History Halibrand Wheels: The Original Mag
Discussion in 'Traditional Hot Rods' started by Jive-Bomber, Mar 28, 2017.
  1. Deuces likes this.
  2. Those are not Halibrand. They are E-T mags. E-T III to be precise. Also you have the wrong type washers in them. They should be an oval and fit tight into the wheel. Check ebay under E-T mags for correct washers and lug nuts before anything bad happens to the wheels or your car.
  3. lothiandon1940
    lothiandon1940
  4. lothiandon1940 likes this.
  5. 29Roadie
    29Roadie
    I thought these were pretty cool. These 21" wheels were on the back of a 29 DeSoto Roadster at the Nugget Casino during Bonneville speed week this year. 20190810_163907.jpg
  6. -Brent-
    -Brent-
    I have the magnesium cover plates (undrilled), too. I haven't decided if I'm going to drill and run them, yet.
  7. lothiandon1940
    lothiandon1940
    Back up for further consideration.:D
    Deuces and -Brent- like this.
  8. 32Stoker
    32Stoker
    If anyone have a set of Halibrand KO Spinner Hub / Adapters they want to sell, please PM me. Thanks!
  9. Anyone know the origins of these? Two 15x9.5 and one 15x8.5 (the 8.5 is the only one with "****oose" cast into it. 6 pin knockoffs. Been all over the place trying to learn about them. May sell em, may build a display case for them. 20191204_111540.jpg 20191204_111451.jpg 20191204_111512.jpg
    Deuces likes this.
  10. TERPU
    TERPU
    I absolutely love them. Is there a better wheel? I think not.
    For some reason when I build a car it's always rolling around in my head that it'll need 'Brands on it at some point. Getting ready to give them a shot on the cabinet.
    There was never any real choice on my Roadster. Even though they are Real Rodder copies of smoothies, and the '54 well that's because when I built it I was in a different spot and if I was gonna build a nice car it was going to have them. That was over 20 years ago now. The last picture is the only real set of Smoothies I've ever owned.
    Sure there's lots of great wheels, I like many but there's only one that gets everybody going.
    When a car gets Halibrands it just means you love it a little more.
    Kelly Burns, jnaki and lothiandon1940 like this.
  11. IronTrap
    IronTrap
    Scored these recently and was wondering where I can get 6 pin centerlock adapters to fit Early Ford Hubs. I'm squirreling them away for a "someday" project and I'd just like to start looking for the parts to mount them up to a car ahead of time. I'd like to put 2 on the rear of something!
  12. j hansen
    j hansen
    I was very pleased when we got these old Halibrand wheels in to our shop.
    They belong to a -70,s Swedish Funny Car called Ragnarök.These are the roughest castings I´ve ever seen on a wheel. Skärmavbild 2019-12-10 kl. 16.53.13.png Skärmavbild 2019-12-10 kl. 16.54.13.png Skärmavbild 2019-12-10 kl. 16.54.44.png
  13. HiHelix
    HiHelix
    ohhhhhhhhhhh Jo-JO like
    Deuces likes this.
  14. If it was me, I'd look for special 6-pin hubs - maybe even talk to Boling Brothers and see if it is possible to buy hubs that have not been drilled. Maybe you can drill a set of hubs? What I don't know is the center opening of the wheel - will it fit the diameter of the standard Ford hubs? The think I hate about adapters is that the wheel is moved out (offset) about an 1" to the outside. Always looks funny to me and can screw with the steering/handling of the car.
    kidcampbell71 likes this.
  15. DDDenny
    You may need custom adapters, not sure what you are doing.
    Used Halibrand pressure plates are on that auction site regularly.
    Keep in mind, this stuff has gotten expensive whether new or used.
    Here is an old HAMB thread, it may be of help to you.
    https://www.jalopyjournal.com/forum/threads/pin-knock-off-ford-hubs-best-way-to-go.226496/
    Lots of resources here:
    https://www.google.com/search?q=6+p...OxavmAh**oFsKHd07DdgQuIIBCDU&biw=1280&bih=656
    BigDTexasKid likes this.
  16. This is how we handled the issue. Found some old dirt car 6 pin hubs, redrilled the Ford drums, mounted the hubs using the pins nutted on the inside of the drums. Works on the front also using ford drums. Will not work with early Lincoln drums on the front.
    Deuces and TERPU like this.
  17. There is also some machining to do to make sure everything is centered and secure
  18. IronTrap
    IronTrap
    I'd like to run them on the rear only on an early Ford Drum/hub. They should fit over the hub/snout ok I think for a banjo rear drum. I've heard of using the old dirt car hubs before as a basis. Boling Bros is a good idea too!
    I only want to run them on the rear, so this is a good idea. Glad to hear from someone that has actually done it! What machine work did you do? I guess I need to call around some of the old dirt racers in the area and see who has some 6 pin hubs! Thanks!
  19. Speedwrench
    Speedwrench
    Google " ****oose indy car "
  20. Speedwrench
    Speedwrench
    When you are asking around ask for the hubs from a tapered rear end not a splined rear.
    IronTrap likes this.
  21. Wonder if the 8.5 is actually off one of them. Very interesting. Thank you for the info.
  22. A couple cuts on the lathe on the drums and hubs to create a centering ridge when mating the hub to drum. Probably overkill but I felt it would relieve some stress from just using the pins for centering. Works good, I've used it on a couple cars.
  23. robyv
    robyv
    from hi
  24. robyv
    robyv
    from hi
    Hi I was wondering if any HalibRands may be for sale? Imagine looking to get a g***er setup.
    Thank you
  25. -Brent-
    -Brent-
    I saw the thread got bumped up and I noticed I never shared a pic of the wheels on my coupe after the pic of them stacked in the shop.
    Edit: With doors.
  26. Bob Lowry
    Bob Lowry
    Here's a couple of pictures...on of my '46 I recently sold, but kept the rims, and another of
    part of my friends collection. He started collecting Sprints in the late 60's, never sells them. 46 coupe 10.jpg powers 3.jpg powers 3.jpg
    Deuces, neverdun and kidcampbell71 like this.
  27. deucendude
    deucendude
    from norcal
    Deuces and kidcampbell71 like this.
  28. Ratspit
    Ratspit
    Here is a set of Sprints waiting for their next ride 20200505_133921_resized.jpg 20200505_133600_resized.jpg 20200505_133452_resized.jpg
  29. Deuces
    Deuces
  30. lothiandon1940
    lothiandon1940
    Keep the pictures comin' boys (and girls).:D
    Deuces likes this.
