navajo nation powerhouse in New Mexico. We'd catch station call letters, but they would seldom state the city so we would have to listen for clues in commercials such as car dealerships where they'd mention their city. Sometimes a map was utilized-all pre internet days so research was more work.
    Caught some Canadian stations too. West coast was strong, probably because of the skip up the Pacific. I understand in the early days, folks in NY and London, etc. listened to each others stations across the pond.
  24. v8flat44
    v8flat44
    WLEC Sandusky Ohio; mostly 50s 60s & some 70s. Ohio sports also.
    Can sometimes get an "oldies" station in the 900 range & a country station too.
    1370 in Toledo for unbiased news. All sounds good with the FLATTY rumbling in the background.
    Elcohaulic and Deuces like this.
  25. stuart in mn
    stuart in mn
    I like the sound of old tube car radios, but as mentioned there's not a lot on the AM band worth listening to these days. You can search at swap meets for one of those old FM converters they used to sell in the 1970s, or for a modern solution get a Redirad and plug your choice of music source into the radio: https://redirad.com
    Deuces and Desmodromic like this.
  26. My town has a station that broadcasts in both AM and FM. The venue is Americana* music and it's what on in my home and shop from morning 'til night and it's ****on #1 in all my cars. I usually listen to the FM band but I'll sometimes switch over to AM if I'm traveling any distance. I don't have anything with a survivor AM radio at the moment, but if I did I would make sure it was in good shape since I have access to an AM station I like.
    *"Americana is an amalgam of American music formed by the confluence of the shared and varied traditions that make up the musical ethos of the United States, specifically those sounds that are merged from folk, country, blues, rhythm and blues, rock and roll, gospel, and other external influences."
  27. HOTRODPRIMER
    HOTRODPRIMER
    I have heard of radios but I don't have one. :D HRP
    ct1932ford, dana barlow and Truck64 like this.
  28. Los_Control
    Los_Control
    from TX
    Here in a small west Texas town, we have a local AM station, they also play on fm, And I stream them through my pc in the shop. They play old country, 50's on up to some newer stuff. George Jones, Johnny Cash, Merle ... I'm ok with it. Our yearly cruise in, they play old 50's 60's rock & roll.
    More important I like to hear local news/weather, what the city council is up to, whats on sale at the grocery store this week.
    I found a stock AM radio for my truck and jumped on it, but installing it is a bit down the road yet.
    I listen to all types of music and have a large collection on the pc, but the am radio is my go to.
    Deuces, Elcohaulic and 1953naegle like this.
  29. Dennis D
    Dennis D
    1430 in the St. Louis area for oldies
  30. quick85
    quick85
    After getting knocked on the head I'm hearing WCFL (Chicago) with
    Joel Sebastian ("Put it in the groove and let it wail."), and WLS ("50,000 watts!")
    with Art Roberts and Jim Dunbar.
    A Thousand Stars -- Kathy Young and the Innocents
    Long Lonely Nights -- Lee Andrews and the Hearts
    You Can't Sit Down -- The Dovells
    Sherry -- The Four Seasons
    Money -- Barrett Strong
    Ruby Baby -- Dion
    And too many more.
    Deuces and 302GMC like this.
