Projects Simca Marmon Flathead V8 from 1987!
Discussion in 'Traditional Hot Rods' started by edwardlloyd, Oct 1, 2019.
  1. edwardlloyd
    edwardlloyd
    from Germany
    I've just picked up a nice 30 year old flathead V8 for my next project.
    It's a French Simca Marmon (Ford) flathead V8 cast in March 1987.
    It came out of a decommissioned French military light truck. It's got the air compressor mount up front so fingers crossed, it's a long stroke engine.
    It's a low hours engine so we'll see how good it is later after strip down.
    Obviously it'll need a normal ignition from Bubba. A p***enger oil pan and starter and a decent 12V generator.
    The remote oil filter is there, just needs relocating.
    Hey - there are some advantages living in Europe. 20191001_141919.jpeg View attachment 4437114 20191001_141937.jpeg 20191001_141946.jpeg 20191001_141956.jpeg 20191001_142008.jpeg
    Sent from my SM-G935F using The H.A.M.B. mobile app
  2. redoxide
    redoxide
    We used to buy those in the UK for £300 an engine, still in the airtight containers .. those days are long gone... That was around the early / mid 90s. Wish I bought more ..
  3. big duece
    big duece
    from kansas
    Cool! Is it a 4" stroke? A 59a pan should fit.
  4. edwardlloyd
    edwardlloyd
    from Germany
  5. big duece
    big duece
    from kansas
    I believe the ones that had the sump pickup up front were 4", at least mine was. Bob Drake or others truck water pumps bolt right on. Actually, the hole block is SAE threads, only the exhaust studs have 10mm theads on the nut end, sae in the block. Hint, leave the studs in, they are a ***** to get out.
  6. edwardlloyd
    edwardlloyd
    from Germany
    I got the first head off. No ridge or scoring in the cylinders. Valves look clean. This looks like the low hours on this are true. 20191001_155740.jpeg 20191001_155749.jpeg 20191001_155842.jpeg
    catdad49, lewk, mgtstumpy and 5 others like this.
  7. edwardlloyd
    edwardlloyd
    from Germany
    Woogeroo, Jeff34 and big duece like this.
  8. Trad V8
    Trad V8
    from Edinburgh
    Hi Ed, will you put a new cam in? If so which one? I've got a couple of these 4" strokers put to one side myself and will be looking to put one together sometime next year hopefully.
  9. Texas Webb
    Texas Webb
    What a score.
  10. Jalopy Joker
    Jalopy Joker
  11. big duece
    big duece
    from kansas
  12. edwardlloyd
    edwardlloyd
    from Germany
    That's the way it was built. It's stock with just 311 hours on it. And it does have the 4" crank. It's built for torque so maybe it doesn't breath as well as a Mercury. Anyway it's going in the Model-A completely stock.
    It'll get headers, and new distributor and a single 94 carb. It'll be more than enough for a Model-A rear axle anyway.
    catdad49 and irishsteve like this.
  13. DDDenny
  14. Bandit Billy
    Bandit Billy
    cool relief work, didn't know these blocks came that way form the usine
  15. Boden
    Boden
    Looks like a 4” stroke motor
  16. FlatJan
    FlatJan
    just for the record as its often stated wrong, those arent hours, those are engine revolutions times a factor written on the conto's side.
    yours is kinda new. I also have two comparables from 79 and 86 freshly French mil rebuild.
    and yes it will need porting.
    dont forget to weld the pans breather shut!
    btw think you are gsra too? i did the rodazin and wrote the french Flathead articles some years ago so if you have questions contact me
  17. edwardlloyd
    edwardlloyd
    from Germany
    So it would appear the engine has done just 622,000 revolutions in total. Which at 1000rpm average means just over 10 hours.
    mgtstumpy and clem like this.
  18. edwardlloyd
    edwardlloyd
    from Germany
    I just removed the intake. Looks like brand new inside. Looks like someone has worked on the intake runners to improve flow. 20191002_132126.jpeg 20191002_132140.jpeg
  19. edwardlloyd
    edwardlloyd
    from Germany
    I think I'm going to use the original intake manifold. It's aluminium but has a 4 bolt carb base. I've offered up a 4 bolt Lincoln Zephyr carb and the bolt pattern very nearly fits. About 1mm off so I could drill out the base holes a little.
    The Zephyr carb offers a little bit more flow too. 20191002_132914.jpeg 20191002_133240.jpeg
    catdad49, mgtstumpy, Jet96 and 2 others like this.
  20. CheatersPete
    CheatersPete
  21. Surfcityrocker
    Surfcityrocker
    from Austria
    Great score! Are these still sold by army surplus vendors?
    If I may ask - how much did you pay for it?
  22. edwardlloyd
    edwardlloyd
    from Germany
    I friend of mine bought 30 of them. Ex French military. I paid just over 3K for it. Which is great for a nearly new 4" engine.
  23. edwardlloyd
    edwardlloyd
    from Germany
    It looks like it was ***embled in July 1992 even though the casting was already 5 years old at the time. 20191002_135935.jpeg
    kidcampbell71 likes this.
  24. brady1929
    brady1929
    Cool flathead. Congrats.
  25. Surfcityrocker
    Surfcityrocker
    from Austria
    Thanks for your answer
    Sent from my Moto G (5S) using The H.A.M.B. mobile app
    jimmysweden likes this.
  26. FlatJan
    FlatJan
    it was made/cast in 87
    No this is the rebuild plate. So it was rebuild by french mil in 92 in clermond ferrand.
    cylinders are standard, crank- and camshaftjournals are in first undersize.
    ports are always like this.
    i think i know who you got it from ;)
  27. edwardlloyd
    edwardlloyd
    from Germany
    So I guess the revolutions counter was reset during the rebuild. That would explain it's fresh condition then if it was rebuilt in '92. Still, stock pistons means it hasn't covered much mileage.
  28. 41rodderz
    41rodderz
    from Oregon
    We all would love to score an engine like that.:):cool: Congrats.
  29. FlatJan
    FlatJan
    yes typically thats what they did.
    so you are really lucky. Engines like that dont show up that often anymore :cool:
    so i would say this is a great moment to say merci
    raven likes this.
  30. Bruce Lancaster
    Bruce Lancaster
    The HAMB is such a labor saver! This just saved me from trudging down to the ba*****t to introduce a French manifold to a Lincoln carb!
    "I think I'm going to use the original intake manifold. It's aluminium but has a 4 bolt carb base. I've offered up a 4 bolt Lincoln Zephyr carb and the bolt pattern very nearly fits. About 1mm off so I could drill out the base holes a little.
    The Zephyr carb offers a little bit more flow too."
    Does yours have the aluminum pan, either up front or Ford type sump? The 59 type aluminum pans are really nice.
    Moriarity and kidcampbell71 like this.
