Hot Rods Qucktime for 390 Cad.....anyone???
Discussion in 'The Hokey Ass Message Board' started by DeadFast 33, Nov 8, 2017.
  1. DeLuxe 32
    DeLuxe 32
    Hey Rex, what were your thoughts about this bell housing? There's a few ridiculously cheap on eBay...might get on seven though I have the wilcap set up.
  2. Sutton Speed
    Sutton Speed
  3. lumpy 63
    lumpy 63
    Awesome! A Cad 390 is on my bucket list. At least now I have the trans adapter, thanks for the tip!:D
    Roothawg and loudbang like this.
  4. lumpy 63
    lumpy 63
    Bump For anyone looking for a Cad trans Adapter.
  5. Beanscoot
    Beanscoot
    The ad says it fits a 365 and 390 Cadillac. Does anyone know if the 429 Cadillac is the same bellhousing pattern?
  6. ls1yj
    ls1yj
    from Kentucky
    429 is not the same block.
    This bell works up to 62
  7. lumpy 63
    lumpy 63
    Is1yj, you mention a chrysler truck starter, is that a bolt up to the quicktime bell? And do you have a part # or model application? Thanks in advance, Lumpy.
    Roothawg likes this.
  8. Sutton Speed
    Sutton Speed
    Do keep in mind this bell is for a Ford T5 or TKO, not the GM bolt pattern.
    Roothawg and lumpy 63 like this.
  9. ls1yj
    ls1yj
    from Kentucky
    Lumpy
    The 90’s dodge truck starters are what was used in design. I don’t know part number, but a 318 starter should work for application
  10. earlymopar
    earlymopar
    The most often referred to Dodge truck starter is a 1992 Dakota starter from a 318. The body of this starter is "mini" in size but it is not a gear-reduction starter like some of the aftermarket starters.
    - EM.
    ls1yj, Roothawg and lumpy 63 like this.
  11. Beanscoot
    Beanscoot
    "429 is not the same block.
    This bell works up to 62"
    Thanks. But yes, I do know that a 429 Cadillac is not the same block as a 390 Cadillac.
    Much like a 351W Ford is not the same block as a 302 Ford, yet those two Fords used the same bellhousing.
    The down side to the dirt cheap Quick Time bellhousing is that it probably means that it's being discontinued.
    I just checked and it's no longer available online via that link. I guess you guys bought them all!
  12. Roothawg
    Roothawg
    There are millions of the Ford T5's out there. Well, there were, but now that I need one, they will all disappear.
  13. lumpy 63
    lumpy 63
    No shortage out west:rolleyes:
  14. Roothawg
    Roothawg
    If you ever want anything to skyrocket in price, just let me know and I'll start looking to buy one. :cool:
    lothiandon1940 and lumpy 63 like this.
  15. lumpy 63
    lumpy 63
    Just looked at the Holley site, says "no longer available online"
    kidcampbell71 likes this.
  16. pkhammer
    pkhammer
    Maybe I got the last one from Holley. I ordered mine Tuesday thanks to a tip on here and it shipped Wednesday. It's supposed to arrive today. I'm counting on this fitting my 331 although it only lists 365 and 390 engines. My two 331s are '55 models without the cast in bell, only available the one year.
  17. lumpy 63
    lumpy 63
    It will fit 55 331:cool:
    Automotive Stud, ls1yj and pkhammer like this.
  18. earlymopar
    earlymopar
    Some additional information on small Mopar starters. There is an even smaller starter model used on 2005-2008 Dodge Rams with a 5.7 and a MANUAL transmission. This one apparently is a gear reduction design and is not offset like the Mopar or Nippondenso "mini" gear reduction starters. The 2005-2008 Ram starter's housing is directly in line with the starter drive axis making it smaller overall. The "Mini" starter is shown below compared to the 2005-2008 Ram starter.
    - EM
  19. 51box
    51box
    from MA
    If anyone has one of these Cadillac quick time bells that they want to sell let me know. Thanks
    ls1yj likes this.
  20. lumpy 63
    lumpy 63
    I have read several post's about cad trans adapters and several people stated that the 390 cad crank isn't drilled for a pilot bushing..Mine had a steel plug in it and once I pulled it out the machined surface is now .520 deep ...works for me:cool:
    warbird1 likes this.
  21. lumpy 63
    lumpy 63
    Here is the wilcap flywheel. Part number FW CAD-EFM
    It has a 130 tooth ring gear and it fit perfectly. Photo6.jpg Photo7.jpg Photo8.jpg
  22. lumpy 63
    lumpy 63
    Here is what I have found with the ****ter shield. The holes in the block plate for the starter mount are only drilled to 5/16" and the starter bolt are 3/8" so these two holes need to be drilled. Also, the lower two bell housing mounting holes are drilled and tapped for 5/16", don't know why as the caddy block is drilled and tapped for 7/16" bolts. I am gonna just drill them out and mount it the way Cadillac intended. Photo1.jpg Photo2.jpg
  23. lumpy 63
    lumpy 63
    I'm working on some starter issues now, I purchased a Power Master gear reduction starter but it doesn't fit as well as I like. Today I will try a factory Mopar starter. Will post my findings. :D
    Barrelnose pickup likes this.
  24. lumpy 63
    lumpy 63
    So after work today I installed a starter for a 92 Dodge Dakota with a 318. It still didn't sound great so I removed it and noticed two small raised edges on the bell that were protruding slightly past the opening of the block plate, I ground these down with a carbide burr to match the block plate. Cranks and sounds just fine now:D
  25. 51box
    51box
    from MA
    Looking good @lumpy 63 thanks for posting up the info
    lumpy 63 likes this.
  26. lumpy 63
    lumpy 63
    One more note on this subject . the Wilcap flywheel is . 600 thick . the Cad crank flange is .500 thick . Most all Hi Po flywheel bolts I could find were 1 inch long or less. I found Crower flywheel bolts that are 1 .125 long , part # 78446A-6
    kadillackid likes this.
  27. mopacltd
    mopacltd
    Hadn't heard much from you lately and was wondering what you were up to.
  28. lumpy 63
    lumpy 63
    Interesting note on this , Trans Dapt actually had a listing for a 390 Cad to Ford input Bushing as recently as the the late 90s ..Part # 5010 . Called Trans Dapt and as expected it was obsolete. I ordered an Advance adapters AMC to Ford trans adapter bushing , It is 1.8 od and I will turn it down to 1.625 od.
  29. Roothawg
    Roothawg
    Thanks Lumpy for doing all this. It will sure make it easier for me, when I do mine.
  30. lumpy 63
    lumpy 63
    Also just picked up some Ford 5.0 10.5 clutch parts for fit up. If you guys look at your QT bells you will notice it is drilled for a clutch cable , which is probably what I will use when I install it in my 55 PU.
