Projects '31 Model A Coupe Build: "Spooky"
Discussion in 'Traditional Hot Rods' started by brianf31, Aug 15, 2017.
  1. vtwhead
    vtwhead
    looks great, gives me some ideas for mine
    loudbang and brianf31 like this.
  2. IowaMercMan
    IowaMercMan
    Look for a mid 90s full size GM roof panel. Easier to find and the crown is perfect. Here’s mine, from a 94 Bonneville.
    In these pics, the Bonneville panel is just laid on there.
    Sent from my iPhone using The H.A.M.B. mobile app[​IMG][​IMG]
  3. brianf31
    brianf31
    Great fit!
  4. brianf31
    brianf31
    Slicks are mounted and the headers uncapped. Time to go to the strip.
  5. brEad
    brEad
    That looks great! Ready for business!
  6. brianf31
    brianf31
    Thanks bread. I ran a best of 13.17@105 mph at our Run What Ya Brung yesterday. Slicks bit hard and bogged the motor. I gotta learn to work the clutch and I'll get in the 12s.
    Nailhead A-V8, loudbang and brEad like this.
  7. Phil55Kratz
    Phil55Kratz
    Very nice coupe! Looks like tons of fun
    brianf31 and loudbang like this.
  8. brianf31
    brianf31
    quickrack-alan, AHotRod, Tim and 8 others like this.
  9. brianf31
    brianf31
    I made the long trip to work in July. 60 miles round trip, 10 mpg and 93 degrees on the way home. It was loud, hot and uncomfortable as a hot rod should be. At work 7-25-2019.jpg
  10. brianf31
    brianf31
    Last spring, I spun a rod bearing at the strip. I should have known that might happen. The major weakness in the 351C is the oiling system. The mains and rods don't get priority oiling; oil goes to lifters before main and rod bearings and it's slow to drain back when all that oil is in the heads. Combine high revs and a stock 5 quart oil pan and bad things happen.
    After having the crank turned, I added a blueprinted oil pump, oil restricted pushrods, enlarged/matched oil drain backs and all of that. I modified the oil pan to take 8 quarts and added baffling. That started with a hammer formed bottom.
    I was already running a Pertronix distributor so I added their rev limiter. It's hidden out of sight under the cowl. It doesn't work like your typical rev limiter. When you hit the limit, it randomly steals spark until you back off the pedal. It's pretty slick.
  11. dirty old man
    dirty old man
    Looking forward to seeing you, son, and the coupe @ RWYB on 10/5/19 Brian. That Cleveland is a beast. My son and I put one in an OT '65 Mustang years ago and the top end was unbelievable.
    What rpm do you have that limiter set at? I'm running an MSD dist, box, and limiter in my Hiboy on the SBC.
    I like that oil pan:)
  12. brianf31
    brianf31
    Dave, it's set on a fairly safe 6100 rpm. That ought to keep me out of trouble in the burnout box.
    loudbang and Tim like this.
  13. brianf31
    brianf31
    The wife made a decal just in time for this weekend's Run What Ya Brung. I'll end up hand painting it after I paint the car this winter. For now, vinyl will do.
  14. dirty old man
    dirty old man
    Looks good Brian. Looking forward to seeing you this weekend. Please remind me thaat I want to talk to you about those oil restricting pushrods. I have roller rockers in my sbc and I'm getting more oil to them than needed and would like to cut it back a bit. But I don't want to restrict the oil to my flat tappets by using those restrictors made to fit oil galleys. Just want to restrict the oil going to top end via pushrods.
  15. brianf31
    brianf31
    Dave, look up Smith Brothers. They have .040 holes in one end and still allow plenty of oil to the rockers. They are high quality.
    Deutscher, loudbang and SquintBoy like this.
  16. brianf31
    brianf31
    Dad helped me thrash on the original build back in '99. He didn't get to ride in it then and I parked it in 2000. He moved a pretty good distance away before I got it running again last year.
    The stars finally aligned yesterday. Dad came by on a day of perfect weather. 24 years after he gave the body to me, he finally got to ride in the hot rod he started so long ago.
    Every builder imagines what it will be like the first time his car comes to life. It's the pot of gold at the end of the rainbow, the reward after countless hours of hard work. I hope yesterday's ride was every bit as cool as he always imagined it. I hope he knows how special that moment was to me.
  17. Tim
    Tim
    from KCMO
    Very very cool
    brianf31 likes this.
  18. loudbang
    GREAT Christmas present for both of you. Good work.
    1947knuck, brianf31 and jim32 like this.
  19. dirty old man
    dirty old man
    Now that's way KOOL:cool::cool::cool::cool: Great gift for both of you.:):):):)
  20. Mike Colemire
    Mike Colemire
    Love the car and the vid was really cool. I bet it's really nice to have a Dad that has interest like you do. You may have mentioned but what brand and size rear tires are they? They look bad a$$ on there.
  21. brianf31
    brianf31
    Thanks Mike. The rear tires are BF Goodrich Silvertown 285/70R15.
    Deutscher, AHotRod, catdad49 and 6 others like this.
  22. boutlaw
    boutlaw
    Great looking coupe, great story...
  23. brianf31
    brianf31
  24. dirty old man
    dirty old man
    Got just a few seconds of video, then pic froze and when I exited and came back, it said video not available.
  25. loudbang
    Worked good for me at this time.
    1947knuck likes this.
  26. dirty old man
    dirty old man
    Working now for me too:cool::cool::cool::cool::cool::cool::):)
  27. brianf31
    brianf31
    I had a bird hit the radiator the other day. It didn't do any damage but I thought it might be time for a grille insert.
    I used 1/4" brake line for the perimeter. I started out using a tubing bender but found that it was easy enough to bend by hand. I welded a few 1/2" X 3/4" 16 gage tabs to fasten to the grille shell.
    The hardware store had some light gage expanded metal that looked like it would work so I picked it up. A buncha light welds holds it in place.
    All told, I had about $15 in it and it only adds 2 pounds of weight.
    Deutscher, AHotRod, Tim and 9 others like this.
  28. dirty old man
    dirty old man
    Looks nice Brian, and it looks as if it will keep out the birds and the bugs, that is except those damn gnats:eek:
  29. vtwhead
    vtwhead
    Nice job. Ought to help considerably.
  30. brianf31
    brianf31
    I changed the cam hoping to get the coupe in the 12s. I gave it a shot at the Run What Ya Brung today. The best I could manage was a 13.20 at 108 mph. I picked up 3 mph so the cam was doing it's part but I bogged on the launch.
    My kid Luke took a turn at it and, wouldn't you know it, he ran a 12.88 at 109.69 mph! Looks like I should be crew chief going forward.
