Projects 1933 Ford Truck
Discussion in 'The Hokey Ass Message Board' started by Steve Hurst, Sep 17, 2019.
  1. Steve Hurst
    Steve Hurst
    Can someone help me out. I’m new to this 30s stuff. I have a 33 Ford truck and I am having trouble with the grille shell to hood fitment. To start, I am trying to put the truck back together after someone did a horrible cob job trying to channel it. So I have no reference as to where anything is actually located. I am trying to put it back close to factory body height. I have it where I think the cab is close but the grille shell is definitely wrong.
  2. Steve Hurst
    Steve Hurst
  3. kidcampbell71
    kidcampbell71
    ... you're new ... how are you loading pictures ? What device do you have ? Computer/PC, cell phone ( what type ) ? ... and where are you located ? Your profile completed, would help other HAMB'r's near you ... offer help, if needed.
  4. Steve Hurst
    Steve Hurst
  5. lothiandon1940
    lothiandon1940
    He got the picture thing sorted out.:).........I like yours better.:D
  6. Steve Hurst
    Steve Hurst
  7. AngleDrive
    AngleDrive
    from Florida
    The radiator is what locates the grille shell. The radiator mounts are triangles if front of the cross member. There are small brackets attached to the radiator then to the grille shell.
  8. Steve Hurst
    Steve Hurst
  9. Steve Hurst
    Steve Hurst
    I get that but the lines are wrong. And the angle of the top of the grille shell is all wrong.
  10. continentaljohn
    continentaljohn
    Wrong grill shell and top looks odd to me
  11. HOTRODPRIMER
    HOTRODPRIMER
    If you are using a gl*** grille shell that's your problem, your going to need to do some pie cutting to make it fit. HRP
  12. chevyfordman
    chevyfordman
    33 34 shells have a slant to the shell
    loudbang and lothiandon1940 like this.
  13. Steve Hurst
    Steve Hurst
    If it’s the wrong grille shell, What is it for? And it is steel.
  14. Steve Hurst
    Steve Hurst
    Updated my info, just to make you happy
    kidcampbell71 likes this.
  15. lothiandon1940
    lothiandon1940
    Are you sure that you have the cab un-channeled and positioned correctly?
  16. I had a 34 pickup that I channelled, and my grille was different from yours. I didn't run the side portions of the front cowling, so I can't say if I would have had the problem or not.
    As far as height of the top of the cowl, even after replacing it with a 32 shell from a car, I just lined the shell up to follow the original angle from the cowl. I didn't take any measurements, I just used the mark I eyeball to pick the height.
    If I was going to run with the cowl and the fit looked like your picture, I would look at either t******* the top or the bottom to make the seam right. I would also look at adding metal at the open area to cut down on the size of the seam.
    I found that when I chopped and channelled my truck, things that looked like they would fit after cutting, required a lot of fitting.
    From my own personal experience chopping and channelling two trucks, I have the ultimate respect for the people that chop the tops on the late 40s coupes.
    Bob
  17. Steve Hurst
    Steve Hurst
    I have the cab un-channeled and in what I believe is the correct position. It’s difficult to know if it’s perfect because the whole floor was missing. And the firewall is hacked to pieces. But from what reference I can fin it is very close.
    lothiandon1940 likes this.
  18. Kiwi 4d
    Kiwi 4d
    Why does it have that weird big moulded bump where the filler cap should be?
  19. AngleDrive
    AngleDrive
    from Florida
    Too many duplicate photos, but you will get the hang of it. Grille shell is not 33 truck. If I can remember I'll shoot some photos of a Hobby Members 33 truck tomorrow.
  20. continentaljohn
    continentaljohn
    05639FB4-1E63-4FBE-AECD-35067B1F16B2.png Maybe the hood has been trimmed or cab too far forward because it don’t look like mine
  21. Any chance thats a 34 shell,and 33 hood.They look alike,but arent.
  22. Steve Hurst
    Steve Hurst
    I can cut and add and make the gaps correct but I shouldn’t have too. If it’s the wrong shell I will
    Try and find the correct one.
    cactus1 likes this.
  23. Steve Hurst
    Steve Hurst
    I don’t really know. From what I have read it’s a 33. But I’m not a expert by any means.
  24. Steve Hurst
    Steve Hurst
    According to the information I have found the hood measures correctly in the center and on the sides.
  25. Steve Hurst
    Steve Hurst
    Do you have a pic of the front of the shell?
  26. Fordors
    Fordors
    The ‘33 grille did not have a stainless trim piece that surrounds the grille bars, so if yours is a ‘34 the holes for mounting the stainless would show that they have been filled. It looks like the top of your shell has been filled where the radiator cap would be and the top of the shell looks like it would accept the ‘34 shell ornament and radiator cap.
    With that said I expected the slant of the ‘33 and ‘34 hoods and grille shells to be the same and therefore interchangeable but those odd gaps have me scratching my head.
  27. HOTRODPRIMER
    HOTRODPRIMER
    Can you post a photo of the back of the cab? HRP
  28. continentaljohn
    continentaljohn
    A bit more of the front of the 34 with a 23 louvre hood and yours is 22 making it 33? and also no emblem. F9C09C39-7C4E-4BCA-AF77-346B78D77B82.jpeg
  29. F-ONE
    F-ONE
    from Alabama
    Note the rather severe angle (nose down) of the hood line. Does the front of your cab need to come up???
    On second thought....Down???
    Any way I do believe the angle of the hood is too severe.
