Technical Little tips and tricks for garage hobbyists.
Discussion in 'The Hokey Ass Message Board' started by Ron Brown, Jul 30, 2019.
  1. And they won’t burn you upholstery!
    X-cpe, Atwater Mike, mario711 and 5 others like this.
  2. koolbeans
    koolbeans
    You bet. Great idea. This stuff stinks to high heaven. If you get it on you, burn your cloths or your squeeze will.
    Sent from my XT1710-02 using The H.A.M.B. mobile app
  3. BigO
    BigO
    PLEASE DO NOT draw or write on a primered car with a SHARPIE that is not going to be stripped to bare metal later because after its painted (especially if its going to be a light color) it will bleed through later on. I've seen it happen.
  4. mwhistle
    mwhistle
    from sacramento
    +1 on pee bottle...
  5. 57JoeFoMoPar
    57JoeFoMoPar
    Buy a house with a huge *** garage already up, the bigger the better. Outbuildings are only worth pennies on the dollar in the purchase of residential real estate, so you're getting a building at an extraordinary discount over the cost to build and you're financing it to boot right in with your mortgage.
    To build a garage yourself, you're coming out of pocket the full sum in liquid cash, and you, instead of someone else, is taking the depreciation hit. Bad move.
  6. TagMan
    TagMan
    ^^^^^ Absolutely correct. I'm going through this now with my new shop build after a 2-year search for the "perfect" house & shop I wanted, but couldn't find. I'm paying for it now.........
    osage orange, loudbang and Boneyard51 like this.
  7. 57JoeFoMoPar
    57JoeFoMoPar
    My shop probably added $10K of additional value to my property over what it would have been worth had it not been there. It probably cost $50K to build. So the $10K is in there as part of my mortgage, at 3.75% fixed rate over 30 years... the difference in monthly mortgage payment for the shop is $45 a month.
  8. Boden
    Boden
    from Sherman CT
    I use a old cutting board when taking something with small pieces apart. Such as carbs, and distributors
  9. 65pacecar
    65pacecar
    from KY, AZ
    I know you mean to use it as a base to dismantle and sort parts on but I was reading this at work and my first thought was of beating the carbs and distributer apart with the cutting board, basically until they fall apart. It’s been a long day :)
    brEad, ratrodrodder, redzula and 3 others like this.
  10. Don't spray your "rust" with glossy clear coat..LLS.....there is matte clear.....
    There are different blasting media, use the appropriate one on the part.
    JB weld has it place, aluminum can be TIG welded, soldered or MIG welded.
    Double check your power valve in your old Holley 94......There are many different configurations.
    A card table is a wonderful addition to a garage....I have two.
    Try to keep a section of a bench clear so you don't have to work on the floor.
    Dollar Stores carry very small funnels....remember how hard it is to put oil in your jack...
    Dollar Stores carry hammers, screw drivers, s****ers and dentist picks.
    I hang my oil drain pan with the dump tube inside a funnel that is inside an old water jug.
    It is tough organizing a two car garage with 4 car garage worth of stuff. Remember, the walls.
    Don't use a cutting board....use a serving tray with a raised edge so your check balls don't roll away.....
  11. 5brown1
    5brown1
    I use Avon Skin So Soft for cleaning oil, grease, tar, etc. from my hands. It works great and leaves
    the skin undamaged and soft.
  12. Elcohaulic
    Elcohaulic
    I like using Baby Oil for cleaning hands....
  13. Rusty Heaps
    Rusty Heaps
    I hate it when my check balls roll away!:eek:
  14. Bandit Billy
    Bandit Billy
    2 words for all of you considering a shop addition "renovation lending", I do a lot of it. As a lender we will not do a renovation loan to solely build a shop but we will fund a shop of you spend money on the home at the same time. You are correct that your $50,000 shop added a minimal value increase to your property BUT if you had borrowed $100,000 and added some living space, preferably a bed/bath, upgraded the kitchen and existing bath(s), then your appraised value would have gone up enough to cover the shop and you wouldn't lose any money on your investment. BTW, renovation lending bases equity on the future (improved) value of the property so don't worry if your existing home doesn't have the equity you need to do something like this.
    The only drawback is you cant do the work yourself, have to hire a contractor which is a good thing since most of you would be trying to MIG the studs and beams together.
    Squirrel knows his engines, Billy knows mortgages (licensed in OR, WA and CA NMLS 188558).
  15. mr57
    mr57
    Watkins degreaser will take oil stains, ATF stains, and damn near anything off your good clothes provided you're fast enough that your old lady doesn't discover you washed the stuff in her good laundry machines....
    brEad and loudbang like this.
  16. Fortunateson
    Fortunateson
    Well you could Mig the studs together if you hammer in a few nails at the appropriate locations and then weld those I suppose...?
    rpm56 likes this.
  17. leon bee
    leon bee
    I inherited a lead hammer. Ugly as hell, I didn't think I'd like it but I really do. Instead of beating on something with my bare fist, and bleeding, cause I didn't want to ding it, I go get the lead.
  18. jetnow1
    jetnow1
    from CT
    He is referring to Billy Bandits post a couple of posts above it.
    loudbang and clem like this.
  19. boy_named_sue
    boy_named_sue
    from Dayton, OH
    Lol you had me busting up at my desk this morning. Also the rest of that info was super helpful as my wife and I were just recently talking through this prospect. Thanks billy
  20. BigO
    BigO
    For those that are new to using rattle can paint and looking for good clean results (or those that have had poor results) i like Dupli Color best, first make sure the can is shaken VERY WELL not just 5 or 6 shakes, then put in the sun and rotate every so often till can is good and warm, if it's winter or cloudy just put in hot water. Make sure your prep work is nice and smooth and dust free. When warm, shake the can again vigourusly and do few test sprays and make sure tip is CLEAN and the area you will be painting in is also dust and bug free, then lay down a few light coats and let dry in between then a nice coat to finish and let stand overnight. A lot of very nice work has been done with rattle can so DON'T think its a short cut, it holds up well under normal conditions. Patience is your FRIEND. :)
  21. boy_named_sue
    boy_named_sue
    from Dayton, OH
    Also, on this topic: any clever ideas of how to store your grease gun without it making a giant mess? Over the years I just devoted an entire drawer to it and wipe it out occasionally, but that’s not a very expedient use of minimal storage space. I’d love a good idea to try
    Bigcheese327 and loudbang like this.
  22. jaw22w
    jaw22w
    from Indiana
    Yeah, grease guns can be a mess. Some greases seem to release the oils out of the grease and leak all over the place. Lately, I have been using Lucas Oil "Red and Tacky". It doesn't seem to release the oils as bad as others. Anyway, I keep mine in a big zip lock baggie.
  23. chopnchaneled
    chopnchaneled
    from Buford Ga.
    I hang mine from some 3/4 conduit that's mounted crossed a corner of
    the shop kind of out of the way.
  24. 56don
    56don
    Ha ha, Yeah, if you are a doctor! :p
  25. s55mercury66
    s55mercury66
    from SW Wyoming
    You can pull the handle back on the grease gun, and relieve the pressure on it. That will help a little.
    ratrodrodder, LAROKE and loudbang like this.
  26. Leakie
    Leakie
    Here is a simple solution...
    Bigcheese327, JD69, RICH B and 19 others like this.
  27. Country Joe
    Country Joe
    5 gal bucket for my grease guns.
  28. brad2v
    brad2v
  29. KevKo
    KevKo
    from Motown
    Warming the rattle cans in warm water is a good tip. But don't put it on the stove! I just run hot tap water, fill the sink, and put the can in for a little bit.
  30. BigO
    BigO
    Good catch :D, "patience". Stupid auto correct ......
