Does anybody have any pics of a 303 or 324 Olds in a shoebox? I’m getting mine sorted and need to see how others have got around the steering? I’m using a T350 adapted trans from Ross Race Engines and one of their compact starters. Sent from my iPhone using H.A.M.B.
I see a modified oil pan in your future but there were at one time modified drag links available for sbc in ford shoebox.
Bobbleed just found a survivor with an Olds Rocket in a shoebox.... Maybe he could shed a little bit of old school light on the subject! Sent from my LM-V405 using The H.A.M.B. mobile app
old thread but go to post #13 for what the fella did on his F100 https://www.jalopyjournal.com/forum/threads/hurst-dropped-drag-link-kit.221931/
Hurst used to offer this and some old magazines with pretty crude ones first picture https://images.search.yahoo.com/sea...sBCJ2X37**DFLnrZk0mzELqF9QMw9w-IXECTDD4BVDplM
I have a friend who is doing the same thing, he's using a Volvo steering box. Car Craft Feb 1956 has an article on this and The Story of a California Hot Rodder by Jay Carnine has a story about this.
The fix is a DROPPED TIE ROD, very common in the day & easily fabricated. Someone will provide a picture from an old magazine article.
That was initially my plan however the oil pump and pickup sit hard down into the rear of the pan Sent from my iPhone using H.A.M.B.
Have 371 in 50 mercury ... Engine is at a good angle/ starter is relocated on p***enger side ... stock manifold sits right on steering box ... otherwise linkage clears pan...
The trick we used back in the 60s to solve the starter problem, was to buy a starter crossover. This was an easy swap into the truck than into the car. The link is expired, but excellent pictures of a crossover. https://www.jalopyjournal.com/forum...er-oil-filter-byp***-303-324-371-394.1101771/ Did you look on the everything Olds thread for some tips? https://www.jalopyjournal.com/forum...ll-other-posts-lasalle-related.149650/page-22 Used crossovers have been advertised on HAMB, but you can also do a google search using this string -- Olds 1949 -1960 starter "crossover" . It will get you plenty of results, and I hope you find one at a reasonable price. I never did it, but some guys that swapped in engines with starter clearance issue, moved the engine to the right, off the frame centerline. Bob
I didn't use an olds in my 49 but I did use a sbc. I flipped the spindle supports and heated and bent the steering arms and used a pitman arm with a deeper drop from a different car...seems like it was an Olds of some kind but I don't remember. I raised the engine about 3/4th inch higher off the mount brackets to clear the steering linkage...
I built a 324 Olds out of a 55 Olds into a 49 business coupe. The mounts and starter adapter to move it to the p***enger side were available from J.C. Whiney. We dropped the drag link and drove it daily until rust ate it away.
Starter "crossovers" are hard to find and expensive. It took me almost a year to find a good one for less than $500.
