Technical 1964 ford f100 wires caught fire
Discussion in 'The Hokey Ass Message Board' started by DAGGER1120, Sep 18, 2019.
  1. DAGGER1120
    DAGGER1120
    Hello everyone this is my first post I own a 1964 ford f100 a couple of days ago I went to start my truck and when I started cranking the engine smoke started coming from the hood I open the hood and there’s a wire from the back of the engine bay on fire so I took the fire out and the wire goes from in the firewall to what looks like a coil the truck does not turn over at all I’ve been thinking the starter could’ve caused this problem anyone else have any suggestions anything helps thank you.
  2. Special Ed
    Special Ed
    First, disconnect your battery immediately, then get yourself a multi-meter or circuit-tester, and we can begin to help you.
    SOHC427, Truck64 and Boneyard51 like this.
  3. And PLEASE learn to use punctuation.
    You need a wiring diagram. We need a picture of the wire. Probably the only thing that burned was insulation. Trace the wire and let us see the termination under the hood
    Ben
  4. F-ONE
    F-ONE
    from Alabama
    What looks like the Coil??
    This could be the coil or the starter solenoid.
    Likely it's the starter solenoid and the primary lead to the starter. These big wires get super hot from the draw and inadequate ground. Of course there's no way to know without a photo.
    These get replaced but unfortunately the replacement wires (starter cables) from the box stores are for Hondas.
    Too small of wire.
    Bad grounds.
    Heavy Draw.
    =Fire
    chryslerfan55 and Boneyard51 like this.
  5. Boneyard51
    Boneyard51
    Sounds like your resister wire or resister shorted out, if it comes from within the firewall and goes to the coil. It may have also taken out your ignition switch or related components.
    Pics help!
    Bones
  6. DAGGER1120
    DAGGER1120
    I have a DMM
  7. DAGGER1120
    DAGGER1120
    I’m getting the photos right now
  8. DAGGER1120
    DAGGER1120
    Getting pictures now
  9. 296moon
    296moon
    from england
    Is it the truck in your aviater? looks like a Donk
  10. DAGGER1120
    DAGGER1120
    [​IMG][​IMG][​IMG]
    boy_named_sue and chryslerfan55 like this.
  11. DAGGER1120
    DAGGER1120
    [​IMG][​IMG][​IMG]
  12. Truck64
    Truck64
    from Ioway
    Is there a low ohm ignition coil installed? Have to be mindful of the current flow through the primary ignition circuit.
  13. BJR
    BJR
    The new Fords catch fire and burn like that also.
  14. F-ONE
    F-ONE
    from Alabama
    That indeed is the solenoid. Unfortunately it's off the leg that goes to the main harness.
    You need to start chasing wire. Get a shop manual.
  15. AngleDrive
    AngleDrive
    from Florida
    The wire that feeds power to the inside of the cab looks like the culprit.
  16. TrailerTrashToo
    TrailerTrashToo
    That is the starter solenoid. Just to make sure that what looks obvious is actually wired correctly, please verify:
    a. The heavy RED wire on the left goes to the starter.
    b. The heavy BLACK wire on the right goes to the +12 Volt terminal of the battery.
    ***UMING the above is correct, the crispy wires on the right go to the ammeter, ignition switch, fuse block (if the early Ford pickup has one), etc. The wires in this harness bundle will touching each other as the insulation was burned off.
    With a little luck, you can follow the burned wire thru the firewall and under the dash to the source of the short circuit.
    Suspects include (not an exclusive list):
    a. Failed firewall grommet, insulation worn thru and the wire grounding out on the firewall hole. Should see the burned area at the firewall, and the insulation inside should be OK.
    b. Failed ammeter - One of the wires to the ammeter should be crispy. If both wires are crispy, the short is deeper into the under dash wiring.
    Good luck.
  17. 52HardTop
    52HardTop
    I hope you've disconnected the battery as it was suggested you do. I would then carefully remove that tape that is covering the wires going towards your dashboard. You can see there are conductors that have lost their insulation caused by a short of some kind. Do not cut or remove any wires! Just remove the tape covering the wires. You must follow them back to where they are no longer burned or where they still have insulation cover. I would start there. You may find a reason for the wire fire under the tape.
    TrailerTrashToo likes this.
  18. DAGGER1120
    DAGGER1120
    Thank you for all the help!
  19. DAGGER1120
    DAGGER1120
    Thank you this has helped me a lot
  20. RmK57
    RmK57
    I'd check under the dash also for loose wiring. Especially around the the ignition and headlight switches.
  21. Boneyard51
    Boneyard51
    Looks like you got some answers , just got back to the iPad.....a little late! Good luck, you have a short. You will have to replace the burnt wire so just uncover it and trace it till the burn stops..... your problem will be close!
    Bones
  22. deathrowdave
    deathrowdave
    from NKy
    I’m not sure , it’s been a few years since I have been into the wiring on an early F100 , but as best as I remember the Amp Meeter is shut with just a wire p***ing through a loop on the rear of the meter . Maybe he only has a charge light and no meter . Need a few more answers . But it for sure has a short and a bad one .
  23. Truck64
    Truck64
    from Ioway
    '64 had GEN idiot light, no amp gauge, at least not standard.
  24. deucemac
    deucemac
    Whatever you do to repair the problem, add a fuel link to the wire coming off the starter relay and going to the distribution point. Ford does it from the factory and even divides power wires and has multiple fuse links to prevent overloading circuits. They weren't that bright in 64 however.
  25. Petejoe
    Petejoe
    from Zoar, Ohio
    Just for clarification deucemac, I believe you mean fuse link not fuel link. [emoji3]
  26. deucemac
    deucemac
    Yep, I have to blame my commie keyboard for that error!
  27. winr
    winr
    from Texas
  28. bobss396
    bobss396
    You are pretty much realizing that the condition of your wiring is not that good. Fix it up for now, but you may consider a new harness for the truck. It is really not that much work and it will eliminate woes down the road. All you need is something like a Rebel 9+3 or Kwik Wire 14-circuit kit.
