Projects 1938 ford pick up
Discussion in 'Traditional Hot Rods' started by nobby, Sep 24, 2019.
  1. nobby
    nobby
    1938 ford pick up
    1953 8ba
    Pressed steel bell house
    T5
    1971 mustang 9 inch with 56.5 maverick sjafts.
    Econo front brakes
    Ch***is engineering spindles
    Rhd saginaw 525
    Stock 38 thd pedals
    PONTNAK123 and slim38 like this.
  2. Jalopy Joker
    Jalopy Joker
  3. 41rodderz
    41rodderz
    from Oregon
    It's supposed to be a mystery.:D
  4. low budget
    low budget
    from Central Ky
    Looks like you got a little ch***is repair work ahead of you too.
    Im interested and would be glad to tag along and see what you do;)
    lothiandon1940 likes this.
  5. nobby
    nobby
    Yes. Purchased it all in bits from the one guy.
    Picked it all up in a mercedes van..
    frames is rusted out and twisted. Been in a fire
    All the body parts have been in a fire---less paint removal!!
    The cab and doors are riddled with bullet holes
    I have cut and drilled all the rivets out and wire wheeled the frame.
    Bolted it together last night. Needed to put it all together to see what I have, never stood next to a 38 pick up before!!
    built up the axle with 4.11's -open diff 71 mustang case, stock 76 maverick shafts, 10 by 2.5 finned brakes from a 1980 ford something.
    A few things I have learned only today....
    A posies 37 to 40 1'' dropped spring is 39 inches long unladen, laden its 39.75 , part number 2040
    I think they still list them on ebay as 35-40, but I am sure 35 and 36 fords have a narrower spring perch/wishbone
    They list some on ebay at 33.5'' They do not fit.. they are for I think earlier axles spring over - bought one of them already.
    When fitting a 1 inch dropped posies spring to a 37 to 40 axle put the wishbone and axle on the bench. Clamp the spring with big cramps. Dont try doing it in the vehicle.
    2. An a or b front shackle doesnt fit. Its not wide enough, I think they are 2.5'' internal, you need 2.75'', you can squeeze them in by flattening the u bolt and filing up the cross member holes
    3. a Mitsubishi l200 front bump stop looks and fits exactly like a 38 ford!!!
  6. Jalopy Joker
    Jalopy Joker
    you have done good with a real challenge - yes, very difficult, and expensive, learning what fits and does not. be sure to ask here for help and ideas with this project
  7. stillrunners
    stillrunners
    from dallas
    Kool......need frame ?
  8. nobby
    nobby
    yes I could really use a solid stock frame, alas I am on the other side of the pond.....
  9. Cool truck Nobby, although, I am biased as I have a 35'Ford. It is in storage in our son's workshop at the moment as we moved house in the last year, and I am in the middle of building a new garage, then I can get on with finishing it. Where in Lundinium are you?, as we lived in Pimlico for 26 years.
    Cheers , and good luck with the build.
    hfh likes this.
  10. Henrietta the '38 Ford pickup sends friendly horn honks to you and your '38. Sheet metal that has been through a fire is hard to work. I'd rather deal with bullet holes.
  11. nobby
    nobby
    got a bit confused searching for a wishbone ball and clamp, I didn't have any to start with so didn't know what they looked like..
    20190924_165302.jpg they are called
    Radius Rod Bushing (Rubber Ball) Cover
    Thanks for the beep
    -not far from Pimlico.. Fulham,
    the inside measurement of the front spring shackle is 65mm
    the do not measure the shackle on centres, the internal measurement
    this is a trailer spring plate 15 quid, hope it fits
    ordered some m12 65mm square u-bolts
  12. nobby
    nobby
    64248646_2790778257605208_7498497515625381888_n[1].jpg engine fun
    bought two 8ba's a couple of months ago
    thought I'd make one good one out of the two
    both engines were full of sand up to the intake on two cylinders at tdc
    the sand had rotted the pistons
    thing is they don't look cracked in the usual places!!
    may need a few liners...…
    don't know why I used white vinegar to soak the bores
    View attachment 4438492 62320187_2788953234454377_1104965703665975296_n[1].jpg View attachment 4438492 62320187_2788953234454377_1104965703665975296_n[1].jpg
    64363317_2788955877787446_521105564525133824_n[1].jpg 62642714_2790781884271512_1820658455208263680_n[1].jpg
    what a chore
    still have one stuck valve and guide, need to cut it.
  13. ratreo
    ratreo
    Bummer,
    I have both the drivers side and p***enger side doors, a hood and a variety of other 38 Ford truck parts sitting on my property...
    The problem is I am just about diametrically opposed to you on the planet. The cost to ship heavy awkward sized parts work be prohibitive
    Good luck with your project, keep at it, you’ll get her going
  14. nobby
    nobby
    Hello ratreo,
    I do have doors and a hood
    ! luckily the hood escaped the fire!!
    the doors are real bad
    I am having trouble finding a 35-40 front shackle.... think I need a stock one
    am also having trouble reaming my king pin bushes... bought an adjustable reamer that was too big, bought one that was too small and broke it.
  15. ratreo
    ratreo
    3DCFD935-46D9-45DE-8CB9-8C4698DDFB03.jpeg A5BFB309-4CCA-47D0-8FE3-EB58B0A183F1.jpeg 41BE9426-D36C-403D-A597-5340C68F0E59.jpeg So I have the stock front end which is a “spring over “ configuration. Tell me what you need. If I have it I may be willing to split some of the parts up so someone can get benefit from it. As I remember the wishbone socket ***y has been incorporated into the reconfigured frame.
    The screwball that previously owned the truck had preformed a hideous chop. He was sooooo proud of his welding expertise...
    It looked like he “hot dribbled” the roof skin back together. I’ll try to find the cab pics
  16. ratreo
    ratreo
  17. harpo1313
    harpo1313
    from wareham,ma
    The lasagna chop strikes again , Im subscribed.
    Texas Webb likes this.
  18. nobby
    nobby
    Mitsubishi l200 springs and shackkes and bushes 165 delivered
    Shocks 38
    Lower shock mounts 49 delivered
    Bump stops 28 pair delivered
    the bump stops turn the thinner 2 3/4'' axle tube to 3''
    so - you can use 3'' u-bolts, plus you get a bump stop!!!
    Swap meet 2 3/4 axle saddles ne 10 pound
    Looks like it may work. Shocks need to point forwards and back. Twin shock crossmembers - - can only go one way
  19. nobby
    nobby
    I think that is a 35 36 front wish bone and cross member
    I think you can use that wishbone in its stock central configuration with say a so-cal axle, and bolt it in a 35-40 frame
    the wishbone on a 37 38 39 is wider at the perch
  20. ratreo
    ratreo
    [QUOTE : I am having trouble finding a 35-40 front shackle.... think I need a stock one
    am also having trouble reaming my king pin bushes... bought an adjustable reamer that was too big, bought one that was too small and broke it.[/QUOTE]
    I (as you’ve seen in the pics) have the main spring and all of the leaves along with the shackle brackets. Do you only need the shackle brackets? Is your main spring in good shape?
    Once again, if there are some parts that would help you maybe we can work out a deal to get them cut apart, boxed up and shipped in your direction.
    I’ve built a number of cars and trucks. As a suggestion be cautious how much you cleanup/remove material when you ream out your king pin bores. It doesn’t take very much to go too far. Usually the bores and upper and lower faces has surface rust on them. Often I’ve found that a flat file for the upper and lower surface is enough combined with scotch brite in the bore will get you started. Be careful that your reamer is true to the axis of the king pin bore and that you’re flushing the rust and small chips out as you are “lightly” reaming the bores out. It’s easy to mess it up. Many cars with “death wobble” woes can be traced back to loose king pins and too loose perch pin bores.
  21. ratreo
    ratreo
    Along with bad geometry with your steering.
    Oops, I believe that I’ve opened a pandora’s box on this subject...
  22. nobby
    nobby
    Hi i have bought a posies new 1 inch lower spring
    I have new ch***is engineerinspidles with the fat girth they come without the bushes so tgey are not fit then reamed
    I have a stock axle and bone which i am using unsplit.
    Got new pins and bushes
    I think you are correct in that it msybe the axke bore at fault if its not bushed and reamed. As the cotter pin may hold it tight. But it can still rock
    Just want to get it on its wheels
    Will do the usual.
    Track with to tyre centres
    Ackernann
    Steeribf arm lengths
    Steeribg hox ratio
  23. 41rodderz
    41rodderz
    from Oregon
    Sounds like the "Goldielocks and the three bears".:D
  24. sidevalve8ba
    sidevalve8ba
  25. ratreo
    ratreo
    ackkk!
    surly that was not a taunt about the beatific welding technique?????
    “go away or i will taunt you a second time”
    sidevalve8ba likes this.
  26. hrdtlrdr
    hrdtlrdr
    I ***umeeeee you know the 38 and 39 pick ups are about the same for parts. the grille is a little different and the windshield crank is horizontal on the 38.The 1935 and 36 axle is 2 inches at the perch boss. the later axles are 2.25 inches .
  27. hrdtlrdr
    hrdtlrdr
    If I can help send me a PM.
  28. hrdtlrdr
    hrdtlrdr
    ratreo,ineed the back half of a38-39 ford cab? i am also a ways away but what do you have? thanks Chuck.
  29. nobby
    nobby
    this nearly is correct
    use a 3/4 double d shaft and double stick tape strips of 120 emery onto it
    increasing the width of the strips as you go
    finally have the pins in - hooray
    how does the windscreen centre bar work?
    is it fixed at the bottom or is it a loose piece and has top and bottom receiver bits- I think mine is rotted off at the bottom, if so can you gat the bars separate?
    thanks!!
    PARTS WANTED
    I could do with a grille centre bar v8 badge
    could do with a 38 window crank handle
    door handles
  30. nobby
    nobby
    how does the rad fit
    I gather since I have rad prop tabs on the firewall, the top of the rad takes the rods?
    I need a radiator.. I gather I can't then get a 51 ford car style as have to have the prop tabs and the lower mounting for the springs ??
    do I buy a 32 rad with the filler not on the top?
