Projects What!!? another 27 on 32 chassis!??. Scratch build body.
Discussion in 'Traditional Hot Rods' started by Mindover, Jun 5, 2011.
  1. Mindover
    Mindover
    from England
    Joe I feel exactly the same ha!
  2. Mindover
    Mindover
    from England
    So I had cleaned and painted most of the parts. I did most of the cleaning up with wire brushes on a grinder. [​IMG]
    Next job was to mount the wishbones. So I made brackets to mount them to the axle. I shortened the torque tube and move the bracket for mounting the front of the wishbones.
    I ended up modifying the rear crossmember to make the car sit a little lower and I also modified the front by removing a
    spring. [​IMG]
    Gradually I cleaned and painted all the parts.
    Outback, Shadow Creek, OFT and 3 others like this.
  3. GizmoJoe
    GizmoJoe
    Looking nice, David.
    That cleaning and painting sure is tedious stuff. I did auto-body work for a living for a decade but it just isn't the same as putting a car together from parts.
    kidcampbell71 likes this.
  4. Mindover
    Mindover
    from England
    Thanks for the reply Joe. Not only putting the car together from parts but making most of the parts from scratch as well. The hardest part though is that I didn't have a pattern for many of the parts. I am a bit stuck at the moment because I need a measurement from the turtle deck. When I had a turtle deck here I didn't have time or space to work on my rod. Now it's gone I find I need some information I don't have.
  5. Mindover
    Mindover
    from England
    Anyone who could be prepared to give me a couple of accurate measurements from an original turtle deck would be much appreciated.
  6. GizmoJoe
    GizmoJoe
    Yes, you certainly are starting from scratch.
    I have as well (including the frame and suspension pieces), but mine isn't up to your standards and I'm not a pro so there is a lot less pressure to look good. ;)
    Your's will look better than an original, I suspect.
    Outback and brEad like this.
  7. DesmoDog
    DesmoDog
    I have a turtle deck here but it's pretty ratty so I'm not sure how correct any of the dimensions are anymore...
  8. justabeater37
    justabeater37
    Just a quick question. How long did your Torque tube end up?
  9. cheeko55
    cheeko55
    my 26 on 32 rails
  10. Mindover
    Mindover
    from England
    Thank you for the reply. I will see if there is any way to communicate the couple of measurements I need to you, perhaps with a photo. its the panel above the trunk that joins to the body tub that's in question.
  11. Mindover
    Mindover
    from England
    I cant remember it was a while ago I will see if I can get a measurement for you .
    Outback likes this.
  12. Mindover
    Mindover
    from England
    Nice! I like the coupe's as well.
  13. Mindover
    Mindover
    from England
    Another panel I made was the back of the tub...
    I formed the bead on my P21 Pullmax.
    Outback, 1952B3b23, cactus1 and 3 others like this.
  14. Mindover
    Mindover
    from England
    This was also painted in etch primer to stop it rusting.
    Outback, cactus1, brEad and 2 others like this.
  15. Mindover
    Mindover
    from England
    I part made the panel at the top of the turtledeck , this is the panel I don't have all the information for. I got to this stage and realised I don't have enough information to finish it.
  16. What info do you need David? Mine is loose. I can dig it out and take some pics and measurements if you need?
  17. Mindover
    Mindover
    from England
    Thanks Mike. I need the length at the edge of the panel where it joins the side panel, the edge that the T section trim goes against. On the same panel I also need a measurement under the edge where the trunk lid goes and the distance from that edge to the brace inside. Some photos of the inside strengthening frame would also be very helpful.
  18. Mindover
    Mindover
    from England
    I wasn't clear enough about the first measurement. I mean the length from the back edge to the crease in the panel at the front where it joins the tub. You can see on my panel above I haven't defined this area.
  19. Sorry I don’t have a metric rule handy! I will leave it out in case you need anything else. E1A0E286-18B5-47A7-A9D3-14F5F6C15342.jpeg D2D741BC-266F-4114-8CE4-F90F54E9E14C.jpeg 0E4DD293-BD4B-4D0A-BB28-24E11C66CF9A.jpeg FF358031-0EB7-4349-8DE7-B781748543B5.jpeg BA3BD371-4325-4E03-AFB5-C4A702F780E0.jpeg 1F5330A6-3B78-49C9-B4CA-EFECAE5107C7.jpeg 84375441-D1AD-4FF6-B25C-543F5A22242C.jpeg 2A120447-62D4-4D52-AC9E-11855CFD2D69.jpeg BA5842F7-05E5-4506-B595-3F20A3BE196D.jpeg 81A10750-A4BB-4B09-B1CC-AD5D1F60867A.jpeg 91CD5A30-70F5-41A6-8D39-33E3D4CE3015.jpeg BA3344C8-558E-4E79-A8AE-F0D27366945D.jpeg 7D1F1BE2-ED59-4662-8256-BEB603E0DB78.jpeg 67F71F1D-8189-4A89-8D8A-9A26367481BC.jpeg 47A19C87-A8EC-41B3-B96C-45E743BD987B.jpeg 6F7B1147-1C85-4B0D-BBF4-CABE49A35A0A.jpeg 97B49367-7A15-4B02-BC07-8C4F878AE2C3.jpeg E27AD0FC-C70D-4DF2-B8BC-2B02F14830A3.jpeg DAAF6D34-A66C-4227-A493-1A041F83C042.jpeg
  20. Oops! Some duplicates in there!
  21. DesmoDog
    DesmoDog
    Forgive the highjack, but as long as we're talking tulip panels here I'd love to know if that panel is flat going across the car where it meets the deck lid? My decklid (repro) is flat from side to side, the tulip panel has a bow to it from side to side, and I'm not sure which is correct.
    This exagerates it since the deck lid is sitting below the tulip panel but shows the differences in the shape of the decklid vs the panel.
  22. Last edited: Sep 29, 2019
    DesmoDog and kidcampbell71 like this.
  23. Mindover
    Mindover
    from England
    Thank you so much Mike. That is perfect. I can now finish the turtle deck. I have the rest of the body in one piece as I will show in the next few photos. I really appreciate your help.
    cactus1 and kidcampbell71 like this.
  24. Mindover
    Mindover
    from England
    Its fine (the hijack) great to have all the info you can get. The deck lid was one of the hardest panels I made. The repro deck lids I have seen are single curve but the real thing is compound curve at the back as well as curved where it meets the tulip panel. Not easy to make. It took me three tries.
    Outback and 1952B3b23 like this.
  25. You’re welcome David. Glad to be of help!
  26. Mindover
    Mindover
    from England
    I was never very happy with my first attempt at making the subframe and in my defence at the time I never had an original to copy. anyway I decided to make a new one. I copied the original one I have here now but I didn't make it identical. The profile and dimensions are the same as the original but I made it more in keeping with what I needed to fit a floorpan and to get it to sit on the ch***is better. I changes some of the details of the cross section profile. You can see there is simply a lip on the inside to fix a floorpan to.
    1952B3b23, mkebaird, brEad and 3 others like this.
  27. Mindover
    Mindover
    from England
    Here is a few photos showing what is basically a kit of panels ready to bolt together to make up my 27 T roadster body. every single part of this was made here by me. Its been a long old job.
    [​IMG] [​IMG][​IMG]
    Outback, 1952B3b23, mkebaird and 6 others like this.
  28. Mindover
    Mindover
    from England
    One last photo....
    Outback, alchemy, 1952B3b23 and 11 others like this.
  29. kidcampbell71
    kidcampbell71
    Wow !!
    Sooo' glad, you're posting again. I also ... can't wait, until your time, can accomodate, screwing this T together. Once and for all. It's amazing.
    As always, thank you, for sharing, sir.
    Outback likes this.
  30. Mike Rouse
    Mike Rouse
    A way to describe the curve is to use the chord method. Attached is a sketch of the devise that picks up the height or depth of the curve.
    Outback likes this.
