Projects break drum
Discussion in 'The Hokey Ass Message Board' started by lodaddyo, Nov 18, 2018.
  1. lodaddyo
    lodaddyo
    ok
  2. X38
    X38
    Did they fit before painting/coating?
    gimpyshotrods likes this.
  3. greybeard360
    greybeard360
    Is all of that stuff powder coated? Could be your problem right there.... clean it off.
  4. Fordors
    Fordors
    Machine them? I would just hit them a bit with one of those rubber sanding drums you put a sand paper sleeve on.
    The slight amount you need to remove should dust out of them really quickly.
  5. stuart in mn
    stuart in mn
    If the difference is only 0.005" s****ing the paint off the mating surfaces may be enough, or just spending a few minutes cleaning things up with a file. If machining is required I'd do it to the drums, since the hub is original and the drums are aftermarket.
  6. krylon32
    krylon32
    from Nebraska
    Looks like you'll have to drill the stud holes a little over size? Speedway drums have had problems in the past.
  7. Your new studs aren't for that set up.
    Get the right studs or drill out the drum to accept that shoulder
    razoo lew, oj, ottoman and 2 others like this.
  8. mad mikey
    mad mikey
  9. Blue One
    Blue One
    from Alberta
    Absolutely correct.
    If you had the right studs the shoulder would be shorter and wouldn’t stick out like that.
    Simple, measure that shoulder and drill the drums.
    5window likes this.
  10. Fordors
    Fordors
    Because your drums pilot on the hub you can drill the lug holes oversize with no issues.
    lodaddyo likes this.
  11. I'm guessing here ,,,,
    Studs for swedgedededed drums but trying to fit them like a slip on.
    Mixing apples and oranges gives orpleange and other things that don't make sense.
    Beanscoot likes this.
  12. mickeyc
    mickeyc
    Wondering, will the drum take up enough of the shoulder protrusion so that the
    wheel will seat properly and not have the same issue as the drum?
  13. Beanscoot
    Beanscoot
    I would first try using a 45 degree chamfer tool on the insides of the drum stud holes, probably a 1/16" chamfer or so would be enough to get them to sit flush.
  14. patina steve
    patina steve
    I have done exactly what you are doing many times ( original hubs, 610-234 Dorman studs and new Lincoln style break drums ) the drums are hub centric all you need to do is drill out the stud holes so there is no binding on the studs to allow the break drum to center on the hub.
    lodaddyo and town sedan like this.
  15. Blue One
    Blue One
    from Alberta
    You’re probably referring to brake drums,
    They’re certainly not break or breaking drums :D
    If so they’ll need replacing.:p
  16. wuga
    wuga
    Don't screw around with your drums. Go to your supplier and find a Dorman stud the same length in a 1/2 20 thread, but with the shorter shoulder. I went through the same thing. Sorry I don't remember the part number.
    And you thread ***le slanders Speedway when you actually installed the wrong studs.
    Warren
    X38 likes this.
  17. Andy
    Andy
    I used studs for a F1 and they fit the drums perfectly.
    van's rod shop likes this.
  18. Perfect. Why don't the "techs" at Speedway know this? They gave me a Dorman part # that didn't work - 610-234. But Dorman 601-109 is what you recommended and they are right on.
  19. patina steve
    patina steve
    Specs for Studs Dorman 610-234 1/2" - 20 .621 Knurl 1 5/8" Length
    Dorman 601-109 1/2" - 20 .625 Knurl 1 5/8" Length
