Finally Got a Henry J
Discussion in 'The Hokey Ass Message Board' started by swade41, Oct 3, 2010.
  1. swade41
    swade41
    from Buffalo,NY
    Thanks, it might even do jackrabbit starts from a traffic light with this thing
    loudbang and enloe like this.
  2. swade41
    swade41
    from Buffalo,NY
    I actually ended my agonizing over trying to blend my new firewall work with the older "history" work on the rest of the firewall, something that has held me back on moving forward for a long while now.
    I finally just said screw it after trying several different attempts that left me unsatisfied with the results, not saying that I'm totally happy with this result either but I need to get moving on this one before the cold weather sits in. Plus you know the other thing, which is supposed to happen in a couple weeks, but I think I've got that beat...hopefully (knock on wood).
    I tried flat black last night, mostly because I had it on hand, the filler work really soaked it up and once seeing it this morning I thought about how oil mist from the breathers would show on it, so I switched to satin and put on 4 coats of Rustoleum's finest today. Hopefully this covers well over the filler, if not I'll just have to add a few stickers then..ha ha ha
  3. Baron
    Baron
    Looks fine Phil. You may want to run over it with some 320 or 400 and then give it a couple more coats, and that should cover well. Once the BB is in along with the headers, not going to see much of the firewall anyway. :)
    enloe, loudbang and chryslerfan55 like this.
  4. swade41
    swade41
    from Buffalo,NY
    That's what I'm hoping for, the distraction of the engine taking away from the mismatch of the new and old firewall. Today I was thinking of satin clear for easy clean up but I think I'm getting a little carried away on what this old car is about, a 20 footer that money is spent on going fast rather than trying to look good.
  5. swade41
    swade41
    from Buffalo,NY
    Washed away a couple years of dust and funk off the front suspension, nice to see it cleaned up, doesn't look so neglected now.
  6. swade41
    swade41
    from Buffalo,NY
    Firewall doesn't look to bad so I proceeded with installing the stainless insert, a tough lesson learned to see how accessible your mounting holes will be on the inside of the firewall. Me and my 15 yr old son fought with the stainless hardware for over 4 hrs, climbing over the roll bar, trying to lay across the fibergl*** racing seats, shoving your hand in a 2 inch gap behind the dash blind to put nylock nuts on. I had to remove the steering column, gauge panel, swinging brake pedal bracket, move wiring, ugh, should've just used aluminum rivets.
    Then I spent an hour and a half moving things to get the car moved forward under the chain fall on trolley and moving the engine/trans from the back section forward to the same spot. I blanketed up to protect my new shiny firewall and realized I was missing the motor mount bolts, where the heck did I put those damn things.
    What normally works for me working by myself is to thread the engine/trans nose first in between the radiator support loops and new shiny firewall until it's over the ch***is. Then I roll the car back until there's enough room to rotate the combo the correct direction in between the fibergl*** tilt front end and shiny new firewall, then lower chain, roll car forward, lower chain, roll car forward, lower chain, roll car forward, lower chain until it slides home and onto the motor mounts like a glove.
    kidcampbell71, enloe, Dooley and 2 others like this.
  7. swade41
    swade41
    from Buffalo,NY
    The new and improved "Badder" Bad Moon
    20190922_153334.jpg 20190921_192409.jpg 20190921_192500.jpg 20190921_192657.jpg
    Tickety Boo, enloe, TagMan and 7 others like this.
  8. Dooley
    Dooley
    from Buffalo NY
    That’s gonna haul ***
    loudbang and swade41 like this.
  9. swade41
    swade41
    from Buffalo,NY
    I even did the bucket brigade and gave the ol girl a much needed sponge bath, been awhile since I seen it with the layers of wood, drywall and bondo dust knocked off of it.
    Still looking like honey
    enloe, loudbang, LOST ANGEL and 2 others like this.
  10. loudbang
    Like the rubber glove blocking off the water pump. :)
    enloe and swade41 like this.
  11. Hemiman 426
    Hemiman 426
    from Tulsa, Ok.
    Looks good Phil!
  12. swade41
    swade41
    from Buffalo,NY
    I should've thought of that earlier, I had paper towels stuffed in there with a sandwich bag zip tied around it, moving it around always made it leak. I even tried spinning the pump to get the level down, still leaked out, as soon as I hooked the chain fall to it, it leaked, so in haste to save cleanup on the floor I pulled the glove and tied it on there, then thought damn, where was that idea a year ago...ha ha ha
    It'd probably look like a cows udder if it got to full ... ha ha ha
    enloe and loudbang like this.
  13. malibumonte78
    malibumonte78
    So glad to see you making progress on this thing again! Firewall looks great!
    swade41 and loudbang like this.
  14. swade41
    swade41
    from Buffalo,NY
    Thank you, crazy what you can do in a week's time when you actually set your mind to doing something.
    From mockup to finish, only about 5 yrs between the two..ha ha
  15. swade41
    swade41
    from Buffalo,NY
    I put spacers on top of the carbs to raise the scoop up, I like that better but still an option to run the Shelby 350 scoop depending on the height of filters I could fit under it. Thinking of it I guess that doesn't matter because only those small filters can fit inside of the Hilborn style scoop.
  16. Dooley
    Dooley
    from Buffalo NY
    That cast scoop looks pretty nasty
  17. chopped
    chopped
    Had one once, paid $15.00 for it. But it was 1963.
  18. swade41
    swade41
    from Buffalo,NY
    If I use it I'll polish it again, should've never had it sandblasted..lol..but I was going to powdercoat it to look magnesium.
  19. swade41
    swade41
    from Buffalo,NY
    That's pretty darn cheap and I bet the floors and rockers were still good
  20. loudbang
    Damn you got another new mesmerizing avatar. :eek:
    swade41 likes this.
  21. swade41
    swade41
    from Buffalo,NY
    Best Marylin Monroe photo ever
  22. FinnishFireball
    FinnishFireball
    I can't decide which I like more, your Henry J or your avatar. Both make my heart pounding!
  23. swade41
    swade41
    from Buffalo,NY
    I need a couple "air bags" like that, but they might poke my eyes out..lol
    Put my new heavy duty alternator mount on, 1/2 inch thick aluminum with a one inch thick solid spacer between the two arms, this baby is solid.
    Realized I forgot to m***age my toe boards for header clearance before painting that firewall, I had to breakout the BFH to make the needed room. So it looks like a little bodywork and paint will be in order, plus I have to find a new spot for the ignition box.
    Then I moved over to completing the front disc brake install, so off came the hubs and repacked the bearings, loaded the calipers, got all that on plus installed the 90/10 Lakewood shocks.
    Last night and tonight I sanded and polished by hand the old front runners, freaking back is killing me now from that, I need to find some kind of power tool to make this **** easier.
    And tonight I did the other one
  24. Baron
    Baron
    Nice to see you back on the Henry J. Be even better to see you in it, back racing !
  25. Dooley
    Dooley
    from Buffalo NY
    Getting there!!!
  26. swade41
    swade41
    from Buffalo,NY
    More blingy after using the Flitz polish and their buffing whell/ball thing in a drill, easier than the old spit shine method for sure.
    Not sure what's next on the list of things to do, sometimes I just have no motivation to do any of it, other days I stroll out there and find myself tinkering away. I need to clearance the stainless firewall a bit to be able to get the steering column in and out easier, maybe that'll be in a couple days after my back recoups.
    Baron, enloe and loudbang like this.
  27. henry's57bbwagon
    henry's57bbwagon
    Great work. Hope to get back to the HJ by the spring.
  28. swade41
    swade41
    from Buffalo,NY
    I visited this old thread looking for a photo that turned out to be plastered with Photobucket's b.s., so while I'm here I'll update it.
    It seems like I've got more accomplished than I have photos to prove but maybe I really haven't accomplished much at all lol
    When I went to rebuild the carbs it turned out one carb had heli-coils holding the bowls on, so I found a pretty close match with the original carb having front/rear power valves and new only having one.
    So I cut the air horn off the new carb, went through it to match the other carb and have an equal pair other than being different colors.
    20201011_161730.jpg 20201011_153548.jpg 20201013_130100.jpg 20201017_192120.jpg
    Took some aluminum flat bar drilled some speed holes in it to mount my fuel regulator to.
    59Apachegail, Dooley and Baron like this.
  29. swade41
    swade41
    from Buffalo,NY
    Next up was a new 4 core radiator, so I had to cut the radiator mounts off the frame and move them to work with the new radiator.
    59Apachegail, enloe and Baron like this.
